[mapserver-commits] r10970 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Feb 8 13:43:08 EST 2011
Author: aboudreault
Date: 2011-02-08 10:43:08 -0800 (Tue, 08 Feb 2011)
New Revision: 10970
trunk/mapserver/maporaclespatial.c
One-pass Query Improvements: Fixed OracleSpatial driver
Modified: trunk/mapserver/maporaclespatial.c
--- trunk/mapserver/maporaclespatial.c 2011-02-08 18:27:04 UTC (rev 10969)
+++ trunk/mapserver/maporaclespatial.c 2011-02-08 18:43:08 UTC (rev 10970)
@@ -1921,7 +1921,7 @@
/* create SQL statement for retrieving shapes */
-/* Sets up cursor for use in *NextShape and *ResultsGetShape */
+/* Sets up cursor for use in *NextShape and *GetShape */
int msOracleSpatialLayerWhichShapes( layerObj *layer, rectObj rect )
int success, i;
@@ -2254,6 +2254,7 @@
msOracleSpatialHandler *hand = NULL;
msOracleSpatialStatement *sthand = NULL;
if (layerinfo == NULL)
msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerWhichShapes called on unopened layer", "msOracleSpatialLayerNextShape()" );
@@ -2301,7 +2302,7 @@
/* get the items for the shape */
shape->index = atol( (char *)(sthand->items[sthand->uniqueidindex][ sthand->row ])); /* Primary Key */
- shape->tileindex = sthand->row_num; /* Index into cursor: TODO, THIS SHOULD SET THE RESULTINDEX INSTEAD */
+ shape->resultindex = sthand->row_num;
shape->numvalues = layer->numitems;
shape->values = (char **)malloc( sizeof(char*) * shape->numvalues );
@@ -2344,10 +2345,9 @@
return MS_SUCCESS;
-int msOracleSpatialLayerResultGetShape( layerObj *layer, shapeObj *shape, int record, long pkey)
+int msOracleSpatialLayerGetShape( layerObj *layer, shapeObj *shape, resultObj *record)
int success, i;
- long buffer_first_row_num, buffer_last_row_num;
SDOGeometryObj *obj;
SDOGeometryInd *ind;
msOracleSpatialDataHandler *dthand = NULL;
@@ -2355,8 +2355,11 @@
msOracleSpatialLayerInfo *layerinfo;
+ long shapeindex = record->shapeindex;
+ int resultindex = record->resultindex;
if(layer == NULL) {
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called on unopened layer","msOracleSpatialLayerResultGetShape()" );
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetShape called on unopened layer","msOracleSpatialLayerGetShape()" );
return MS_FAILURE;
@@ -2364,117 +2367,412 @@
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called on unopened layer (layerinfo)","msOracleSpatialLayerResultGetShape()" );
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetShape called on unopened layer (layerinfo)","msOracleSpatialLayerGetShape()" );
return MS_FAILURE;
- /* get layerinfo */
- dthand = (msOracleSpatialDataHandler *)layerinfo->oradatahandlers;
- hand = (msOracleSpatialHandler *)layerinfo->orahandlers;
- sthand = (msOracleSpatialStatement *)layerinfo->orastmt2;
- if (layer->resultcache == NULL)
+ /* If resultindex is set, fetch the shape from the resultcache, otherwise fetch it from the DB */
+ if (resultindex >= 0)
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape called before msOracleSpatialLayerWhichShapes()","msOracleSpatialLayerResultGetShape()" );
- return MS_FAILURE;
- /* TODO: do we need to fall back... we should never get here.
- * fprintf(stderr, "WARNING: msOracleSpatialLayerResultGetShape called before msOracleSpatialLayerWhichShapes()\n");
- * return msOracleSpatialLayerGetShape(layer, shape, pkey);*/
+ long buffer_first_row_num, buffer_last_row_num;
+ /* get layerinfo */
+ dthand = (msOracleSpatialDataHandler *)layerinfo->oradatahandlers;
+ hand = (msOracleSpatialHandler *)layerinfo->orahandlers;
+ sthand = (msOracleSpatialStatement *)layerinfo->orastmt2;
- //record = layer->resultcache->results[record].tileindex; // Do we need to do this? Is record our tile index or an index into the result cache?
