[mapserver-commits] r10854 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jan 10 13:57:54 EST 2011
Author: assefa
Date: 2011-01-10 10:57:53 -0800 (Mon, 10 Jan 2011)
New Revision: 10854
trunk/mapserver/mapobject.c
trunk/mapserver/mapows.h
trunk/mapserver/mapwms.c
Correct exception parameter issue #3525
Modified: trunk/mapserver/mapobject.c
--- trunk/mapserver/mapobject.c 2011-01-10 18:11:40 UTC (rev 10853)
+++ trunk/mapserver/mapobject.c 2011-01-10 18:57:53 UTC (rev 10854)
@@ -804,10 +804,17 @@
#ifdef USE_WMS_SVR
int version;
+ char *wms_exception_format = NULL;
+ int i =0;
version = msOWSParseVersionString(wmtver);
+ for(i=0; i<request->NumParams; i++)
+ if (strcasecmp(request->ParamNames[i], "EXCEPTIONS") == 0)
+ wms_exception_format = request->ParamValues[i];
return msWMSLoadGetMapParams(map, version, request->ParamNames,
- request->ParamValues, request->NumParams);
+ request->ParamValues, request->NumParams, wms_exception_format);
#else
msSetError(MS_WMSERR, "WMS server support is not available.",
"msMapLoadOWSParameters()");
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h 2011-01-10 18:11:40 UTC (rev 10853)
+++ trunk/mapserver/mapows.h 2011-01-10 18:57:53 UTC (rev 10854)
@@ -425,7 +425,7 @@
int msWMSDispatch(mapObj *map, cgiRequestObj *req, int force_wms_mode);
MS_DLL_EXPORT int msWMSLoadGetMapParams(mapObj *map, int nVersion,
- char **names, char **values, int numentries);
+ char **names, char **values, int numentries, char *wms_exception_format);
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2011-01-10 18:11:40 UTC (rev 10853)
+++ trunk/mapserver/mapwms.c 2011-01-10 18:57:53 UTC (rev 10854)
@@ -65,9 +65,9 @@
** Report current MapServer error in requested format.
-static char *wms_exception_format=NULL;
-int msWMSException(mapObj *map, int nVersion, const char *exception_code)
+int msWMSException(mapObj *map, int nVersion, const char *exception_code,
+ char *wms_exception_format)
const char *encoding;
char *schemalocation = NULL;
@@ -277,7 +277,7 @@
** Apply the TIME parameter to layers that are time aware
-int msWMSApplyTime(mapObj *map, int version, char *time)
+int msWMSApplyTime(mapObj *map, int version, char *time, char *wms_exception_format)
int i=0;
layerObj *lp = NULL;
@@ -307,8 +307,7 @@
if (timedefault == NULL)
msSetError(MS_WMSERR, "No Time value was given, and no default time value defined.", "msWMSApplyTime");
- return msWMSException(map, version,
- "MissingDimensionValue");
+ return msWMSException(map, version, "MissingDimensionValue", wms_exception_format);
else
@@ -317,7 +316,7 @@
msSetError(MS_WMSERR, "No Time value was given, and the default time value %s is invalid or outside the time extent defined %s", "msWMSApplyTime", timedefault, timeextent);
/* return MS_FALSE; */
- "InvalidDimensionValue");
+ "InvalidDimensionValue", wms_exception_format);
msLayerSetTimeFilter(lp, timedefault, timefield);
@@ -332,7 +331,7 @@
msSetError(MS_WMSERR, "Time value(s) %s given is invalid or outside the time extent defined (%s).", "msWMSApplyTime", time, timeextent);
else
@@ -341,7 +340,7 @@
