[mapserver-commits] r10965 - trunk/mapserver/mapscript/php
svn at osgeo.org
svn at osgeo.org
Mon Feb 7 13:24:41 EST 2011
Author: aboudreault
Date: 2011-02-07 10:24:41 -0800 (Mon, 07 Feb 2011)
New Revision: 10965
Added:
trunk/mapserver/mapscript/php/result.c
Removed:
trunk/mapserver/mapscript/php/resultcachemember.c
removed cachemember and added result object in php
Added: trunk/mapserver/mapscript/php/result.c
--- trunk/mapserver/mapscript/php/result.c (rev 0)
+++ trunk/mapserver/mapscript/php/result.c 2011-02-07 18:24:41 UTC (rev 10965)
@@ -0,0 +1,170 @@
+ * $Id: php_mapscript.c 9765 2010-01-28 15:32:10Z aboudreault $
+ * Project: MapServer
+ * Purpose: PHP/MapScript extension for MapServer. External interface
+ * functions
+ * Author: Daniel Morissette, DM Solutions Group (dmorissette at dmsolutions.ca)
+ * Alan Boudreault, Mapgears
+ * Copyright (c) 2000-2010, Daniel Morissette, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies of this Software or works derived from this Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#include "php_mapscript.h"
+zend_class_entry *mapscript_ce_result;
+ZEND_BEGIN_ARG_INFO_EX(result___get_args, 0, 0, 1)
+ ZEND_ARG_INFO(0, property)
+ZEND_END_ARG_INFO()
+ZEND_BEGIN_ARG_INFO_EX(result___set_args, 0, 0, 2)
+ ZEND_ARG_INFO(0, value)
+/* {{{ proto resultObj __construct()
+ resultObj CANNOT be instanciated, this will throw an exception on use */
+PHP_METHOD(resultObj, __construct)
+ mapscript_throw_exception("resultObj cannot be constructed" TSRMLS_CC);
+PHP_METHOD(resultObj, __get)
+ char *property;
+ long property_len;
+ zval *zobj = getThis();
+ php_result_object *php_result;
+ PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s",
+ &property, &property_len) == FAILURE) {
+ PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
+ return;
+ php_result = (php_result_object *) zend_object_store_get_object(zobj TSRMLS_CC);
+ IF_GET_LONG("shapeindex", php_result->result->shapeindex)
+ else IF_GET_LONG("tileindex", php_result->result->tileindex)
+ else IF_GET_LONG("classindex", php_result->result->classindex)
+ else IF_GET_LONG("resultindex", php_result->result->resultindex)
+ else
+ mapscript_throw_exception("Property '%s' does not exist in this object." TSRMLS_CC, property);
+PHP_METHOD(resultObj, __set)
+ char *property;
+ zval *value;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "sz",
+ &property, &property_len, &value) == FAILURE) {
+ return;
+ if ( (STRING_EQUAL("shapeindex", property)) ||
+ (STRING_EQUAL("tileindex", property)) ||
+ (STRING_EQUAL("resultindex", property)) ||
+ (STRING_EQUAL("classindex", property)))
+ mapscript_throw_exception("Property '%s' is an object and can only be modified through its accessors." TSRMLS_CC, property);
+ else
+zend_function_entry result_functions[] = {
+ PHP_ME(resultObj, __construct, NULL, ZEND_ACC_PUBLIC|ZEND_ACC_CTOR)
+ PHP_ME(resultObj, __get, result___get_args, ZEND_ACC_PUBLIC)
+ PHP_ME(resultObj, __set, result___set_args, ZEND_ACC_PUBLIC)
+ {NULL, NULL, NULL}
+void mapscript_create_result(resultObj *result, parent_object parent,
+ zval *return_value TSRMLS_DC)
+ php_result_object * php_result;
+ object_init_ex(return_value, mapscript_ce_result);
+ php_result = (php_result_object *)zend_object_store_get_object(return_value TSRMLS_CC);
+ php_result->result = result;
+ php_result->parent = parent;
+ MAPSCRIPT_ADDREF(parent.val);
+static void mapscript_result_object_destroy(void *object TSRMLS_DC)
+ php_result_object *php_result = (php_result_object *)object;
+ MAPSCRIPT_FREE_OBJECT(php_result);
+ MAPSCRIPT_FREE_PARENT(php_result->parent);
+ /* We don't need to free the resultObj */
+ efree(object);
+static zend_object_value mapscript_result_object_new(zend_class_entry *ce TSRMLS_DC)
+ zend_object_value retval;
+ MAPSCRIPT_ALLOC_OBJECT(php_result, php_result_object);
+ retval = mapscript_object_new(&php_result->std, ce,
+ &mapscript_result_object_destroy TSRMLS_CC);
+ MAPSCRIPT_INIT_PARENT(php_result->parent);
+ return retval;
+PHP_MINIT_FUNCTION(result)
+ zend_class_entry ce;
+ MAPSCRIPT_REGISTER_CLASS("resultObj",
+ result_functions,
+ mapscript_ce_result,
+ mapscript_result_object_new);
+ mapscript_ce_result->ce_flags |= ZEND_ACC_FINAL_CLASS;
+ return SUCCESS;
Deleted: trunk/mapserver/mapscript/php/resultcachemember.c
--- trunk/mapserver/mapscript/php/resultcachemember.c 2011-02-07 17:26:59 UTC (rev 10964)