+ if (layer->resultcache == NULL)
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetShape called before msOracleSpatialLayerWhichShapes()","msOracleSpatialLayerGetShape()" );
+ return MS_FAILURE;
- if (record >= sthand->rows_count || record < 0)
- /*msDebug("msOracleSpatialLayerResultGetShape problem with cursor. Trying to fetch record = %ld of %ld, falling back to GetShape\n",
- * record, sthand->rows_count);
- *return msOracleSpatialLayerGetShape(layer, shape, pkey); */
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape record out of range","msOracleSpatialLayerResultGetShape()" );
+ if (resultindex >= sthand->rows_count)
+ if (layer->debug >= 5)
+ msDebug("msOracleSpatialLayerGetShape problem with cursor. Trying to fetch record = %ld of %ld, falling back to GetShape\n", resultindex, sthand->rows_count);
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetShape record out of range","msOracleSpatialLayerGetShape()" );
- if (layer->debug >= 5)
- msDebug("msOracleSpatialLayerResultGetShape was called. Using the record = %ld of %ld. (shape: %ld should equal pkey: %ld)\n",
- record, layer->resultcache->numresults, layer->resultcache->results[record].shapeindex, pkey);
+ msDebug("msOracleSpatialLayerGetShape was called. Using the record = %ld of %ld. (shape: %ld should equal pkey: %ld)\n",
+ resultindex, layer->resultcache->numresults, layer->resultcache->results[resultindex].shapeindex, shapeindex);
- /* NOTE: with the way the resultcache works, we should see items in increasing order, but some may have been filtered out. */
- /* Best case: item in buffer */
- /* Next best case: item is in next fetch block */
- /* Worst case: item is random access */
- buffer_first_row_num = sthand->row_num - sthand->row; /* cursor id of first item in buffer */
- buffer_last_row_num = buffer_first_row_num + sthand->rows_fetched - 1; /* cursor id of last item in buffer */
- if(record >= buffer_first_row_num && record <= buffer_last_row_num) /* Item is in buffer. Calculate position in buffer */
- sthand->row += record - sthand->row_num; /* move sthand row an row_num by offset from last call */
- sthand->row_num += record - sthand->row_num;
- else /* Item is not in buffer. Fetch item from Oracle */
- if (layer->debug >= 4)
- msDebug("msOracleSpatialLayerResultGetShape: Fetching result from DB start: %ld end:%ld record: %ld\n", buffer_first_row_num, buffer_last_row_num, record);
+ /* NOTE: with the way the resultcache works, we should see items in increasing order, but some may have been filtered out. */
+ /* Best case: item in buffer */
+ /* Next best case: item is in next fetch block */
+ /* Worst case: item is random access */
+ buffer_first_row_num = sthand->row_num - sthand->row; /* cursor id of first item in buffer */
+ buffer_last_row_num = buffer_first_row_num + sthand->rows_fetched - 1; /* cursor id of last item in buffer */
+ if(resultindex >= buffer_first_row_num && resultindex <= buffer_last_row_num) /* Item is in buffer. Calculate position in buffer */
+ sthand->row += resultindex - sthand->row_num; /* move sthand row an row_num by offset from last call */
+ sthand->row_num += resultindex - sthand->row_num;
+ else /* Item is not in buffer. Fetch item from Oracle */
+ if (layer->debug >= 4)
+ msDebug("msOracleSpatialLayerGetShape: Fetching result from DB start: %ld end:%ld record: %ld\n", buffer_first_row_num, buffer_last_row_num, resultindex);
- success = TRY( hand, OCIStmtFetch2( sthand->stmthp, hand->errhp, (ub4)ARRAY_SIZE, (ub2)OCI_FETCH_ABSOLUTE, (sb4)record+1, (ub4)OCI_DEFAULT ) )
+ success = TRY( hand, OCIStmtFetch2( sthand->stmthp, hand->errhp, (ub4)ARRAY_SIZE, (ub2)OCI_FETCH_ABSOLUTE, (sb4)resultindex+1, (ub4)OCI_DEFAULT ) )
&& TRY( hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROWS_FETCHED, hand->errhp ) );