msSetError(MS_WMSERR, "Time value(s) %s given is invalid or outside the time extent defined (%s), and default time set is invalid (%s)", "msWMSApplyTime", time, timeextent, timedefault);
else
@@ -375,7 +374,7 @@
int i, adjust_extent = MS_FALSE, nonsquare_enabled = MS_FALSE;
int iUnits = -1;
@@ -411,12 +410,15 @@
epsgbuf[0]='\0';
srsbuffer[0]='\0';
/* Some of the getMap parameters are actually required depending on the */
/* request, but for now we assume all are optional and the map file */
/* defaults will apply. */
msAdjustExtent(&(map->extent), map->width, map->height);
for(i=0; map && i<numentries; i++)
/* getMap parameters */
@@ -426,6 +428,7 @@
request = values[i];
/* check if SLD is passed. If yes, check for OGR support */
if (strcasecmp(names[i], "SLD") == 0 || strcasecmp(names[i], "SLD_BODY") == 0)
@@ -437,7 +440,7 @@
if (ogrEnabled == 0)
msSetError(MS_WMSERR, "OGR support is not available.", "msWMSLoadGetMapParams()");
- return msWMSException(map, nVersion, NULL);
+ return msWMSException(map, nVersion, NULL, wms_exception_format);
else
@@ -446,12 +449,12 @@
if (strcasecmp(names[i], "SLD") == 0)
if ((status = msSLDApplySLDURL(map, values[i], -1, NULL)) != MS_SUCCESS)
if (strcasecmp(names[i], "SLD_BODY") == 0)
if ((status =msSLDApplySLD(map, values[i], -1, NULL)) != MS_SUCCESS)
@@ -468,7 +471,7 @@
if (layers==NULL || strlen(values[i]) <=0 || numlayers < 1) {
msSetError(MS_WMSERR, "At least one layer name required in LAYERS.",
if (nVersion >= OWS_1_3_0) {
@@ -477,7 +480,7 @@
if (numlayers > atoi(layerlimit)) {
msSetError(MS_WMSERR, "Number of layers requested exceeds LayerLimit.",
@@ -609,14 +612,14 @@
"Unsupported CRS namespace (only EPSG, AUTO2, CRS currently supported).",
- return msWMSException(map, nVersion, "InvalidCRS");
+ return msWMSException(map, nVersion, "InvalidCRS", wms_exception_format);
else
"Unsupported SRS namespace (only EPSG and AUTO currently supported).",
- return msWMSException(map, nVersion, "InvalidSRS");
+ return msWMSException(map, nVersion, "InvalidSRS", wms_exception_format);
@@ -628,7 +631,7 @@
if (tokens==NULL || n != 4) {
msSetError(MS_WMSERR, "Wrong number of arguments for BBOX.",
bboxrequest = values[i];
@@ -650,7 +653,7 @@
"Invalid values for BBOX.",
adjust_extent = MS_TRUE;
@@ -683,7 +686,7 @@
"Unsupported output format (%s).",
"msWMSLoadGetMapParams()",
values[i] );
- return msWMSException(map, nVersion, "InvalidFormat");
+ return msWMSException(map, nVersion, "InvalidFormat", wms_exception_format);
else
@@ -701,7 +704,7 @@
values[i] );
@@ -746,7 +749,7 @@
"Invalid format for the EXCEPTION parameter.",
if (bboxfound && bboxrequest && nVersion >= OWS_1_3_0)
@@ -811,7 +814,7 @@
@@ -840,7 +843,7 @@
if (timerequest)
- if (msWMSApplyTime(map, nVersion, stime) == MS_FAILURE)
+ if (msWMSApplyTime(map, nVersion, stime, wms_exception_format) == MS_FAILURE)
return MS_FAILURE;/* msWMSException(map, nVersion, "InvalidTimeRequest"); */
@@ -861,7 +864,7 @@
msSetError(MS_WMSERR, "Invalid layer(s) given in the LAYERS parameter.",
- return msWMSException(map, nVersion, "LayerNotDefined");
+ return msWMSException(map, nVersion, "LayerNotDefined", wms_exception_format);
/* validate srs value: When the SRS parameter in a GetMap request contains a
