[mapserver-commits] r10825 - in trunk/msautotest/query: . expected
svn at osgeo.org
svn at osgeo.org
Sun Jan 2 19:53:04 EST 2011
Author: sdlime
Date: 2011-01-02 16:53:04 -0800 (Sun, 02 Jan 2011)
New Revision: 10825
Added:
trunk/msautotest/query/expected/filters_test007.gif
trunk/msautotest/query/expected/filters_test008.gif
trunk/msautotest/query/filters.map
Added a couple of logical expressions with regex operators.
Added: trunk/msautotest/query/expected/filters_test007.gif
(Binary files differ)
Property changes on: trunk/msautotest/query/expected/filters_test007.gif
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/msautotest/query/expected/filters_test008.gif
Property changes on: trunk/msautotest/query/expected/filters_test008.gif
Modified: trunk/msautotest/query/filters.map
--- trunk/msautotest/query/filters.map 2011-01-02 23:08:37 UTC (rev 10824)
+++ trunk/msautotest/query/filters.map 2011-01-03 00:53:04 UTC (rev 10825)
@@ -9,6 +9,8 @@
# RUN_PARMS: filters_test004.gif [SHP2IMG] -m [MAPFILE] -l filters_test004 -o [RESULT]
# RUN_PARMS: filters_test005.gif [SHP2IMG] -m [MAPFILE] -l filters_test005 -o [RESULT]
# RUN_PARMS: filters_test006.gif [SHP2IMG] -m [MAPFILE] -l filters_test006 -o [RESULT]
+# RUN_PARMS: filters_test007.gif [SHP2IMG] -m [MAPFILE] -l filters_test007 -o [RESULT]
+# RUN_PARMS: filters_test008.gif [SHP2IMG] -m [MAPFILE] -l filters_test008 -o [RESULT]
MAP
NAME 'filters'
@@ -64,7 +66,21 @@
INCLUDE 'include/bdry_counpy2_shapefile.map'
END
+ # Logical expression, regex
LAYER
+ NAME 'filters_test007'
+ FILTER ('[CTY_NAME]' ~ '^A')
+ INCLUDE 'include/bdry_counpy2_shapefile.map'
+ END
+ # Logical expression, regex (case insensitive)
+ LAYER
+ NAME 'filters_test008'
+ FILTER ('[CTY_NAME]' ~* '^a')
+ END
+ LAYER
NAME 'bdry_counpy2'
TYPE LINE
DATA 'data/bdry_counpy2.shp'
More information about the mapserver-commits
