[mapserver-commits] r11789 - branches/branch-6-0/docs/en/mapfile/symbology trunk/docs/en/mapfile/symbology
Tue Jun 7 07:22:57 EDT 2011
Author: havatv
Date: 2011-06-07 04:22:57 -0700 (Tue, 07 Jun 2011)
New Revision: 11789
   branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
   trunk/docs/en/mapfile/symbology/construction.txt
Fixed some inconsistencies in the symbol construction document (#3910)
Modified: branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-06-06 17:31:28 UTC (rev 11788)
+++ branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-06-07 11:22:57 UTC (rev 11789)
@@ -952,7 +952,6 @@
         SIZE 20.0
         ANGLE 30
         GAP -50
-        #OFFSET -5 -99
       END # STYLE
     END # CLASS
   END # LAYER
@@ -977,11 +976,7 @@
         COLOR 102 0 0
         SYMBOL "P"
         SIZE 20
-        #SIZE 70
         GAP -30
-        #OUTLINECOLOR 0 255 0
-        #WIDTH 4
-        #OFFSET -10 -99
       END # STYLE
     END # CLASS
   END # LAYER
@@ -1006,11 +1001,7 @@
         COLOR 102 0 0
         SYMBOL "o-flag-trans"
         SIZE 20
-        #SIZE 70
         GAP -30
-        #WIDTH 4
-        #OFFSET -10 -99
       END # STYLE
     END # CLASS
   END # LAYER
@@ -1351,9 +1342,11 @@
    |    END                         |    IMAGE "stern.png"                            |
    |    STYLE                       |    TRANSPARENT 8                                |
    |      SYMBOL "in_the_star"      |  END                                            |
-   |      COLOR 0 0 0               |                                                 |
-   |      OUTLINECOLOR 0 0 0        |.. image:: ../../images/star-symbol.png          |
-   |    END                         |   :align: left                                  |
+   |    END                         |                                                 |
+   |    STYLE                       |.. image:: ../../images/star-symbol.png          |
+   |      OUTLINECOLOR 0 0 0        |   :align: left                                  |
+   |      WIDTH 1                   |                                                 |
+   |    END                         |                                                 |
    |  END                           |                                                 |
@@ -1372,12 +1365,12 @@
    |  CLASS                         |  SYMBOL                                         |
    |    STYLE                       |    NAME "in_point1"                             |
    |      SYMBOL "in_point1"        |    TYPE PIXMAP                                  |
-   |      COLOR 0 0 0               |    IMAGE "flaeche1_1.png"                       |
-   |      OUTLINECOLOR 0 0 0        |    TRANSPARENT 13                               |
-   |    END                         |  END                                            |
-   |  END                           |                                                 |
-   |                                |.. image:: ../../images/dot-symbol.png           |
-   |                                |   :align: left                                  |
+   |    END                         |    IMAGE "flaeche1_1.png"                       |
+   |    STYLE                       |    TRANSPARENT 13                               |
+   |      OUTLINECOLOR 0 0 0        |  END                                            |
+   |      WIDTH 1                   |                                                 |
+   |    END                         |.. image:: ../../images/dot-symbol.png           |
+   |  END                           |   :align: left                                  |
 .. figure:: ../../images/diagonal-area-symbol.png
@@ -1398,9 +1391,11 @@
    |    END                         |    IMAGE "schraffur.png"                        |
    |    STYLE                       |    TRANSPARENT 2                                |
    |      SYMBOL "in_hatch"         |  END                                            |
-   |      COLOR 0 0 0               |                                                 |
-   |      OUTLINECOLOR 0 0 0        |.. image:: ../../images/hatch.png                |
+   |    END                         |                                                 |
+   |    STYLE                       |.. image:: ../../images/hatch.png                |
+   |      WIDTH 1                   |                                                 |
+   |    END                         |                                                 |
    |  END                           |                                                 |
@@ -1433,14 +1428,14 @@
 .. note::
-  For line vector line symbols (`FILL` off), if a width greater than 1
+  For vector line symbols (`FILL` off), if a width greater than 1
   is specified, the lines will grow to extend outside the original
   bounding box of the symbol.  The parts that are outside of the
   bounding box will be cut away.
 :ref:`style` ANGLE can be used for polygon fills, but will only rotate
-each individual symbol, not the pattern as a whole.  To generate
-rotated patterns is therefore quite demanding.
+each individual symbol, not the pattern as a whole.  It is therefore
+quite demanding to generate rotated patterns.
 Below you will find some examples of vector symbols used for polygon
 fills.  The polygon fill is accompanied by the vector symbol used
Modified: trunk/docs/en/mapfile/symbology/construction.txt
--- trunk/docs/en/mapfile/symbology/construction.txt	2011-06-06 17:31:28 UTC (rev 11788)
+++ trunk/docs/en/mapfile/symbology/construction.txt	2011-06-07 11:22:57 UTC (rev 11789)
@@ -952,7 +952,6 @@
         SIZE 20.0
         ANGLE 30
         GAP -50
-        #OFFSET -5 -99
       END # STYLE
     END # CLASS
   END # LAYER
         COLOR 102 0 0
         SYMBOL "P"
         SIZE 20
-        #SIZE 70
         GAP -30
-        #WIDTH 4
-        #OFFSET -10 -99
       END # STYLE
     END # CLASS
   END # LAYER
         COLOR 102 0 0
         SIZE 20
-        #SIZE 70
         GAP -30
-        #WIDTH 4
-        #OFFSET -10 -99
       END # STYLE
     END # CLASS
   END # LAYER
-   |      COLOR 0 0 0               |                                                 |
+   |    END                         |                                                 |
+   |      WIDTH 1                   |                                                 |
+   |    END                         |                                                 |
    |  END                           |                                                 |
    |  CLASS                         |  SYMBOL                                         |
-   |    END                         |  END                                            |
-   |  END                           |                                                 |
+   |      WIDTH 1                   |                                                 |
-   |      COLOR 0 0 0               |                                                 |
+   |    END                         |                                                 |
+   |      WIDTH 1                   |                                                 |
+   |    END                         |                                                 |
    |  END                           |                                                 |
 .. note::
