[mapserver-commits] r11807 - in sandbox/inspire_soc2011: mapserver msautotest/wxs
Mon Jun 13 06:13:45 EDT 2011
Author: stefanl
Date: 2011-06-13 03:13:45 -0700 (Mon, 13 Jun 2011)
New Revision: 11807
   sandbox/inspire_soc2011/mapserver/mapows.c
   sandbox/inspire_soc2011/mapserver/mapows.h
   sandbox/inspire_soc2011/mapserver/mapwms.c
   sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
   sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
inspire view service metadata support (scenario1+2)
Modified: sandbox/inspire_soc2011/mapserver/mapows.c
--- sandbox/inspire_soc2011/mapserver/mapows.c	2011-06-10 17:33:26 UTC (rev 11806)
+++ sandbox/inspire_soc2011/mapserver/mapows.c	2011-06-13 10:13:45 UTC (rev 11807)
@@ -771,8 +771,8 @@
     if ( online_resource && validated_language &&
         msOWSLookupMetadata(&(map->web.metadata), namespaces, "inspire_languagesubstitution") ) {
         /* online_resource is already terminated, so we can simply add language=...& */
-    	/* but first we need to make sure that online_resource has enough capacity */
-    	online_resource = (char *)msSmallRealloc(online_resource, strlen(online_resource) + strlen(validated_language) +  11);
+        /* but first we need to make sure that online_resource has enough capacity */
+        online_resource = (char *)msSmallRealloc(online_resource, strlen(online_resource) + strlen(validated_language) +  11);
         strcat(online_resource, "language=");
         strcat(online_resource, validated_language);
         strcat(online_resource, "&");
@@ -845,16 +845,16 @@
   const char *inspire_languages = NULL;
   if (!msOWSLookupMetadata(&(map->web.metadata), "MO", "inspire_capabilities")) {
-	  *numitems = 0;
-	  return NULL;
+      *numitems = 0;
+      return NULL;
   inspire_languages = msOWSLookupMetadata(&(map->web.metadata), namespaces, "inspire_languages");
   if (inspire_languages && strlen(inspire_languages) > 0) {
-	  return msStringSplit(inspire_languages, ',', numitems);
+      return msStringSplit(inspire_languages, ',', numitems);
   } else {
-	  *numitems = 0;
-	  return NULL;
+      *numitems = 0;
+      return NULL;
@@ -879,11 +879,11 @@
   char *language = NULL;
   if( inspire_languages && num_items > 0 ) {
-	if ( !requested_language || !msStringInArray( requested_language, inspire_languages, num_items) ) {
-	  language = msStrdup(inspire_languages[0]);
-	} else {
-	  language = msStrdup(requested_language);
+    if ( !requested_language || !msStringInArray( requested_language, inspire_languages, num_items) ) {
+      language = msStrdup(inspire_languages[0]);
+    } else {
+      language = msStrdup(requested_language);
   msFreeCharArray(inspire_languages, num_items);
@@ -904,20 +904,20 @@
 ** Returns a status code; MS_NOERR if all ok, action_if_not_found otherwise
 int msOWSPrintInspireCommonExtendedCapabilities(FILE *stream, mapObj *map, const char *namespaces,
-		                                        int action_if_not_found, const char *tag_name,
-		                                        const char *validated_language, const int service) {
+                                                int action_if_not_found, const char *tag_name,
+                                                const char *validated_language, const int service) {
     int metadataStatus = 0;
     int languageStatus = 0;
-	msIO_fprintf(stream, "  <%s>\n", tag_name);
+    msIO_fprintf(stream, "  <%s>\n", tag_name);
-	metadataStatus = msOWSPrintInspireCommonMetadata(stream, map, namespaces, action_if_not_found);
-	languageStatus = msOWSPrintInspireCommonLanguages(stream, map, namespaces, action_if_not_found, validated_language);
+    metadataStatus = msOWSPrintInspireCommonMetadata(stream, map, namespaces, action_if_not_found);
+    languageStatus = msOWSPrintInspireCommonLanguages(stream, map, namespaces, action_if_not_found, validated_language);
-	msIO_fprintf(stream, "  </%s>\n", tag_name);
+    msIO_fprintf(stream, "  </%s>\n", tag_name);
-	return (metadataStatus != MS_NOERR) ? metadataStatus : languageStatus;
+    return (metadataStatus != MS_NOERR) ? metadataStatus : languageStatus;
 /* msOWSPrintInspireCommonMetadata
@@ -928,24 +928,53 @@