- ERROR("msOracleSpatialLayerResultGetShape", hand, dthand);
+ ERROR("msOracleSpatialLayerGetShape", hand, dthand);
- sthand->row_num = record;
- sthand->row = 0; /* reset row index */
+ sthand->row_num = resultindex;
+ sthand->row = 0; /* reset row index */
- if (!success || sthand->rows_fetched == 0) {
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerResultGetShape could not fetch specified record.", "msOracleSpatialLayerResultGetShape()" );
+ if (!success || sthand->rows_fetched == 0) {
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetShape could not fetch specified record.", "msOracleSpatialLayerGetShape()" );
+ /* set obj & ind for current row */
+ obj = sthand->obj[ sthand->row ];
+ ind = sthand->ind[ sthand->row ];
+ /* get the items for the shape */
+ shape->index = shapeindex; /* By definition this is what we asked for */
+ shape->numvalues = layer->numitems;
+ shape->values = (char **)malloc( sizeof(char*) * shape->numvalues );
+ if (shape->values == NULL)
+ msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values", "msOracleSpatialLayerNextShape()" );
return MS_FAILURE;
- /* set obj & ind for current row */
- obj = sthand->obj[ sthand->row ];
- ind = sthand->ind[ sthand->row ];
+ for( i=0; i < shape->numvalues; ++i )
+ shape->values[i] = (char *)malloc(strlen((char *)sthand->items[i][ sthand->row ])+1);
+ if (shape->values[i] == NULL)
+ msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items", "msOracleSpatialLayerNextShape()" );
+ else
+ strcpy(shape->values[i], (char *)sthand->items[i][ sthand->row ]);
+ shape->values[i][strlen((char *)sthand->items[i][ sthand->row ])] = '\0';
- /* get the items for the shape */
- shape->index = record; /* By definition this is what we asked for */
- shape->numvalues = layer->numitems;
+ /* fetch a layer->type object */
+ success = osGetOrdinates(dthand, hand, shape, obj, ind);
- shape->values = (char **)malloc( sizeof(char*) * shape->numvalues );
- if (shape->values == NULL)
- msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values", "msOracleSpatialLayerNextShape()" );
+ if (success != MS_SUCCESS)
+ msSetError( MS_ORACLESPATIALERR, "Call to osGetOrdinates failed.", "msOracleSpatialLayerGetShape()" );
- for( i=0; i < shape->numvalues; ++i )
+ osShapeBounds(shape);
+ if(shape->type == MS_SHAPE_NULL) {
+ msSetError( MS_ORACLESPATIALERR, "Shape type is null... this probably means a record number was requested that could not have beeen in a result set (as returned by NextShape).", "msOracleSpatialLayerGetShape()" );
+ return (MS_SUCCESS);
+ else /* no resultindex, fetch the shape from the DB */
- shape->values[i] = (char *)malloc(strlen((char *)sthand->items[i][ sthand->row ])+1);
- if (shape->values[i] == NULL)
+ char *table_name;
+ char query_str[6000], *geom_column_name = NULL, *unique = NULL, *srid = NULL;
+ int function = 0;
+ int version = 0;
+ sb2 *nullind = NULL;
+ /*OCIDefine *adtp = NULL, *items[QUERY_SIZE] = { NULL };*/
+ OCIDefine *adtp = NULL;
+ OCIDefine **items = NULL;
+ if (layer->debug)
+ msDebug("msOracleSpatialLayerGetShape was called. Using the record = %ld.\n", shapeindex);
+ sthand = (msOracleSpatialStatement *) layerinfo->orastmt;
+ /* allocate enough space for items */
+ if (layer->numitems > 0)
- msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items", "msOracleSpatialLayerNextShape()" );
+ if (sthand->items_query == NULL)
+ sthand->items_query = (item_text_array_query *)malloc( sizeof(item_text_array_query) * (layer->numitems) );
+ msSetError( MS_ORACLESPATIALERR, "Cannot allocate layerinfo->items_query buffer", "msOracleSpatialLayerGetShape()" );
+ nullind = (sb2 *)malloc( sizeof(sb2) * (layer->numitems) );
+ if (nullind == NULL)
+ msSetError( MS_ORACLESPATIALERR, "Cannot allocate nullind buffer", "msOracleSpatialLayerGetShape()" );