@@ -923,13 +926,13 @@
msSetError(MS_WMSERR, "Invalid CRS given : CRS must be valid for all requested layers.",
else
msSetError(MS_WMSERR, "Invalid SRS given : SRS must be valid for all requested layers.",
@@ -947,7 +950,7 @@
/* Restore valid default values in case errors INIMAGE are used */
map->width = 400;
map->height= 300;
/* Check whether requested BBOX and width/height result in non-square pixels
@@ -990,7 +993,7 @@
"have any projection set. Please make sure your mapfile "
"has a projection defined at the top level.",
else
@@ -998,7 +1001,7 @@
@@ -1014,7 +1017,7 @@
if (nTmp != 0)
msFreeProjection(&newProj);
@@ -1039,7 +1042,7 @@
original_srs) != 0)
GET_LAYER(map, i)->project = MS_TRUE;
@@ -1064,7 +1067,7 @@
nTmp = msLoadProjectionString(&(map->projection), srsbuffer);
if (nTmp != 0)
iUnits = GetMapserverUnitUsingProj(&(map->projection));
if (iUnits != -1)
@@ -1129,7 +1132,7 @@
msFreeCharArray(tokens, n);
msFreeCharArray(layers, numlayers);
- return msWMSException(map, nVersion, "StyleNotDefined");
+ return msWMSException(map, nVersion, "StyleNotDefined", wms_exception_format);
@@ -1143,7 +1146,7 @@
if (layers && numlayers > 0)
@@ -1178,31 +1181,31 @@
else
msSetError(MS_WMSERR, "Missing required parameter SRS", "msWMSLoadGetMapParams()");
- return msWMSException(map, nVersion, "MissingParameterValue");
+ return msWMSException(map, nVersion, "MissingParameterValue", wms_exception_format);
if (bboxfound == 0)
msSetError(MS_WMSERR, "Missing required parameter BBOX", "msWMSLoadGetMapParams()");
if (formatfound == 0 && (strcasecmp(request, "GetMap") == 0 || strcasecmp(request, "map") == 0))
msSetError(MS_WMSERR, "Missing required parameter FORMAT", "msWMSLoadGetMapParams()");
if (widthfound == 0)
msSetError(MS_WMSERR, "Missing required parameter WIDTH", "msWMSLoadGetMapParams()");
if (heightfound == 0)
msSetError(MS_WMSERR, "Missing required parameter HEIGHT", "msWMSLoadGetMapParams()");
@@ -1984,7 +1987,8 @@
** msWMSGetCapabilities()
-int msWMSGetCapabilities(mapObj *map, int nVersion, cgiRequestObj *req, const char *requested_updatesequence)
+int msWMSGetCapabilities(mapObj *map, int nVersion, cgiRequestObj *req, const char *requested_updatesequence,
char *dtd_url = NULL;
char *script_url=NULL, *script_url_encoded=NULL;
@@ -2014,11 +2018,11 @@
i = msOWSNegotiateUpdateSequence(requested_updatesequence, updatesequence);
if (i == 0) { /* current */
msSetError(MS_WMSERR, "UPDATESEQUENCE parameter (%s) is equal to server (%s)", "msWMSGetCapabilities()", requested_updatesequence, updatesequence);
- return msWMSException(map, nVersion, "CurrentUpdateSequence");
+ return msWMSException(map, nVersion, "CurrentUpdateSequence", wms_exception_format);
if (i > 0) { /* invalid */
msSetError(MS_WMSERR, "UPDATESEQUENCE parameter (%s) is higher than server (%s)", "msWMSGetCapabilities()", requested_updatesequence, updatesequence);
- return msWMSException(map, nVersion, "InvalidUpdateSequence");
+ return msWMSException(map, nVersion, "InvalidUpdateSequence", wms_exception_format);
@@ -2062,7 +2066,7 @@
if ((script_url=msOWSGetOnlineResource(map, "MO", "onlineresource", req)) == NULL ||
