[mapserver-commits] r11806 - trunk/docs/en/output
Fri Jun 10 13:33:27 EDT 2011
Author: warmerdam
Date: 2011-06-10 10:33:26 -0700 (Fri, 10 Jun 2011)
New Revision: 11806
   trunk/docs/en/output/ogr_output.txt
Removed duplicate gml_include_items explanation.
Modified: trunk/docs/en/output/ogr_output.txt
--- trunk/docs/en/output/ogr_output.txt	2011-06-09 06:05:31 UTC (rev 11805)
+++ trunk/docs/en/output/ogr_output.txt	2011-06-10 17:33:26 UTC (rev 11806)
@@ -138,25 +138,6 @@
   The new default behaviour is to expose no attributes at all.
-**gml_include_items**
-  (Optional) A comma delimited list of items to include, or keyword
-  "all". As of MapServer 4.6, you can control how many attributes (fields) you expose
-  for your data layer with this metadata. The previous behaviour was simply to expose
-  all attributes all of the time. You can enable full exposure by using the keyword "all",
-  such as:
-    "gml_include_items" "all"
-  You can specify a list of attributes (fields) for partial exposure, such as:
-    "gml_include_items" "Name,ID"
-  The new default behaviour is to expose no attributes at all.
 **gml_[item name]_alias**
   (Optional) An alias for an attribute's name.  The resulting file will refer
   to this attribute by the alias.  Here is an example:
