[mapserver-commits] r10971 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Feb 8 14:39:03 EST 2011
Author: aboudreault
Date: 2011-02-08 11:39:03 -0800 (Tue, 08 Feb 2011)
New Revision: 10971
trunk/mapserver/mappostgis.c
One-pass Query Improvements: Fixed PostGIS driver
Modified: trunk/mapserver/mappostgis.c
--- trunk/mapserver/mappostgis.c 2011-02-08 18:43:08 UTC (rev 10970)
+++ trunk/mapserver/mappostgis.c 2011-02-08 19:39:03 UTC (rev 10971)
@@ -2118,10 +2118,10 @@
if( layer->debug > 4 ) {
msDebug("msPostGISReadShape: Setting shape->index = %d\n", uid);
- msDebug("msPostGISReadShape: Setting shape->tileindex = %d\n", layerinfo->rownum);
+ msDebug("msPostGISReadShape: Setting shape->resultindex = %d\n", layerinfo->rownum);
shape->index = uid;
- shape->tileindex = layerinfo->rownum; /* TODO: I think this should set resultindex now */
+ shape->resultindex = layerinfo->rownum;
if( layer->debug > 2 ) {
msDebug("msPostGISReadShape: [index] %d\n", shape->index);
@@ -2543,160 +2543,139 @@
-** msPostGISLayerResultsGetShape()
+** msPostGISLayerGetShape()
** Registered vtable->LayerGetShape function. For pulling from a prepared and
-** undisposed result set. We ignore the 'tile' parameter, as it means nothing to us.
+** undisposed result set.
-int msPostGISLayerResultsGetShape(layerObj *layer, shapeObj *shape, int tile, long record) {
+int msPostGISLayerGetShape(layerObj *layer, shapeObj *shape, resultObj *record) {
#ifdef USE_POSTGIS
PGresult *pgresult = NULL;
msPostGISLayerInfo *layerinfo = NULL;
int result = MS_SUCCESS;
- int status;
+ long shapeindex = record->shapeindex;
+ int resultindex = record->resultindex;
assert(layer != NULL);
assert(layer->layerinfo != NULL);
if (layer->debug) {
- msDebug("msPostGISLayerResultsGetShape called for record = %i\n", record);
+ msDebug("msPostGISLayerGetShape called for record = %i\n", resultindex);
- if( tile < 0 ) {
- return msPostGISLayerResultsGetShape(layer, shape, tile, record);
+ /* If resultindex is set, fetch the shape from the resultcache, otherwise fetch it from the DB */
+ if (resultindex >= 0)
+ int status;
- layerinfo = (msPostGISLayerInfo*) layer->layerinfo;
+ layerinfo = (msPostGISLayerInfo*) layer->layerinfo;
- /* Check the validity of the open result. */
- pgresult = layerinfo->pgresult;
- if ( ! pgresult ) {
- msSetError( MS_MISCERR,
- "PostgreSQL result set is null.",
- "msPostGISLayerResultsGetShape()");
- return MS_FAILURE;
- status = PQresultStatus(pgresult);
- if ( layer->debug > 1 ) {
- msDebug("msPostGISLayerResultsGetShape query status: %s (%d)\n", PQresStatus(status), status);
- if( ! ( status == PGRES_COMMAND_OK || status == PGRES_TUPLES_OK) ) {
- "PostgreSQL result set is not ready.",
+ /* Check the validity of the open result. */
+ pgresult = layerinfo->pgresult;
+ if ( ! pgresult ) {
+ msSetError( MS_MISCERR,
+ "PostgreSQL result set is null.",
+ "msPostGISLayerGetShape()");
+ return MS_FAILURE;
+ status = PQresultStatus(pgresult);
+ if ( layer->debug > 1 ) {
+ msDebug("msPostGISLayerGetShape query status: %s (%d)\n", PQresStatus(status), status);
+ if( ! ( status == PGRES_COMMAND_OK || status == PGRES_TUPLES_OK) ) {
+ "PostgreSQL result set is not ready.",
- /* Check the validity of the requested record number. */
- if( tile >= PQntuples(pgresult) ) {
- msDebug("msPostGISLayerResultsGetShape got request for (%d) but only has %d tuples.\n", tile, PQntuples(pgresult));
- "Got request larger than result set.",
+ /* Check the validity of the requested record number. */
+ if( resultindex >= PQntuples(pgresult) ) {
+ msDebug("msPostGISLayerGetShape got request for (%d) but only has %d tuples.\n", resultindex, PQntuples(pgresult));
+ "Got request larger than result set.",
- layerinfo->rownum = tile; /* Only return one result. */
+ layerinfo->rownum = resultindex; /* Only return one result. */
- /* We don't know the shape type until we read the geometry. */
- shape->type = MS_SHAPE_NULL;
+ /* We don't know the shape type until we read the geometry. */
+ shape->type = MS_SHAPE_NULL;
- /* Return the shape, cursor access mode. */
- result = msPostGISReadShape(layer, shape);
+ /* Return the shape, cursor access mode. */
+ result = msPostGISReadShape(layer, shape);
- return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : MS_SUCCESS;
-#else
- "PostGIS support is not available.",
-#endif
-** msPostGISLayerGetShape()
-** Registered vtable->LayerGetShape function. TODO: MERGE WITH msPostGISLayerResultsGetShape()...