(script_url_encoded = msEncodeHTMLEntities(script_url)) == NULL)
if (nVersion <= OWS_1_0_7 || nVersion >= OWS_1_3_0) /* 1.0.0 to 1.0.7 and >=1.3.0*/
@@ -2697,7 +2701,8 @@
** msWMSGetMap()
-int msWMSGetMap(mapObj *map, int nVersion, char **names, char **values, int numentries)
+int msWMSGetMap(mapObj *map, int nVersion, char **names, char **values, int numentries,
imageObj *img;
int i = 0;
@@ -2778,7 +2783,7 @@
else
img = msDrawMap(map, MS_FALSE);
if (img == NULL)
/* Set the HTTP Cache-control headers if they are defined
in the map object */
@@ -2792,7 +2797,7 @@
msIO_printf("Content-type: %s%c%c",
MS_IMAGE_MIME_TYPE(map->outputformat), 10,10);
if (msSaveImage(map, img, NULL) != MS_SUCCESS)
msFreeImage(img);
@@ -2800,7 +2805,7 @@
return(MS_SUCCESS);
-int msDumpResult(mapObj *map, int bFormatHtml, int nVersion)
+int msDumpResult(mapObj *map, int bFormatHtml, int nVersion, char *wms_exception_format)
int numresults=0;
int i;
@@ -2873,7 +2878,7 @@
if (msLayerResultsGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex) != MS_SUCCESS)
msFree(itemvisible);
msIO_printf(" Feature %ld: \n", lp->resultcache->results[j].shapeindex);
@@ -2900,7 +2905,8 @@
** msWMSFeatureInfo()
-int msWMSFeatureInfo(mapObj *map, int nVersion, char **names, char **values, int numentries)
+int msWMSFeatureInfo(mapObj *map, int nVersion, char **names, char **values, int numentries,
int i, feature_count=1, numlayers_found=0;
pointObj point = {-1.0, -1.0};
@@ -2926,7 +2932,7 @@
layers = msStringSplit(values[i], ',', &numlayers);
if(layers==NULL || numlayers < 1 || strlen(msStringTrimLeft(values[i])) < 1) {
msSetError(MS_WMSERR, "At least one layer name required in QUERY_LAYERS.", "msWMSFeatureInfo()");
@@ -2981,12 +2987,12 @@
if (query_layer)
msSetError(MS_WMSERR, "Layer(s) specified in QUERY_LAYERS parameter is not offered by the service instance.", "msWMSFeatureInfo()");
else
msSetError(MS_WMSERR, "Required QUERY_LAYERS parameter missing for getFeatureInfo.", "msWMSFeatureInfo()");
@@ -3004,7 +3010,7 @@
if (GET_LAYER(map, i)->status == MS_ON && !msIsLayerQueryable(GET_LAYER(map, i)))
msSetError(MS_WMSERR, "Requested layer(s) are not queryable.", "msWMSFeatureInfo()");
- return msWMSException(map, nVersion, "LayerNotQueryable");
+ return msWMSException(map, nVersion, "LayerNotQueryable", wms_exception_format);
if(point.x == -1.0 || point.y == -1.0) {
@@ -3012,7 +3018,7 @@
msSetError(MS_WMSERR, "Required I/J parameters missing for getFeatureInfo.", "msWMSFeatureInfo()");
else
msSetError(MS_WMSERR, "Required X/Y parameters missing for getFeatureInfo.", "msWMSFeatureInfo()");
/*wms1.3.0: check if the points are valid*/
@@ -3021,7 +3027,7 @@
if (point.x > map->width || point.y > map->height)
msSetError(MS_WMSERR, "Invalid I/J values", "msWMSFeatureInfo()");
- return msWMSException(map, nVersion, "InvalidPoint");
+ return msWMSException(map, nVersion, "InvalidPoint", wms_exception_format);
/* Perform the actual query */
@@ -3044,7 +3050,7 @@
map->query.maxresults = feature_count;
if(msQueryByPoint(map) != MS_SUCCESS)
- if((query_status=ms_error->code) != MS_NOTFOUND) return msWMSException(map, nVersion, NULL);
