[mapserver-commits] r11010 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Feb 24 23:56:20 EST 2011
Author: sdlime
Date: 2011-02-24 20:56:20 -0800 (Thu, 24 Feb 2011)
New Revision: 11010
trunk/mapserver/mapwcs.h
trunk/mapserver/mapwcs20.c
Applied patch for #3687.
Modified: trunk/mapserver/mapwcs.h
--- trunk/mapserver/mapwcs.h 2011-02-25 04:53:48 UTC (rev 11009)
+++ trunk/mapserver/mapwcs.h 2011-02-25 04:56:20 UTC (rev 11010)
@@ -156,7 +156,7 @@
typedef struct
char *name; /* name of the axis */
- long size; /* pixelsize of the axis */
+ int size; /* pixelsize of the axis */
double resolution; /* resolution of the axis */
char *resolutionUOM; /* resolution units of measure */
wcs20SubsetObjPtr subset;
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c 2011-02-25 04:53:48 UTC (rev 11009)
+++ trunk/mapserver/mapwcs20.c 2011-02-25 04:56:20 UTC (rev 11010)
@@ -62,10 +62,10 @@
/* only if all characters could be parsed, MS_SUCCESS is returned. */
-static int msStringParseInteger(const char *string, long *dest)
+static int msStringParseInteger(const char *string, int *dest)
char *parse_check;
- *dest = strtol(string, &parse_check, 0);
+ *dest = (int)strtol(string, &parse_check, 0);
if(parse_check == string)
return MS_FAILURE;
@@ -562,7 +562,7 @@
*outAxis = string;
/* parse size value */
- if(msStringParseInteger(number, (long int *)outSize) != MS_SUCCESS)
+ if(msStringParseInteger(number, outSize) != MS_SUCCESS)
msSetError(MS_WCSERR, "Parameter value '%s' is not a valid integer.",
"msWCSParseSize20()", number);
More information about the mapserver-commits