-int msPostGISLayerGetShape(layerObj *layer, shapeObj *shape, resultObj *record) {
-#ifdef USE_POSTGIS
- PGresult *pgresult;
- msPostGISLayerInfo *layerinfo;
- int result, num_tuples;
- char *strSQL = 0;
- long shapeindex = record->shapeindex; /* global index */
- int resultindex = record->resultindex; /* local index to a result set (if set) */
- assert(layer != NULL);
- assert(layer->layerinfo != NULL);
- if (layer->debug) {
- msDebug("msPostGISLayerGetShape called for record = %i\n", shapeindex);
+ return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : MS_SUCCESS;
+ else /* no resultindex, fetch the shape from the DB */
+ int num_tuples;
+ char *strSQL = 0;
- /* Fill out layerinfo with our current DATA state. */
- if ( msPostGISParseData(layer) != MS_SUCCESS) {
+ /* Fill out layerinfo with our current DATA state. */
+ if ( msPostGISParseData(layer) != MS_SUCCESS) {
- ** This comes *after* parsedata, because parsedata fills in
- ** layer->layerinfo.
+ ** This comes *after* parsedata, because parsedata fills in
+ ** layer->layerinfo.
- /* Build a SQL query based on our current state. */
- strSQL = msPostGISBuildSQL(layer, 0, &shapeindex);
- if ( ! strSQL ) {
- msSetError(MS_QUERYERR, "Failed to build query SQL.", "msPostGISLayerGetShape()");
+ /* Build a SQL query based on our current state. */
+ strSQL = msPostGISBuildSQL(layer, 0, &shapeindex);
+ if ( ! strSQL ) {
+ msSetError(MS_QUERYERR, "Failed to build query SQL.", "msPostGISLayerGetShape()");
- msDebug("msPostGISLayerGetShape query: %s\n", strSQL);
+ if (layer->debug) {
+ msDebug("msPostGISLayerGetShape query: %s\n", strSQL);
- pgresult = PQexec(layerinfo->pgconn, strSQL);
+ pgresult = PQexec(layerinfo->pgconn, strSQL);
- /* Something went wrong. */
- if ( (!pgresult) || (PQresultStatus(pgresult) != PGRES_TUPLES_OK) ) {
- msSetError(MS_QUERYERR, "Error (%s) executing SQL: %s", "msPostGISLayerGetShape()", PQerrorMessage(layerinfo->pgconn), strSQL );
+ /* Something went wrong. */
+ if ( (!pgresult) || (PQresultStatus(pgresult) != PGRES_TUPLES_OK) ) {
+ msSetError(MS_QUERYERR, "Error (%s) executing SQL: %s", "msPostGISLayerGetShape()", PQerrorMessage(layerinfo->pgconn), strSQL );
- if (pgresult) {
- PQclear(pgresult);
+ if (pgresult) {
+ PQclear(pgresult);
+ free(strSQL);
- free(strSQL);
+ /* Clean any existing pgresult before storing current one. */
+ if(layerinfo->pgresult) PQclear(layerinfo->pgresult);
+ layerinfo->pgresult = pgresult;
- /* Clean any existing pgresult before storing current one. */
- if(layerinfo->pgresult) PQclear(layerinfo->pgresult);
- layerinfo->pgresult = pgresult;
+ /* Clean any existing SQL before storing current. */
+ if(layerinfo->sql) free(layerinfo->sql);
+ layerinfo->sql = strSQL;
- /* Clean any existing SQL before storing current. */
- if(layerinfo->sql) free(layerinfo->sql);
- layerinfo->sql = strSQL;
+ layerinfo->rownum = 0; /* Only return one result. */
- layerinfo->rownum = 0; /* Only return one result. */
+ num_tuples = PQntuples(pgresult);
+ msDebug("msPostGISLayerGetShape number of records: %d\n", num_tuples);
- num_tuples = PQntuples(pgresult);
- msDebug("msPostGISLayerGetShape number of records: %d\n", num_tuples);
+ if (num_tuples > 0) {
+ /* Get shape in random access mode. */
- if (num_tuples > 0) {
- /* Get shape in random access mode. */
+ return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : ( (num_tuples > 0) ? MS_SUCCESS : MS_DONE );
- return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : ( (num_tuples > 0) ? MS_SUCCESS : MS_DONE );
#else
More information about the mapserver-commits