+++ trunk/mapserver/mapscript/php/resultcachemember.c 2011-02-07 18:24:41 UTC (rev 10965)
@@ -1,168 +0,0 @@
- * $Id: php_mapscript.c 9765 2010-01-28 15:32:10Z aboudreault $
- * Project: MapServer
- * Purpose: PHP/MapScript extension for MapServer. External interface
- * functions
- * Author: Daniel Morissette, DM Solutions Group (dmorissette at dmsolutions.ca)
- * Alan Boudreault, Mapgears
- * Copyright (c) 2000-2010, Daniel Morissette, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
- * all copies of this Software or works derived from this Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-#include "php_mapscript.h"
-zend_class_entry *mapscript_ce_resultcachemember;
-ZEND_BEGIN_ARG_INFO_EX(resultcachemember___get_args, 0, 0, 1)
- ZEND_ARG_INFO(0, property)
-ZEND_END_ARG_INFO()
-ZEND_BEGIN_ARG_INFO_EX(resultcachemember___set_args, 0, 0, 2)
- ZEND_ARG_INFO(0, value)
-/* {{{ proto resultCacheMemberObj __construct()
- resultCacheMemberObj CANNOT be instanciated, this will throw an exception on use */
-PHP_METHOD(resultCacheMemberObj, __construct)
- mapscript_throw_exception("resultCacheMemberObj cannot be constructed" TSRMLS_CC);
-PHP_METHOD(resultCacheMemberObj, __get)
- char *property;
- long property_len;
- zval *zobj = getThis();
- php_resultcachemember_object *php_resultcachemember;
- PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
- if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s",
- &property, &property_len) == FAILURE) {
- PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
- return;
- php_resultcachemember = (php_resultcachemember_object *) zend_object_store_get_object(zobj TSRMLS_CC);
- IF_GET_LONG("shapeindex", php_resultcachemember->resultcachemember->shapeindex)
- else IF_GET_LONG("tileindex", php_resultcachemember->resultcachemember->tileindex)
- else IF_GET_LONG("classindex", php_resultcachemember->resultcachemember->classindex)
- else
- mapscript_throw_exception("Property '%s' does not exist in this object." TSRMLS_CC, property);
-PHP_METHOD(resultCacheMemberObj, __set)
- char *property;
- zval *value;
- if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "sz",
- &property, &property_len, &value) == FAILURE) {
- return;
- if ( (STRING_EQUAL("shapeindex", property)) ||
- (STRING_EQUAL("tileindex", property)) ||
- (STRING_EQUAL("classindex", property)))
- mapscript_throw_exception("Property '%s' is an object and can only be modified through its accessors." TSRMLS_CC, property);
- else
-zend_function_entry resultcachemember_functions[] = {
- PHP_ME(resultCacheMemberObj, __construct, NULL, ZEND_ACC_PUBLIC|ZEND_ACC_CTOR)
- PHP_ME(resultCacheMemberObj, __get, resultcachemember___get_args, ZEND_ACC_PUBLIC)
- PHP_ME(resultCacheMemberObj, __set, resultcachemember___set_args, ZEND_ACC_PUBLIC)
- {NULL, NULL, NULL}
-void mapscript_create_resultcachemember(resultCacheMemberObj *resultcachemember, parent_object parent,
- zval *return_value TSRMLS_DC)
- php_resultcachemember_object * php_resultcachemember;
- object_init_ex(return_value, mapscript_ce_resultcachemember);
- php_resultcachemember = (php_resultcachemember_object *)zend_object_store_get_object(return_value TSRMLS_CC);
- php_resultcachemember->resultcachemember = resultcachemember;
- php_resultcachemember->parent = parent;
- MAPSCRIPT_ADDREF(parent.val);
-static void mapscript_resultcachemember_object_destroy(void *object TSRMLS_DC)
- php_resultcachemember_object *php_resultcachemember = (php_resultcachemember_object *)object;
- MAPSCRIPT_FREE_OBJECT(php_resultcachemember);
- MAPSCRIPT_FREE_PARENT(php_resultcachemember->parent);
- /* We don't need to free the resultCacheMemberObj */
- efree(object);
-static zend_object_value mapscript_resultcachemember_object_new(zend_class_entry *ce TSRMLS_DC)
- zend_object_value retval;
- MAPSCRIPT_ALLOC_OBJECT(php_resultcachemember, php_resultcachemember_object);
- retval = mapscript_object_new(&php_resultcachemember->std, ce,
- &mapscript_resultcachemember_object_destroy TSRMLS_CC);
- MAPSCRIPT_INIT_PARENT(php_resultcachemember->parent);
- return retval;
-PHP_MINIT_FUNCTION(resultcachemember)
- zend_class_entry ce;
- MAPSCRIPT_REGISTER_CLASS("resultCacheMemberObj",
- resultcachemember_functions,
- mapscript_ce_resultcachemember,
- mapscript_resultcachemember_object_new);
- mapscript_ce_resultcachemember->ce_flags |= ZEND_ACC_FINAL_CLASS;
- return SUCCESS;
More information about the mapserver-commits
