[mapserver-commits] r11027 - trunk/msautotest/query
Sun Feb 27 13:51:04 EST 2011
Author: sdlime
Date: 2011-02-27 10:51:04 -0800 (Sun, 27 Feb 2011)
New Revision: 11027
   trunk/msautotest/query/query.map
Cleaned up a comment. Trivial change...
Modified: trunk/msautotest/query/query.map
--- trunk/msautotest/query/query.map	2011-02-27 18:44:41 UTC (rev 11026)
+++ trunk/msautotest/query/query.map	2011-02-27 18:51:04 UTC (rev 11027)
@@ -9,7 +9,7 @@
 # Test 2: simple mode=nquery, multiple layers, rect-based
 # RUN_PARMS: query_test002.txt [MAPSERV] QUERY_STRING='map=[MAPFILE]&mode=nquery&mapext=420000+5120000+582000+5200000&layers=all'  > [RESULT_DEMIME]
-# Test 3: simple mode=nquery, one layer, point-based
+# Test 3: simple mode=query, one layer, point-based
 # RUN_PARMS: query_test003.txt [MAPSERV] QUERY_STRING='map=[MAPFILE]&mode=query&qlayer=bdry_counpy2&mapxy=467000+5259000' > [RESULT_DEMIME]
 # Test 4: simple mode=nquery, multiple layers, point-based