 int msOWSPrintInspireCommonMetadata(FILE *stream, mapObj *map, const char *namespaces,
                                        int action_if_not_found) {
-	int status = MS_NOERR;
-    /* Referencing a CSW only is the solution known as Scenario 1 */
-    if ( msOWSLookupMetadata(&(map->web.metadata), namespaces, "metadataurl_href") ) {
-      msIO_fprintf(stream, "    <inspire_common:MetadataUrl xsi:type=\"inspire_common:resourceLocatorType\">\n");
-      msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "metadataurl_href", OWS_WARN, "      <inspire_common:URL>%s</inspire_common:URL>\n", "");
-      msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "metadataurl_format", OWS_WARN, "      <inspire_common:MediaType>%s</inspire_common:MediaType>\n", "");
-      msIO_fprintf(stream, "    </inspire_common:MetadataUrl>\n");
-    } else if ( "embed" != msOWSLookupMetadata(&(map->web.metadata), namespaces, "inspire_capabilities") ) {
-      status = action_if_not_found;
-      if (OWS_WARN == action_if_not_found) {
-        msIO_fprintf(stream, "<!-- WARNING: Mandatory metadata '%s%s' was missing in this context. -->\n", (namespaces?"..._":""), "metadataurl_href");
+    int status = MS_NOERR;
+    const char *inspire_capabilities = NULL;
+    inspire_capabilities = msOWSLookupMetadata(&(map->web.metadata), namespaces, "inspire_capabilities");
+    if (strcasecmp("url",inspire_capabilities) == 0)
+        if ( msOWSLookupMetadata(&(map->web.metadata), namespaces, "metadataurl_href") != NULL )
+            msIO_fprintf(stream, "    <inspire_common:MetadataUrl xsi:type=\"inspire_common:resourceLocatorType\">\n");
+            msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "metadataurl_href", OWS_WARN, "      <inspire_common:URL>%s</inspire_common:URL>\n", "");
+            msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "metadataurl_format", OWS_WARN, "      <inspire_common:MediaType>%s</inspire_common:MediaType>\n", "");
+            msIO_fprintf(stream, "    </inspire_common:MetadataUrl>\n");
+        else
+            status = action_if_not_found;
+            if (OWS_WARN == action_if_not_found)
+                msIO_fprintf(stream, "<!-- WARNING: Mandatory metadata '%s%s' was missing in this context. -->\n", (namespaces?"..._":""), "metadataurl_href");
+    else if (strcasecmp("embed",inspire_capabilities) == 0)
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "onlineresource", OWS_NOERR, "      <inspire_common:ResourceLocator>        <inspire_common:URL>%s</inspire_common:URL>\n</inspire_common:ResourceLocator>\n", NULL);
+        msIO_fprintf(stream,"       <inspire_common:ResourceType>service</inspire_common:ResourceType>\n");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_temporal_reference", OWS_WARN, "      <inspire_common:TemporalReference>        <inspire_common:DateOfLastRevision>%s</inspire_common:DateOfLastRevision>\n</inspire_common:TemporalReference>\n", "");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_conformity", OWS_WARN, "      <inspire_common:Conformity>        <inspire_common:Degree>%s</inspire_common:Degree>\n</inspire_common:Conformity>\n", "");
+        msIO_fprintf(stream, "    <inspire_common:MetadataPointOfContact>\n");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_mpoc_name", OWS_WARN, "      <inspire_common:OrganisationName>%s</inspire_common:OrganisationName>\n", "");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_mpoc_email", OWS_WARN, "      <inspire_common:EmailAddress>%s</inspire_common:EmailAddress>\n", "");
+        msIO_fprintf(stream, "    </inspire_common:MetadataPointOfContact>\n");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_metadatadate", OWS_WARN, "      <inspire_common:MetadataDate>%s</inspire_common:MetadataDate>\n", "");
+        msIO_fprintf(stream,"       <inspire_common:SpatialDataServiceType>view</inspire_common:SpatialDataServiceType>\n");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_keyword", OWS_WARN, "      <inspire_common:Keyword xsi:type='inspire_common:classificationOfSpatialDataService'>        <inspire_common:KeywordValue>%s</inspire_common:KeywordValue>\n</inspire_common:Keyword>\n", "");
+    else