+ if((query_status=ms_error->code) != MS_NOTFOUND) return msWMSException(map, nVersion, NULL, wms_exception_format);
/*validate the INFO_FORMAT*/
valid_format = MS_FALSE;
@@ -3081,9 +3087,9 @@
msSetError(MS_WMSERR, "Unsupported INFO_FORMAT value (%s).",
"msWMSFeatureInfo()", info_format);
else
/* Generate response */
@@ -3099,7 +3105,7 @@
msIO_printf("Content-type: text/plain%c%c",10,10);
msIO_printf("GetFeatureInfo results:\n");
- numresults = msDumpResult(map, 0, nVersion);
+ numresults = msDumpResult(map, 0, nVersion, wms_exception_format);
if (numresults == 0) msIO_printf("\n Search returned no results.\n");
@@ -3140,10 +3146,10 @@
if (query_status == MS_NOTFOUND && msObj->map->web.empty)
if(msReturnURL(msObj, msObj->map->web.empty, BROWSE) != MS_SUCCESS)
else if (msReturnTemplateQuery(msObj, (char *)info_format, NULL) != MS_SUCCESS)
/* We don't want to free the map, and param names/values since they */
/* belong to the caller, set them to NULL before freeing the mapservObj */
@@ -3162,7 +3168,7 @@
** msWMSDescribeLayer()
int msWMSDescribeLayer(mapObj *map, int nVersion, char **names,
- char **values, int numentries)
+ char **values, int numentries, char *wms_exception_format)
int i = 0;
char **layers = NULL;
@@ -3194,12 +3200,12 @@
if (nVersion >= OWS_1_3_0 && sld_version == NULL)
msSetError(MS_WMSERR, "Missing required parameter SLD_VERSION", "DescribeLayer()");
if (nVersion >= OWS_1_3_0 && strcasecmp(sld_version, "1.1.0") != 0)
msSetError(MS_WMSERR, "SLD_VERSION must be 1.1.0", "DescribeLayer()");
- return msWMSException(map, nVersion, "InvalidParameterValue");
+ return msWMSException(map, nVersion, "InvalidParameterValue", wms_exception_format);
if (encoding)
@@ -3365,7 +3371,7 @@
** msWMSGetLegendGraphic()
int msWMSGetLegendGraphic(mapObj *map, int nVersion, char **names,
char *pszLayer = NULL;
char *pszFormat = NULL;
@@ -3428,23 +3434,23 @@
if (!pszLayer)
msSetError(MS_WMSERR, "Mandatory LAYER parameter missing in GetLegendGraphic request.", "msWMSGetLegendGraphic()");
if (!pszFormat)
msSetError(MS_WMSERR, "Mandatory FORMAT parameter missing in GetLegendGraphic request.", "msWMSGetLegendGraphic()");
msSetError(MS_WMSERR, "Missing required parameter SLD_VERSION", "GetLegendGraphic()");
msSetError(MS_WMSERR, "SLD_VERSION must be 1.1.0", "GetLegendGraphic()");
/* check if layer name is valid. we cjeck for layer's and group's name*/
for (i=0; i<map->numlayers; i++)
@@ -3465,7 +3471,7 @@
msSetError(MS_WMSERR, "Invalid layer given in the LAYER parameter.",
/* validate format */
@@ -3482,7 +3488,7 @@
"msWMSGetLegendGraphic()",
pszFormat);
else
@@ -3497,7 +3503,7 @@
pszFormat);
msApplyOutputFormat(&(map->outputformat), psFormat, MS_NOOVERRIDE,
@@ -3519,7 +3525,7 @@
msSetError(MS_WMSERR, "style used in the STYLE parameter is not defined on the layer.",
else
@@ -3604,16 +3610,16 @@
"Unavailable RULE (%s).",
psRule);
- return msWMSException(map, nVersion, "InvalidRule");
+ return msWMSException(map, nVersion, "InvalidRule", wms_exception_format);
if (img == NULL)
msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(map->outputformat), 10,10);
msFreeImage(img);
