[mapserver-commits] r11026 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Feb 27 13:44:41 EST 2011
Author: sdlime
Date: 2011-02-27 10:44:41 -0800 (Sun, 27 Feb 2011)
New Revision: 11026
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maptemplate.c
Allow definition of nodata attribute for layers without results (via resultset tag). (#3701)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-02-26 23:00:57 UTC (rev 11025)
+++ trunk/mapserver/HISTORY.TXT 2011-02-27 18:44:41 UTC (rev 11026)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Allow definition of nodata attribute for layers without results (via resultset tag). (#3701)
- mapprojhack.c: restructure to avoid needing projects, or any internal
knowledge of PROJ.4.
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2011-02-26 23:00:57 UTC (rev 11025)
+++ trunk/mapserver/maptemplate.c 2011-02-27 18:44:41 UTC (rev 11026)
@@ -982,6 +982,7 @@
hashTableObj *tagArgs=NULL;
char *layerName=NULL;
+ char *nodata=NULL;
int layerIndex=-1;
layerObj *lp;
@@ -1003,6 +1004,7 @@
if(getTagArgs("resultset", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
if(tagArgs) {
layerName = msLookupHashTable(tagArgs, "layer");
+ nodata = msLookupHashTable(tagArgs, "nodata");
if(!layerName) {
@@ -1054,6 +1056,8 @@
if(processFeatureTag(mapserv, &tag, lp) != MS_SUCCESS)
return(MS_FAILURE); /* TODO: how to handle */
*line = msStringConcatenate(*line, tag);
+ } else if(nodata) {
+ *line = msStringConcatenate(*line, nodata);
*line = msStringConcatenate(*line, postTag);
More information about the mapserver-commits
