[mapserver-commits] r10826 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jan 3 00:28:27 EST 2011
Author: sdlime
Date: 2011-01-02 21:28:27 -0800 (Sun, 02 Jan 2011)
New Revision: 10826
trunk/mapserver/mapprimitive.c
trunk/mapserver/mapprimitive.h
trunk/mapserver/mapquery.c
trunk/mapserver/mapserver.h
Added result index to shapeObj and resultSetMemberObj in preparation for RFC 65. It looks to be safest to simply track a new index value and not re-purpose the tile index.
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c 2011-01-03 00:53:04 UTC (rev 10825)
+++ trunk/mapserver/mapprimitive.c 2011-01-03 05:28:27 UTC (rev 10826)
@@ -104,7 +104,7 @@
/* bookkeeping component */
shape->classindex = 0; /* default class */
- shape->tileindex = shape->index = -1;
+ shape->tileindex = shape->index = shape->resultindex = -1;
shape->scratch = MS_FALSE; /* not a temporary/scratch shape */
@@ -129,6 +129,7 @@
to->classindex = from->classindex;
to->index = from->index;
to->tileindex = from->tileindex;
+ to->resultindex = from->resultindex;
if(from->values) {
to->values = (char **)msSmallMalloc(sizeof(char *)*from->numvalues);
Modified: trunk/mapserver/mapprimitive.h
--- trunk/mapserver/mapprimitive.h 2011-01-03 00:53:04 UTC (rev 10825)
+++ trunk/mapserver/mapprimitive.h 2011-01-03 05:28:27 UTC (rev 10826)
@@ -88,6 +88,7 @@
char *text;
int scratch;
+ int resultindex; /* index within a query result set */
} shapeObj;
typedef lineObj multipointObj;
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2011-01-03 00:53:04 UTC (rev 10825)
+++ trunk/mapserver/mapquery.c 2011-01-03 05:28:27 UTC (rev 10826)
@@ -135,7 +135,7 @@
return MS_FALSE;
-static int addResult(resultCacheObj *cache, int classindex, int shapeindex, int tileindex)
+static int addResult(resultCacheObj *cache, shapeObj *shape)
int i;
@@ -153,11 +153,17 @@
i = cache->numresults;
- cache->results[i].classindex = classindex;
- cache->results[i].tileindex = tileindex;
- cache->results[i].shapeindex = shapeindex;
+ cache->results[i].classindex = shape->classindex;
+ cache->results[i].tileindex = shape->tileindex;
+ cache->results[i].shapeindex = shape->index;
+ cache->results[i].resultindex = shape->resultindex;
cache->numresults++;
+ if(cache->numresults == 1)
+ cache->bounds = shape->bounds;
+ else
+ msMergeRect(&(cache->bounds), &(shape->bounds));
return(MS_SUCCESS);
@@ -494,11 +500,7 @@
return(MS_FAILURE);
- addResult(lp->resultcache, shape.classindex, shape.index, shape.tileindex);
- if(lp->resultcache->numresults == 1)
- lp->resultcache->bounds = shape.bounds;
- else
- msMergeRect(&(lp->resultcache->bounds), &shape.bounds);
+ addResult(lp->resultcache, &shape);
msFreeShape(&shape);
/* msLayerClose(lp); */
@@ -654,13 +656,8 @@
lp->project = MS_FALSE;
#endif
- else
if(map->query.mode == MS_QUERY_SINGLE) { /* no need to look any further */
@@ -837,14 +834,8 @@
- if(status == MS_TRUE) {
- else
+ if(status == MS_TRUE)
} /* next shape */
@@ -1125,15 +1116,9 @@
break; /* should never get here as we test for selection shape type explicitly earlier */
- else
} /* next shape */
@@ -1315,15 +1300,10 @@
if( d <= t ) { /* found one */
lp->resultcache->numresults = 0;
t = d; /* next one must be closer */
} else {
- else
@@ -1574,14 +1554,8 @@
- else
} /* next shape */
@@ -1601,7 +1575,6 @@
return(MS_FAILURE);
/* msQueryByOperator */
@@ -1807,14 +1780,8 @@
return(MS_FAILURE);
- else
} /* next shape */
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2011-01-03 00:53:04 UTC (rev 10825)
+++ trunk/mapserver/mapserver.h 2011-01-03 05:28:27 UTC (rev 10826)
@@ -1080,6 +1080,7 @@
typedef struct {
long shapeindex;
int tileindex;
+ int resultindex;
int classindex;
} resultCacheMemberObj;
#ifdef SWIG
More information about the mapserver-commits
