[mapserver-commits] r11808 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jun 13 11:21:42 EDT 2011
Author: aboudreault
Date: 2011-06-13 08:21:42 -0700 (Mon, 13 Jun 2011)
New Revision: 11808
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapfile.c
trunk/mapserver/mapogr.cpp
Fixed Using STYLEITEM AUTO, loadExpression fails when the label text contains a space or begins with a double quote (#3481)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-06-13 10:13:45 UTC (rev 11807)
+++ trunk/mapserver/HISTORY.TXT 2011-06-13 15:21:42 UTC (rev 11808)
@@ -15,6 +15,9 @@
Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Fixed Using STYLEITEM AUTO, loadExpression fails when the label text
+ contains a space or begins with a double quote (#3481)
- Fix for the cluster processing if the shape bounds doesn't overlap
with the given extent (#3913)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2011-06-13 10:13:45 UTC (rev 11807)
+++ trunk/mapserver/mapfile.c 2011-06-13 15:21:42 UTC (rev 11808)
@@ -2118,10 +2118,7 @@
} else {
msResetErrorList(); /* failure above is not really an error since we'll consider anything not matching (like an unquoted number) as a STRING) */
exp->type = MS_STRING;
- if((strlen(value) - strlen(msyystring_buffer)) == 2)
- exp->string = msStrdup(msyystring_buffer); /* value was quoted */
- else
- exp->string = msStrdup(value); /* use the whole value */
+ exp->string = msStrdup(msyystring_buffer);
return(0);
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp 2011-06-13 10:13:45 UTC (rev 11807)
+++ trunk/mapserver/mapogr.cpp 2011-06-13 15:21:42 UTC (rev 11808)
@@ -2913,11 +2913,10 @@
const char *labelTextString = OGR_ST_GetParamStr(hLabelStyle,
OGRSTLabelTextString,
&bIsNull);
- if (labelTextString && isalnum(labelTextString[0]))
- msLoadExpressionString(&(c->text), (char*)labelTextString);
- else
- (char*)CPLSPrintf("\"%s\"", (char*)labelTextString));
+ char *escapedTextString = msStringEscape((char*)labelTextString);
+ msLoadExpressionString(&(c->text),
+ (char*)CPLSPrintf("\"%s\"", escapedTextString));
+ free(escapedTextString);
c->label.angle = OGR_ST_GetParamDbl(hLabelStyle,
OGRSTLabelAngle, &bIsNull);
@@ -3042,11 +3041,10 @@
/* See bug 3481 about the isalnum hack */
const char *labelTextString = poLabelStyle->TextString(bIsNull);
- else
c->label.angle = poLabelStyle->Angle(bIsNull);
More information about the mapserver-commits