+            msIO_fprintf(stream, "<!-- WARNING: invalid value '%s' for 'inspire_capabilities', only 'embed' and 'url' are supported. -->\n", inspire_capabilities);
-    /* Including all required extension metadata is known as Scenario 2 */
-    /* TODO */
     return status;
@@ -956,13 +985,14 @@
 ** Returns a status code; MS_NOERR if all OK; action_if_not_found otherwise
 int msOWSPrintInspireCommonLanguages(FILE *stream, mapObj *map, const char *namespaces,
-							   int action_if_not_found, const char *validated_language) {
-	char *buffer = NULL; /* temp variable for malloced strings that will need freeing */
+                               int action_if_not_found, const char *validated_language) {
+    char *buffer = NULL; /* temp variable for malloced strings that will need freeing */
-	char *default_language = msOWSGetInspireLanguage(map, namespaces, NULL);
+    char *default_language = msOWSGetInspireLanguage(map, namespaces, NULL);
-    if(validated_language && default_language) {
+    if(validated_language && default_language)
       msIO_fprintf(stream, "    <inspire_common:SupportedLanguages>\n");
       msIO_fprintf(stream, "      <inspire_common:DefaultLanguage><inspire_common:Language>%s"
                            "</inspire_common:Language></inspire_common:DefaultLanguage>\n",
@@ -970,14 +1000,14 @@
       msFree(buffer);
       msOWSPrintEncodeMetadataList(stream, &(map->web.metadata), namespaces, "inspire_languages", NULL, NULL,
                                    "      <inspire_common:SupportedLanguage><inspire_common:Language>%s"
-                                   "</inspire_common:Language></inspire_common:SupportedLanguage>\n", NULL);
+                                   "</inspire_common:Language></inspire_common:SupportedLanguage>\n", default_language);
       msIO_fprintf(stream, "    </inspire_common:SupportedLanguages>\n");
       msIO_fprintf(stream, "    <inspire_common:ResponseLanguage><inspire_common:Language>%s"
                            "</inspire_common:Language></inspire_common:ResponseLanguage>\n", validated_language);
     } else {
-    	msIO_fprintf(stream, "<!-- WARNING: Mandatory metadata '%s%s' was missing in this context. -->\n", (namespaces?"..._":""), "inspire_languages");
+        msIO_fprintf(stream, "<!-- WARNING: Mandatory metadata '%s%s' was missing in this context. -->\n", (namespaces?"..._":""), "inspire_languages");
@@ -1503,11 +1533,11 @@
       keywords = msStringSplit(value, ',', &numkeywords);
       if(keywords && numkeywords > 0) {
         int kw;
-	    if(startTag) msIO_fprintf(stream, "%s", startTag);
-	    for(kw=0; kw<numkeywords; kw++)
+        if(startTag) msIO_fprintf(stream, "%s", startTag);
+        for(kw=0; kw<numkeywords; kw++)
             msIO_fprintf(stream, itemFormat, keywords[kw]);
-	    if(endTag) msIO_fprintf(stream, "%s", endTag);
-	    msFreeCharArray(keywords, numkeywords);
+        if(endTag) msIO_fprintf(stream, "%s", endTag);
+        msFreeCharArray(keywords, numkeywords);
       return MS_TRUE;
@@ -1518,6 +1548,9 @@
 ** Prints comma-separated lists metadata.  (e.g. keywordList)
 ** This will print HTML encoded values.
+** default_value serves 2 purposes if specified:
+** - won't be printed if part of MetadataList (exclusion)
+** - will be printed if MetadataList is empty (fallback)
 int msOWSPrintEncodeMetadataList(FILE *stream, hashTableObj *metadata,
                                  const char *namespaces, const char *name,
@@ -1527,24 +1560,36 @@
     const char *value;
     char *encoded;
-    if((value = msOWSLookupMetadata(metadata, namespaces, name)) ||
-       (value = default_value) != NULL )
+    value = msOWSLookupMetadata(metadata, namespaces, name);
+    if(value == NULL)
+        value = default_value;
+        default_value = NULL;
+    if(value != NULL)
       char **keywords;
       int numkeywords;
         int kw;
+                if (default_value != NULL
+                    && strcasecmp(keywords[kw],default_value) == 0)
+                    continue;
                 encoded = msEncodeHTMLEntities(keywords[kw]);
                 msIO_fprintf(stream, itemFormat, encoded);
                 msFree(encoded);