+ memset(nullind ,0, sizeof(sb2) * (layer->numitems) );
+ items = (OCIDefine **)malloc(sizeof(OCIDefine *)*layer->numitems);
+ if (items == NULL)
+ msSetError( MS_ORACLESPATIALERR,"Cannot allocate items buffer","msOracleSpatialLayerWhichShapes()" );
+ /* clean nullind */
+ free(nullind);
+ memset(items ,0,sizeof(OCIDefine *)*layer->numitems);
+ table_name = (char *) malloc(sizeof(char) * TABLE_NAME_SIZE);
+ if (!msSplitData( layer->data, &geom_column_name, &table_name, &unique, &srid, &function, &version ))
+ "Error parsing OracleSpatial DATA variable. Must be: "
+ "'geometry_column FROM table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or "
+ "'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. "
+ "If want to set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or NONE. "
+ "Your data statement: %s",
+ "msOracleSpatialLayerGetShape()", layer->data );
+ free(nullind);
+ /* clean items */
+ free(items);
+ if (geom_column_name) free(geom_column_name);
+ if (srid) free(srid);
+ if (unique) free(unique);
+ free(table_name);
return MS_FAILURE;
- else
+ /*Define the first query to retrive itens*/
+ if (unique[0] == '\0')
- strcpy(shape->values[i], (char *)sthand->items[i][ sthand->row ]);
- shape->values[i][strlen((char *)sthand->items[i][ sthand->row ])] = '\0';
+ "Error parsing OracleSpatial DATA variable for query. To execute "
+ "query functions you need to define one "
+ "unique column [USING UNIQUE <#column>]",
+ "msOracleSpatialLayerGetShape()" );
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ else
+ snprintf( query_str, sizeof(query_str), "SELECT");
+ /*Define the query*/
+ for( i = 0; i < layer->numitems; ++i )
+ snprintf( query_str + strlen(query_str), sizeof(query_str)-strlen(query_str), " %s,", layer->items[i] );
- /* fetch a layer->type object */
- success = osGetOrdinates(dthand, hand, shape, obj, ind);
+ snprintf( query_str + strlen(query_str), sizeof(query_str)-strlen(query_str), " %s FROM %s WHERE %s = %ld", geom_column_name, table_name, unique, shapeindex);
+ /*if (layer->filter.string != NULL)
+ sprintf( query_str + strlen(query_str), " AND %s", (layer->filter.string));*/
+ osFilteritem(layer, FUNCTION_NONE, query_str, sizeof(query_str), 2);
- if (success != MS_SUCCESS)
- msSetError( MS_ORACLESPATIALERR, "Call to osGetOrdinates failed.", "msOracleSpatialLayerResultGetShape()" );
+ if (layer->debug)
+ msDebug("msOracleSpatialLayerGetShape. Sql: %s\n", query_str);
+ /*Prepare the handlers to the query*/
+ success = TRY( hand,OCIStmtPrepare( sthand->stmthp, hand->errhp, (text *)query_str, (ub4)strlen(query_str), (ub4)OCI_NTV_SYNTAX, (ub4)OCI_DEFAULT) );
+ if (success && layer->numitems > 0)
+ for( i = 0; i < layer->numitems && success; i++ )
+ success = TRY( hand, OCIDefineByPos( sthand->stmthp, &items[i], hand->errhp, (ub4)i+1, (dvoid *)sthand->items_query[i], (sb4)TEXT_SIZE, SQLT_STR, (sb2 *)&nullind[i], (ub2 *)0, (ub2 *)0, (ub4)OCI_DEFAULT ) );
+ if(!success)
+ "Error: %s . "
+ "Query statement: %s . "
+ "Check your data statement.",
+ "msOracleSpatialLayerGetShape()", hand->last_oci_error, query_str );
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ if (success)
+ success = TRY( hand, OCIDefineByPos( sthand->stmthp, &adtp, hand->errhp, (ub4)layer->numitems+1, (dvoid *)0, (sb4)0, SQLT_NTY, (dvoid *)0, (ub2 *)0, (ub2 *)0, (ub4)OCI_DEFAULT) )
+ && TRY( hand, OCIDefineObject( adtp, hand->errhp, dthand->tdo, (dvoid **)sthand->obj, (ub4 *)0, (dvoid **)sthand->ind, (ub4 *)0 ) )
+ && TRY (hand, OCIStmtExecute( hand->svchp, sthand->stmthp, hand->errhp, (ub4)QUERY_SIZE, (ub4)0, (OCISnapshot *)NULL, (OCISnapshot *)NULL, (ub4)OCI_DEFAULT ))
+ && TRY (hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROW_COUNT, hand->errhp ));
+ if(!success)
+ "Error: %s . "
+ "Query statement: %s ."
