[mapserver-commits] r11011 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Feb 24 23:57:54 EST 2011
Author: sdlime
Date: 2011-02-24 20:57:54 -0800 (Thu, 24 Feb 2011)
New Revision: 11011
trunk/mapserver/mapwcs20.c
Applied patch for #3688.
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c 2011-02-25 04:56:20 UTC (rev 11010)
+++ trunk/mapserver/mapwcs20.c 2011-02-25 04:57:54 UTC (rev 11011)
@@ -3021,7 +3021,7 @@
/* is found out. */
-static int msWCSGetCoverage_FinalizeParamsObj20(wcs20ParamsObjPtr params)
+static int msWCSGetCoverage20_FinalizeParamsObj(wcs20ParamsObjPtr params)
int returnValue;
static const int numAxis = 2;
@@ -3202,7 +3202,7 @@
msInitProjection(&imageProj);
msLoadProjectionString(&imageProj, cm.srs);
- if(msWCSGetCoverage_FinalizeParamsObj20(params) == MS_FAILURE)
+ if(msWCSGetCoverage20_FinalizeParamsObj(params) == MS_FAILURE)
return msWCSException(map, "InvalidParameterValue", "extent", params->version);
@@ -3522,14 +3522,16 @@
if(params->multipart == MS_TRUE)
xmlDocPtr psDoc = NULL; /* document pointer */
- xmlNodePtr psRootNode, psRangeSet, psFile;
+ xmlNodePtr psRootNode, psRangeSet, psFile, psRangeParameters;
xmlNsPtr psGmlNs = NULL,
psGmlcovNs = NULL,
psSweNs = NULL,
psWcsNs = NULL,
psXLinkNs = NULL;
wcs20coverageMetadataObj tmpCm;
- char *srs_uri;
+ char *srs_uri, *filename, *default_filename;
+ char *file_ref;
+ int length = 0;
/* Create Document */
psDoc = xmlNewDoc(BAD_CAST "1.0");
@@ -3573,9 +3575,26 @@
psFile = xmlNewChild(psRangeSet, psGmlNs, BAD_CAST "File", NULL);
/* TODO: wait for updated specifications */
- xmlNewChild(psFile, psGmlNs, BAD_CAST "rangeParameters", NULL);
- xmlNewChild(psFile, psGmlNs, BAD_CAST "fileReference", BAD_CAST "file");
+ psRangeParameters = xmlNewChild(psFile, psGmlNs, BAD_CAST "rangeParameters", NULL);
+ default_filename = msStrdup("out.");
+ default_filename = msStringConcatenate(default_filename, MS_IMAGE_EXTENSION(image->format));
+ filename = msGetOutputFormatOption(image->format, "FILENAME", default_filename);
+ length = strlen("coverage/") + strlen(filename) + 1;
+ file_ref = msSmallMalloc(length);
+ strlcpy(file_ref, "coverage/", length);
+ strlcat(file_ref, filename, length);
+ msDebug("File reference: %s\n", file_ref);
+ xmlNewNsProp(psRangeParameters, psXLinkNs, BAD_CAST "href", BAD_CAST file_ref);
+ xmlNewNsProp(psRangeParameters, psXLinkNs, BAD_CAST "role", BAD_CAST MS_IMAGE_MIME_TYPE(map->outputformat));
+ xmlNewNsProp(psRangeParameters, psXLinkNs, BAD_CAST "arcrole", BAD_CAST "fileReference");
+ xmlNewChild(psFile, psGmlNs, BAD_CAST "fileReference", BAD_CAST file_ref);
xmlNewChild(psFile, psGmlNs, BAD_CAST "fileStructure", NULL);
+ xmlNewChild(psFile, psGmlNs, BAD_CAST "mimeType", BAD_CAST MS_IMAGE_MIME_TYPE(map->outputformat));
msWCSCommon20_CreateRangeType(layer, &cm, psGmlNs, psGmlcovNs, psSweNs, psXLinkNs, psRootNode);
More information about the mapserver-commits