       return MS_TRUE;
@@ -1690,7 +1735,7 @@
                            int wms_version)
-  const char	*value, *resx, *resy, *wms_bbox_extended, *epsg_str;
+  const char    *value, *resx, *resy, *wms_bbox_extended, *epsg_str;
   char *encoded, *encoded_resx, *encoded_resy;
   char **epsgs;
   int i, num_epsgs;
Modified: sandbox/inspire_soc2011/mapserver/mapows.h
--- sandbox/inspire_soc2011/mapserver/mapows.h	2011-06-10 17:33:26 UTC (rev 11806)
+++ sandbox/inspire_soc2011/mapserver/mapows.h	2011-06-13 10:13:45 UTC (rev 11807)
@@ -173,12 +173,12 @@
 #define OWS_WFS     2
 MS_DLL_EXPORT int msOWSPrintInspireCommonExtendedCapabilities(FILE *stream, mapObj *map, const char *namespaces,
-		                                        const int action_if_not_found, const char *tag_name,
-		                                        const char *validated_language, const int service);
+                                                const int action_if_not_found, const char *tag_name,
+                                                const char *validated_language, const int service);
                                        int action_if_not_found);
-							   int action_if_not_found, const char *validated_language);
+                               int action_if_not_found, const char *validated_language);
 MS_DLL_EXPORT int msOWSPrintMetadata(FILE *stream, hashTableObj *metadata,
@@ -348,9 +348,9 @@
 } gmlGroupListObj;
 typedef struct {
-	char *prefix;
-	char *uri;
-	char *schemalocation;
+    char *prefix;
+    char *uri;
+    char *schemalocation;
 } gmlNamespaceObj;
 typedef struct {
Modified: sandbox/inspire_soc2011/mapserver/mapwms.c
--- sandbox/inspire_soc2011/mapserver/mapwms.c	2011-06-10 17:33:26 UTC (rev 11806)
+++ sandbox/inspire_soc2011/mapserver/mapwms.c	2011-06-13 10:13:45 UTC (rev 11807)
@@ -1176,7 +1176,7 @@
   if( adjust_extent )
-      double	dx, dy;
+      double    dx, dy;
       dx = (map->extent.maxx - map->extent.minx) / map->width;
       map->extent.minx += dx*0.5;
@@ -1947,7 +1947,7 @@
  * -numNestedGroups: This array holds the number of nested groups for each layer   *
 void msWMSPrintNestedGroups(mapObj* map, int nVersion, char* pabLayerProcessed,
-	int index, int level, char*** nestedGroups, int* numNestedGroups, const char *script_url_encoded, const char *validated_language)
+    int index, int level, char*** nestedGroups, int* numNestedGroups, const char *script_url_encoded, const char *validated_language)
    int j;
@@ -2083,7 +2083,7 @@
   if ((script_url=msOWSGetOnlineResource2(map, "MO", "onlineresource", req, validated_language)) == NULL ||
       (script_url_encoded = msEncodeHTMLEntities(script_url)) == NULL)
-	  msFree(validated_language);
+      msFree(validated_language);
       return msWMSException(map, nVersion, NULL, wms_exception_format);
@@ -2967,7 +2967,7 @@
         continue;
       /* if(msLayerOpen(lp) != MS_SUCCESS || msLayerGetItems(lp) != MS_SUCCESS)
-	   return msWMSException(map, nVersion, NULL); */
+       return msWMSException(map, nVersion, NULL); */
       /* Use metadata to control which fields to output. We use the same
        * metadata names as for GML:
@@ -3081,7 +3081,7 @@
       for(j=0; j<map->numlayers; j++) {
         /* Force all layers OFF by default */
-	GET_LAYER(map, j)->status = MS_OFF;
+    GET_LAYER(map, j)->status = MS_OFF;
         for(k=0; k<numlayers; k++) {
          if (((GET_LAYER(map, j)->name && strcasecmp(GET_LAYER(map, j)->name, layers[k]) == 0) ||
               (map->name && strcasecmp(map->name, layers[k]) == 0) ||
Modified: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map	2011-06-10 17:33:26 UTC (rev 11806)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario1.map	2011-06-13 10:13:45 UTC (rev 11807)
@@ -27,7 +27,7 @@
  NAME GDPNG
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
-#IMAGEMODE RGB
+ #IMAGEMODE RGB
  EXTENSION "png"
 END
@@ -42,35 +42,37 @@
  METADATA
   "wms_inspire_capabilities" "url"                          #enables inspire using scenario 1
   "wms_inspire_languages" "eng,ger"                         #first default, values according ISO 639-2/B
-  "wms_metadataurl_href" "mymetadataurlhref"
-  "wms_metadataurl_format" "mymetadataurlformat"
