[mapserver-commits] r10966 - trunk/mapserver/mapscript/php
Mon Feb 7 13:30:03 EST 2011
Author: aboudreault
Date: 2011-02-07 10:30:03 -0800 (Mon, 07 Feb 2011)
New Revision: 10966
   trunk/mapserver/mapscript/php/layer.c
Removed GetFeature() method in PHP/MapScript
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c	2011-02-07 18:24:41 UTC (rev 10965)
+++ trunk/mapserver/mapscript/php/layer.c	2011-02-07 18:30:03 UTC (rev 10966)
@@ -82,11 +82,6 @@
   ZEND_ARG_OBJ_INFO(0, extent, rectObj, 0)
 ZEND_END_ARG_INFO()
-ZEND_BEGIN_ARG_INFO_EX(layer_getFeature_args, 0, 0, 1)
-  ZEND_ARG_INFO(0, shapeindex)
-  ZEND_ARG_INFO(0, tileindex)
-ZEND_END_ARG_INFO()
 ZEND_BEGIN_ARG_INFO_EX(layer_addFeature_args, 0, 0, 1)
   ZEND_ARG_OBJ_INFO(0, shape, shapeObj, 0)
 ZEND_END_ARG_INFO()
@@ -966,7 +961,7 @@
 /* {{{ proto int layer.open()
-   Open the layer for use with getFeature(). Returns MS_SUCCESS/MS_FAILURE. */
+   Open the layer for use with getShape(). Returns MS_SUCCESS/MS_FAILURE. */
 PHP_METHOD(layerObj, open)
     zval *zobj = getThis();
@@ -1082,49 +1077,6 @@
-/* {{{ proto shapeObj layer.getFeature(shapeindex, [tileindex])
-   Retrieve shapeObj from a layer by index. */
-PHP_METHOD(layerObj, getFeature)
-    zval *zobj = getThis();
-    long shapeindex, tileindex = -1;
-    shapeObj *shape = NULL;
-    php_layer_object *php_layer;
-    PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
-    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l|l",
-                              &shapeindex, &tileindex) == FAILURE) {
-        PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
-        return;
-    php_layer = (php_layer_object *) zend_object_store_get_object(zobj TSRMLS_CC);
-    /* Create a new shapeObj to hold the result
-     * Note that the type used to create the shape (MS_NULL) does not matter
-     * at this point since it will be set by SHPReadShape().
-    if ((shape = shapeObj_new(MS_SHAPE_NULL)) == NULL)
-        mapscript_throw_mapserver_exception("Failed creating new shape (out of memory?)" TSRMLS_CC);
-        return;
-    if (layerObj_getShape(php_layer->layer, shape, tileindex, shapeindex) != MS_SUCCESS)
-        shapeObj_destroy(shape);
-        mapscript_throw_mapserver_exception("" TSRMLS_CC);
-        return;
-    /* Return valid object */
-    MAPSCRIPT_MAKE_PARENT(NULL, NULL);
-    mapscript_create_shape(shape, parent, php_layer, return_value TSRMLS_CC);
 /* {{{ proto int layer.getExtent()
    Retrieve or calculate a layer's extents. */
 PHP_METHOD(layerObj, getExtent)
@@ -1962,7 +1914,6 @@
     PHP_ME(layerObj, whichShapes, layer_whichShapes_args, ZEND_ACC_PUBLIC)
     PHP_ME(layerObj, nextShape, NULL, ZEND_ACC_PUBLIC)
     PHP_ME(layerObj, close, NULL, ZEND_ACC_PUBLIC)
-    PHP_ME(layerObj, getFeature, layer_getFeature_args, ZEND_ACC_PUBLIC)
     PHP_ME(layerObj, getExtent, NULL, ZEND_ACC_PUBLIC)
     PHP_ME(layerObj, addFeature, layer_addFeature_args, ZEND_ACC_PUBLIC)
     PHP_ME(layerObj, getMetaData, layer_getMetaData_args, ZEND_ACC_PUBLIC)
