[mapserver-commits] r11790 - sandbox/inspire_soc2011/msautotest/wxs
svn at osgeo.org
svn at osgeo.org
Tue Jun 7 11:19:31 EDT 2011
Author: stefanl
Date: 2011-06-07 08:19:30 -0700 (Tue, 07 Jun 2011)
New Revision: 11790
Added:
sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
Removed:
sandbox/inspire_soc2011/msautotest/wxs/wms_inspire.map
tests using inspire enabled mapfiles
Deleted: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire.map 2011-06-07 11:22:57 UTC (rev 11789)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire.map 2011-06-07 15:19:30 UTC (rev 11790)
@@ -1 +0,0 @@
\ No newline at end of file
Added: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map (rev 0)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map 2011-06-07 15:19:30 UTC (rev 11790)
@@ -0,0 +1,118 @@
+# Test WMS
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
+# Tests for INSPIRE View Service using WMS 1.3.0 (based on wms_simple.map)
+# scenario 1 - reference to external inspire service metadata
+# Capabilities
+# RUN_PARMS: wms_inspire_scenario1_cap130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&LANGUAGE=ger" > [RESULT_DEVERSION] [RESULT_DEMIME]
+MAP
+NAME WMS_INSPIRE_SCENARIO1_TEST
+STATUS ON
+SIZE 400 300
+#EXTENT 2018000 -73300 3410396 647400
+#UNITS METERS
+EXTENT -67.5725 42 -58.9275 48.5
+UNITS DD
+IMAGECOLOR 255 255 255
+SHAPEPATH ./data
+SYMBOLSET etc/symbols.sym
+FONTSET etc/fonts.txt
+OUTPUTFORMAT
+ NAME GDPNG
+ DRIVER "GD/PNG"
+ MIMETYPE "image/png"
+# IMAGEMODE RGB
+ EXTENSION "png"
+END
+# Start of web interface definition
+WEB
+ IMAGEPATH "/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+ METADATA
+ "wms_inspire_capabilities" "url" #enables inspire using scenario 1
+ "wms_inspire_languages" "eng,ger"
+ "wms_metadataurl_href" "mymetadataurlhref"
+ "wms_metadataurl_format" "mymetadataurlformat"
+ "wms_title_eng" "mytitleeng" #localized (as example)
+ "wms_title_ger" "mytitleger" #localized (as example)
+ "wms_abstract" "myabstract" #not localized (as example)
+ "ows_updatesequence" "123"
+ "wms_onlineresource" "http://localhost/path/to/wms_simple?"
+ "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
+ "ows_schemas_location" "http://schemas.opengis.net"
+ "ows_keywordlist" "ogc,wms,mapserver"
+ "ows_service_onlineresource" "http://www.mapserver.org/"
+ "ows_fees" "conditions unknown" #value either "no conditions apply"|default "conditions unknown"|<specific conditions>
+ "ows_accessconstraints" "none" #value according ISO 19115 (MD_RestrictionCode codelist) or default "none"
+ "ows_addresstype" "postal"
+ "ows_address" "123 SomeRoad Road"
+ "ows_city" "Toronto"
+ "ows_stateorprovince" "Ontario"
+ "ows_postcode" "xxx-xxx"
+ "ows_country" "Canada"
+ "ows_contactelectronicmailaddress" "tomkralidis at xxxxxxx.xxx"
+ "ows_contactvoicetelephone" "+xx-xxx-xxx-xxxx"
+ "ows_contactfacsimiletelephone" "+xx-xxx-xxx-xxxx"
+ "ows_contactperson" "Tom Kralidis"
+ "ows_contactorganization" "MapServer" #responsible organisation
+ "ows_contactposition" "resourceProvider" #responsible organisation, value according "INSPIRE Metadata Regulation" (part D6)
+ "ows_rootlayer_title" "My Layers"
+ "ows_rootlayer_abstract" "These are my layers"
+ "ows_rootlayer_keywordlist" "layers,list"
+ "ows_layerlimit" "1"
+ "ows_enable_request" "*"
+ "wms_getmap_formatlist" "image/png,image/png; mode=24bit,image/jpeg,image/gif,image/png; mode=8bit,image/tiff"
+ END
+END
+PROJECTION
+ "init=epsg:4326"
+ #"init=./data/epsg2:42304"
+END
+# Start of layer definitions
+LAYER
+ NAME road
+ DATA road
+ TEMPLATE "ttt"
+ METADATA
+ "wms_title" "road"
+ "wms_description" "Roads of I.P.E."
+ "wms_srs" "EPSG:43204"
+ "gml_include_items" "all"
+ END
+ TYPE LINE
+ STATUS ON
+ PROJECTION
+ "init=./data/epsg2:42304"
+ END
+ DUMP TRUE
+ CLASSITEM "Name_e"
+ CLASS
+ NAME "Roads"
+ SYMBOL 0
+ COLOR 220 0 0
+ END
+END # Layer
+END # Map File
Added: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map (rev 0)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map 2011-06-07 15:19:30 UTC (rev 11790)
@@ -0,0 +1,122 @@
+# Test WMS
+# scenario 2 - embedded inspire service metadata
+# Capabilities
+# RUN_PARMS: wms_inspire_scenario2_cap130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&LANGUAGE=ger" > [RESULT_DEVERSION] [RESULT_DEMIME]
+MAP
+STATUS ON
+SIZE 400 300
+#UNITS METERS
+UNITS DD
+SHAPEPATH ./data
+OUTPUTFORMAT
+ NAME GDPNG
+ DRIVER "GD/PNG"
+# IMAGEMODE RGB
+ EXTENSION "png"
+END
+WEB
+ METADATA
+ "wms_inspire_capabilities" "embed" #enables inspire using scenario 2
+ "wms_inspire_languages" "eng,ger" #first default, values according ISO 639-2/B
+ "wms_inspire_keyword" "infoMapAccessService" #value according "classification of spatial data services"
+ "wms_inspire_temporal_reference" "2011-09-19" #date of last revision, value according YYYY-MM-DD
+ "wms_inspire_conformity" "not evaluated" #value either "conformant"|"not conformant"|default "not evaluated"
+ "wms_inspire_mpoc_name" "mympocname" #point of contact
+ "wms_inspire_mpoc_email" "mympocemail" #point of contact
+ "wms_inspire_metadatadate" "2011-09-19" #value according YYYY-MM-DD
+ END
+END
+PROJECTION
+ "init=epsg:4326"
+END
+LAYER
+ NAME road
+ DATA road
+ TEMPLATE "ttt"
+ METADATA
+ END
+ TYPE LINE
+ STATUS ON
+ PROJECTION
+ END
+ DUMP TRUE
+ CLASS
+ NAME "Roads"
+ SYMBOL 0
+ COLOR 220 0 0
+ END
+END # Layer
+END # Map File
More information about the mapserver-commits