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ shape->type = MS_SHAPE_NULL;
+ /* no rows fetched */
+ if (sthand->rows_fetched == 0)
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ return (MS_DONE);
+ shape->values = (char **) malloc(sizeof(char *) * layer->numitems);
+ msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values.", "msOracleSpatialLayerGetShape()" );
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ shape->values[i] = (char *)malloc(strlen((char *)sthand->items_query[sthand->row][i])+1);
+ msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items buffer.", "msOracleSpatialLayerGetShape()" );
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ else
+ if (nullind[i] != OCI_IND_NULL)
+ strcpy(shape->values[i], (char *)sthand->items_query[sthand->row][i]);
+ shape->values[i][strlen((char *)sthand->items_query[sthand->row][i])] = '\0';
+ else
+ shape->values[i][0] = '\0';
+ /* increment for next row */
+ sthand->row_num++;
+ sthand->row++;
+ msSetError( MS_ORACLESPATIALERR, "Cannot execute query", "msOracleSpatialLayerGetShape()" );
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
+ sthand->row = sthand->row_num = 0;
+ free(nullind);
+ /* clean items */
+ free(items);
+ free(table_name);
- osShapeBounds(shape);
- if(shape->type == MS_SHAPE_NULL) {
- /*fprintf(stderr, "\trecord: %ld, row: %d rownum: %ld pkey: %s\n", record, sthand->row, sthand->row_num, shape->values[0]);*/
- msSetError( MS_ORACLESPATIALERR, "Shape type is null... this probably means a record number was requested that could not have beeen in a result set (as returned by NextShape).", "msOracleSpatialLayerResultGetShape()" );
- return (MS_SUCCESS);
int msOracleSpatialLayerInitItemInfo( layerObj *layer )
@@ -2911,324 +3209,6 @@
return msOracleSpatialLayerInitItemInfo( layer );
-int msOracleSpatialLayerGetShape( layerObj *layer, shapeObj *shape, resultObj *record )
- char *table_name;
- char query_str[6000], *geom_column_name = NULL, *unique = NULL, *srid = NULL;
- int success, i;
- int function = 0;
- int version = 0;
- SDOGeometryObj *obj = NULL;
- SDOGeometryInd *ind = NULL;
- sb2 *nullind = NULL;
- /*OCIDefine *adtp = NULL, *items[QUERY_SIZE] = { NULL };*/
- OCIDefine *adtp = NULL;
- OCIDefine **items = NULL;
- msOracleSpatialLayerInfo *layerinfo = (msOracleSpatialLayerInfo *)layer->layerinfo;
- msOracleSpatialDataHandler *dthand = NULL;
- msOracleSpatialHandler *hand = NULL;
- msOracleSpatialStatement *sthand = NULL;
- long shapeindex = record->shapeindex;
- int resultindex = record->resultindex;
- /* TODO: MERGE WITH msOracleSpatialLayerGetShape(), use the result index if set */
- if (layer->debug)
- msDebug("msOracleSpatialLayerGetShape was called. Using the record = %ld.\n", shapeindex);
- if (layerinfo == NULL)
- msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetShape called on unopened layer","msOracleSpatialLayerGetShape()" );
- else
- sthand = (msOracleSpatialStatement *) layerinfo->orastmt;
- /* allocate enough space for items */
- if (layer->numitems > 0)
- if (sthand->items_query == NULL)
- sthand->items_query = (item_text_array_query *)malloc( sizeof(item_text_array_query) * (layer->numitems) );
- msSetError( MS_ORACLESPATIALERR, "Cannot allocate layerinfo->items_query buffer", "msOracleSpatialLayerGetShape()" );
- nullind = (sb2 *)malloc( sizeof(sb2) * (layer->numitems) );
- if (nullind == NULL)
- msSetError( MS_ORACLESPATIALERR, "Cannot allocate nullind buffer", "msOracleSpatialLayerGetShape()" );
- memset(nullind ,0, sizeof(sb2) * (layer->numitems) );
- items = (OCIDefine **)malloc(sizeof(OCIDefine *)*layer->numitems);
- if (items == NULL)
- msSetError( MS_ORACLESPATIALERR,"Cannot allocate items buffer","msOracleSpatialLayerWhichShapes()" );
- /* clean nullind */
- free(nullind);
- memset(items ,0,sizeof(OCIDefine *)*layer->numitems);
- table_name = (char *) malloc(sizeof(char) * TABLE_NAME_SIZE);
- if (!msSplitData( layer->data, &geom_column_name, &table_name, &unique, &srid, &function, &version ))
- "Error parsing OracleSpatial DATA variable. Must be: "
- "'geometry_column FROM table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or "