+  "wms_metadataurl_href" "http://inspire.service/metadata"
+  "wms_metadataurl_format" "inspire.service.format"
+  "wms_inspire_keyword" "infoMapAccessService"              #value according "classification of spatial data services"
   "wms_title_eng" "Transport networks: Road Area"
   "wms_title_ger" "Verkehrsnetze: Straßenfläche"
   "wms_abstract" "myabstract"                               #to test fallback
   "wms_abstract_ger" "myabstractger"
   #"wms_onlineresource" "http://localhost/path/to/wms_inspire_scenario1"
-  "ows_updatesequence" "123"
+  "ows_updatesequence" "myupdatesequence"
   "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
   "ows_schemas_location" "http://schemas.opengis.net"
-  "ows_keywordlist" "ogc,wms,mapserver"
+  "ows_keywordlist" "mykeyword1,mykeyword2"
   "ows_service_onlineresource" "http://www.mapserver.org/"
   "ows_fees" "conditions unknown"                           #value either "no conditions apply"|default "conditions unknown"|<specific conditions>
   "ows_accessconstraints" "None"                            #value according ISO 19115 (MD_RestrictionCode codelist) or default "None"
-  "ows_addresstype" "postal"
-  "ows_address" "123 SomeRoad Road"
-  "ows_city" "Toronto"
-  "ows_stateorprovince" "Ontario"
+  "ows_addresstype" "myaddresstype"
+  "ows_address" "myaddress"
+  "ows_city" "mycity"
+  "ows_stateorprovince" "mystateorprovince"
   "ows_postcode" "xxx-xxx"
-  "ows_country" "Canada"
-  "ows_contactelectronicmailaddress" "tomkralidis at xxxxxxx.xxx"
+  "ows_country" "mycountry"
+  "ows_contactelectronicmailaddress" "mycontactelectronicmailaddress at xxxxxxx.xxx"
   "ows_contactvoicetelephone" "+xx-xxx-xxx-xxxx"
   "ows_contactfacsimiletelephone" "+xx-xxx-xxx-xxxx"
-  "ows_contactperson" "Tom Kralidis"
+  "ows_contactperson" "mycontactperson"
   "ows_contactorganization" "MapServer"                     #responsible organisation
   "ows_contactposition" "owner"                             #responsible organisation, value according "INSPIRE Metadata Regulation" (part D6)
-  "ows_rootlayer_title" "My Layers"
-  "ows_rootlayer_abstract" "These are my layers"
-  "ows_rootlayer_keywordlist" "layers,list"
+  "ows_rootlayer_title" "myrootlayertitle"
+  "ows_rootlayer_abstract" "myrootlayerabstract"            #to test fallback
+  "ows_rootlayer_abstract_ger" "myrootlayerabstract"
+  "ows_rootlayer_keywordlist" "myrootlayerkeyword1,myrootlayerkeyword2"
   "ows_layerlimit" "1"
   "ows_enable_request" "*"
   "wms_getmap_formatlist" "image/png,image/png; mode=24bit,image/jpeg,image/gif,image/png; mode=8bit,image/tiff"
@@ -78,7 +80,8 @@
 END
 PROJECTION
- "init=epsg:4326"
+ #"init=epsg:4326"
+ "init=/home/leopolds/MapServer_SoC_2011/msautotest/wxs/data/epsg2:42304"
 END
@@ -100,7 +103,8 @@
  TYPE LINE
  STATUS ON
  PROJECTION
-  "init=epsg:4326"
+  #"init=epsg:4326"
  END
  DUMP TRUE
Modified: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map	2011-06-10 17:33:26 UTC (rev 11806)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map	2011-06-13 10:13:45 UTC (rev 11807)
@@ -27,7 +27,7 @@
  NAME GDPNG
  DRIVER "GD/PNG"
-#IMAGEMODE RGB
+ #IMAGEMODE RGB
  EXTENSION "png"
 END
@@ -42,39 +42,40 @@
  METADATA
   "wms_inspire_capabilities" "embed"                        #enables inspire using scenario 2
-  "wms_inspire_keyword" "infoMapAccessService"              #value according "classification of spatial data services"
   "wms_inspire_temporal_reference" "2011-09-19"             #date of last revision, value according YYYY-MM-DD
   "wms_inspire_conformity" "not evaluated"                  #value either "conformant"|"not conformant"|default "not evaluated"
   "wms_inspire_mpoc_name" "mympocname"                      #point of contact
   "wms_inspire_mpoc_email" "mympocemail"                    #point of contact
   "wms_inspire_metadatadate" "2011-09-19"                   #value according YYYY-MM-DD
   #"wms_onlineresource" "http://localhost/path/to/wms_inspire_scenario2"
@@ -82,7 +83,8 @@
 END
 PROJECTION
- "init=epsg:4326"
+ #"init=epsg:4326"
 END
@@ -104,7 +106,8 @@
  TYPE LINE
  STATUS ON
  PROJECTION
-  "init=epsg:4326"
+  #"init=epsg:4326"
  END
  DUMP TRUE
