[mapserver-commits] r10855 - trunk/docs/en/development/rfc
svn at osgeo.org
svn at osgeo.org
Wed Jan 12 13:29:39 EST 2011
Author: aboudreault
Date: 2011-01-12 10:29:38 -0800 (Wed, 12 Jan 2011)
New Revision: 10855
Added:
trunk/docs/en/development/rfc/ms-rfc-66.txt
Added rfc 66
Added: trunk/docs/en/development/rfc/ms-rfc-66.txt
--- trunk/docs/en/development/rfc/ms-rfc-66.txt (rev 0)
+++ trunk/docs/en/development/rfc/ms-rfc-66.txt 2011-01-12 18:29:38 UTC (rev 10855)
@@ -0,0 +1,85 @@
+.. _rfc66:
+ MS RFC 66: Better handling of temporary files
+:Date: 2011-01-12
+:Author: Alan Boudreault (aboudreault at mapgears.com)
+:Author: Daniel Morissette (dmorissette at mapgears.com)
+:Last Edited: 2011-01-12
+:Status: Draft
+:Version: MapServer 6.0
+:Id: $Id: ms-rfc-63.txt 10711 2010-11-09 12:42:11Z dmorissette $
+Overview
+At the moment, we write some temporary files in the web-accessible
+IMAGEPATH directory, this was a poor practice but still okay for some uses
+in the past (such as writing CONNECTIONTYPE WMS and WFS responses while we
+process them), but as our need for temporary files increase, we need to
+ensure that temp files are handled in a proper and safer way.
+This is a proposal for a better handling of the temporary files. The goal
+of this RFC is to use memory for temporary files when available and to add
+the ability to configure the temporary path.
+Proposed Solution
+By default, the temporary files will be written in memory. This will only
+be available if MapServer is built with gdal/cpl, which has a virtual io
+support. This is more efficient than writing files on disk. The virtual
+file system interface approach will be based on the RFC 62 `CPL Services
+<http://mapserver.org/development/rfc/ms-rfc-62.html#use-of-cpl-services>`_
+implementation, which already uses memory files. If the memory cannot be
+used, the files will be written on the disk. The temporary path can be set
+by the two following ways:
+* The environment variable MS_TEMPPATH.
+* In the mapfile
+ WEB
+ TEMPPATH "/tmp/"
+ END
+If the temporary path is not set, the function will try the standard path
+depending on the OS. "/tmp/" for Linux/MAC and "C:/temp" for Windows. Most
+of the work will be to modify the msTmpFile function.
+Files affected
+* maputil.c: The msTmpFile function.
+* All files that call msTmpFile().
+Bug ID
+The ticket for RFC-66 (containing the implementation) can be found here.
+Ticket 3354_
+.. _3354: http://trac.osgeo.org/mapserver/ticket/3354
+References
+RFC 62 `CPL Services <http://mapserver.org/development/rfc/ms-rfc-62.html#use-of-cpl-services>`_
+Ticket 3570_
+.. _3570: http://trac.osgeo.org/mapserver/ticket/3570
+Voting history
+Not voted yet.
More information about the mapserver-commits