- "'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. "
- "If want to set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or NONE. "
- "Your data statement: %s",
- "msOracleSpatialLayerGetShape()", layer->data );
- free(nullind);
- /* clean items */
- free(items);
- if (geom_column_name) free(geom_column_name);
- if (srid) free(srid);
- if (unique) free(unique);
- free(table_name);
- /*Define the first query to retrive itens*/
- if (unique[0] == '\0')
- "Error parsing OracleSpatial DATA variable for query. To execute "
- "query functions you need to define one "
- "unique column [USING UNIQUE <#column>]",
- "msOracleSpatialLayerGetShape()" );
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- else
- snprintf( query_str, sizeof(query_str), "SELECT");
- /*Define the query*/
- for( i = 0; i < layer->numitems; ++i )
- snprintf( query_str + strlen(query_str), sizeof(query_str)-strlen(query_str), " %s,", layer->items[i] );
- snprintf( query_str + strlen(query_str), sizeof(query_str)-strlen(query_str), " %s FROM %s WHERE %s = %ld", geom_column_name, table_name, unique, shapeindex);
- /*if (layer->filter.string != NULL)
- sprintf( query_str + strlen(query_str), " AND %s", (layer->filter.string));*/
- osFilteritem(layer, FUNCTION_NONE, query_str, sizeof(query_str), 2);
- if (layer->debug)
- msDebug("msOracleSpatialLayerGetShape. Sql: %s\n", query_str);
- /*Prepare the handlers to the query*/
- success = TRY( hand,OCIStmtPrepare( sthand->stmthp, hand->errhp, (text *)query_str, (ub4)strlen(query_str), (ub4)OCI_NTV_SYNTAX, (ub4)OCI_DEFAULT) );
- if (success && layer->numitems > 0)
- for( i = 0; i < layer->numitems && success; i++ )
- success = TRY( hand, OCIDefineByPos( sthand->stmthp, &items[i], hand->errhp, (ub4)i+1, (dvoid *)sthand->items_query[i], (sb4)TEXT_SIZE, SQLT_STR, (sb2 *)&nullind[i], (ub2 *)0, (ub2 *)0, (ub4)OCI_DEFAULT ) );
- if(!success)
- "Error: %s . "
- "Query statement: %s . "
- "Check your data statement.",
- "msOracleSpatialLayerGetShape()", hand->last_oci_error, query_str );
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- if (success)
- success = TRY( hand, OCIDefineByPos( sthand->stmthp, &adtp, hand->errhp, (ub4)layer->numitems+1, (dvoid *)0, (sb4)0, SQLT_NTY, (dvoid *)0, (ub2 *)0, (ub2 *)0, (ub4)OCI_DEFAULT) )
- && TRY( hand, OCIDefineObject( adtp, hand->errhp, dthand->tdo, (dvoid **)sthand->obj, (ub4 *)0, (dvoid **)sthand->ind, (ub4 *)0 ) )
- && TRY (hand, OCIStmtExecute( hand->svchp, sthand->stmthp, hand->errhp, (ub4)QUERY_SIZE, (ub4)0, (OCISnapshot *)NULL, (OCISnapshot *)NULL, (ub4)OCI_DEFAULT ))
- && TRY (hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROW_COUNT, hand->errhp ));
- if(!success)
- "Error: %s . "
- "Query statement: %s ."
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- shape->type = MS_SHAPE_NULL;
- /* no rows fetched */
- if (sthand->rows_fetched == 0)
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- return (MS_DONE);
- shape->values = (char **) malloc(sizeof(char *) * layer->numitems);
- msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values.", "msOracleSpatialLayerGetShape()" );
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- shape->index = shapeindex;
- shape->values[i] = (char *)malloc(strlen((char *)sthand->items_query[sthand->row][i])+1);
- msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items buffer.", "msOracleSpatialLayerGetShape()" );
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- else
- if (nullind[i] != OCI_IND_NULL)
- strcpy(shape->values[i], (char *)sthand->items_query[sthand->row][i]);
- shape->values[i][strlen((char *)sthand->items_query[sthand->row][i])] = '\0';
- else
- shape->values[i][0] = '\0';
- /* increment for next row */
- sthand->row_num++;
- sthand->row++;
- msSetError( MS_ORACLESPATIALERR, "Cannot execute query", "msOracleSpatialLayerGetShape()" );
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
- sthand->row = sthand->row_num = 0;
- free(nullind);
- /* clean items */
- free(items);
- free(table_name);
int msOracleSpatialLayerGetExtent(layerObj *layer, rectObj *extent)
char *table_name;
More information about the mapserver-commits