@@ -3626,7 +3632,7 @@
** have a status set to on or default.
int msWMSGetStyles(mapObj *map, int nVersion, char **names,
int i,j,k;
@@ -3647,7 +3653,7 @@
if (layers==NULL || numlayers < 1) {
"msWMSGetStyles()");
for(j=0; j<map->numlayers; j++)
GET_LAYER(map, j)->status = MS_OFF;
@@ -3677,7 +3683,7 @@
if (nVersion <= OWS_1_1_1)
@@ -3751,6 +3757,7 @@
int i, status, nVersion=OWS_VERSION_NOTSET;
const char *version=NULL, *request=NULL, *service=NULL, *format=NULL, *updatesequence=NULL;
const char * encoding;
encoding = msOWSLookupMetadata(&(map->web.metadata), "MO", "encoding");
@@ -3785,7 +3792,7 @@
/* Invalid version format. msSetError() has been called by
* msOWSParseVersionString() and we return the error as an exception
- return msWMSException(map, OWS_VERSION_NOTSET, NULL);
+ return msWMSException(map, OWS_VERSION_NOTSET, NULL, wms_exception_format);
@@ -3800,7 +3807,7 @@
if (force_wms_mode)
msSetError(MS_WMSERR, "Required SERVICE parameter missing.", "msWMSDispatch");
- return msWMSException(map, nVersion, "ServiceNotDefined");
+ return msWMSException(map, nVersion, "ServiceNotDefined", wms_exception_format);
else
return MS_DONE;
@@ -3816,8 +3823,8 @@
if (nVersion == OWS_VERSION_NOTSET)
nVersion = OWS_1_3_0;/* VERSION is optional with getCapabilities only */
if ((status = msOWSMakeAllLayersUnique(map)) != MS_SUCCESS)
- return msWMSGetCapabilities(map, nVersion, req, updatesequence);
+ return msWMSGetCapabilities(map, nVersion, req, updatesequence, wms_exception_format);
else if (request && (strcasecmp(request, "context") == 0 ||
strcasecmp(request, "GetContext") == 0) )
@@ -3846,11 +3853,11 @@
msSetError(MS_WMSERR, "GetContext not enabled on this server.",
"msWMSDispatch()");
if (encoding)
msIO_printf("Content-type: text/xml; charset=%s%c%c", encoding,10,10);
@@ -3858,7 +3865,7 @@
msIO_printf("Content-type: text/xml%c%c",10,10);
if ( msWriteMapContext(map, stdout) != MS_SUCCESS )
/* Request completed */
return MS_SUCCESS;
@@ -3901,7 +3908,7 @@
"Incomplete WMS request: VERSION parameter missing",
"msWMSDispatch()");
if (request==NULL)
@@ -3909,17 +3916,19 @@
"Incomplete WMS request: REQUEST parameter missing",
"msWMSDispatch()");
if (strcasecmp(request, "GetLegendGraphic") == 0)
- return msWMSGetLegendGraphic(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams);
+ return msWMSGetLegendGraphic(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams,
+ wms_exception_format);
if (strcasecmp(request, "GetStyles") == 0)
- return msWMSGetStyles(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams);
+ return msWMSGetStyles(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams,
else if (request && strcasecmp(request, "GetSchemaExtension") == 0)
return msWMSGetSchemaExtension(map);
@@ -3928,25 +3937,27 @@
if (strcasecmp(request, "map") == 0 || strcasecmp(request, "GetMap") == 0 ||
strcasecmp(request, "feature_info") == 0 || strcasecmp(request, "GetFeatureInfo") == 0 || strcasecmp(request, "DescribeLayer") == 0)
- status = msWMSLoadGetMapParams(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams);
+ status = msWMSLoadGetMapParams(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams,
if (status != MS_SUCCESS) return status;
if (strcasecmp(request, "map") == 0 || strcasecmp(request, "GetMap") == 0)
- return msWMSGetMap(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams);
+ return msWMSGetMap(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams, wms_exception_format);
else if (strcasecmp(request, "feature_info") == 0 || strcasecmp(request, "GetFeatureInfo") == 0)
- return msWMSFeatureInfo(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams);
+ return msWMSFeatureInfo(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams, wms_exception_format);
else if (strcasecmp(request, "DescribeLayer") == 0)
- return msWMSDescribeLayer(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams);
+ return msWMSDescribeLayer(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams,
/* Hummmm... incomplete or unsupported WMS request */
if (service != NULL && strcasecmp(service, "WMS") == 0)
msSetError(MS_WMSERR, "Incomplete or unsupported WMS request", "msWMSDispatch()");
else
return MS_DONE; /* Not a WMS request */
More information about the mapserver-commits
