[mapserver-commits] r11815 - in trunk/docs/zh_cn: . include
Tue Jun 14 10:16:06 EDT 2011
Author: wbprime
Date: 2011-06-14 07:16:06 -0700 (Tue, 14 Jun 2011)
New Revision: 11815
Added:
   trunk/docs/zh_cn/MIGRATION_GUIDE.txt
   trunk/docs/zh_cn/documentation.txt
   trunk/docs/zh_cn/download.txt
   trunk/docs/zh_cn/include/docnav.inc
add MIGRATION_GUIDE.txt
Added: trunk/docs/zh_cn/MIGRATION_GUIDE.txt
--- trunk/docs/zh_cn/MIGRATION_GUIDE.txt	                        (rev 0)
+++ trunk/docs/zh_cn/MIGRATION_GUIDE.txt	2011-06-14 14:16:06 UTC (rev 11815)
@@ -0,0 +1,761 @@
+.. _migration:
+MapServer Migration Guide
+:Last Updated: 2011-05-04
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+MapServer 5.6 to 6.0 Migration
+This section documents the changes that must be made to MapServer
+applications when migrating from version 5.6.x (or earlier versions)
+to 6.0 (i.e. backwards incompatibilities), as well as information
+on some of the new features.
+Mapfile Changes - Expression Parsing
+Version 6.0 features an extensive reworking of the expression parsing capabilities.
+While this adds functionality it also introduces a couple of regressions:
+Logical Expressions
+* a regex is now deliniated as a string (e.g. '^a' rather than /^a/)
+* the regex operator is ~ for case sensitive comparisons and ~* for case insensitive
+* case insensitive string comparison operator is =*
+Class text expressions are true expressions in 6.0. This allows for fancy formatting
+of numeric data but also means string operators must be used to concatenate attribute
+values and string literals.
+* Old/bad: TEXT ([area] acres)
+* New (option 1)/good: TEXT ([area] + ' acres')
+* New (option 2)/good: TEXT '[area] acres'
+On the plus side you can now control the number of decimal places, round and even commify
+the area value for annotion.
+See http://mapserver.org/development/rfc/ms-rfc-64.html and http://trac.osgeo.org/mapserver/ticket/3736
+for more information.
+Mapfile Changes	- Label Styles
+As the need for more and more control of label drawing increased it became apparent that
+we couldn't extend labelObj's endlessly. In 6.0 we introduce the idea of label styles, that
+is, a styleObj inside a labelObj. The styles can be used to add accompanying markers or
+bounding box elements to a label- kinda like annotation layers. The big benefit is that
+it's done in one pass. So you can draw complex roadwork and shields all at the same time.
+Pretty neat huh? Plus you can do attribute binding for any of the styleObj attributes that
+support it.
+As a result the parameters BACKGROUNDCOLOR, BACKGROUNDSHADOWCOLOR, BACKGROUNDSHADOWSIZE
+are no more. To draw a label "box" in 6.0 you'd do:
+  LABEL
+    STYLE # a shadow
+      GEOMTRANSFORM 'labelpoly'
+      COLOR 222 222 222
+      OFFSET 2 2
+    END
+    STYLE # bbox
+      COLOR 255 255 255
+      OUTLINECOLOR 0 0 0
+    END
+  END
+More verbose but *much* more flexible in the long run.
+Mapfile Changes - Label MAXOVERLAPANGLE
+:ref:`RFC60` introduced a new MAXOVERLAPANGLE keyword to filter out ANGLE
+FOLLOW labels in which characters overlap. This new option is enabled by
+default in 6.0 with a default value for MAXOVERLAPANGLE of 22.5 degrees.
+As per :ref:`RFC60`, it is possible to set MAXOVERLAPANGLE to 0 to fall back
+on pre-6.0 behavior which was to use hardcoded maxoverlapangle = 0.4*MS_PI
+(40% of 180 degrees = 72 degrees).
+Core Changes - Rendering Overhaul
+The rendering backends for MapServer have been refactored for version 6 to
+allow us to support all features across all rendering drivers (GD,AGG,PDF,SVG, etc...).
+* PDF support is output through the cairo library. The dependency on the non-free
+  pdflib library has been removed.
+* SVG support is output through the cairo library. The native mapserver SVG driver
+  has been removed.
+* AGG support is compiled in by default (no external dependency) and is the
+  default renderer for png and jpeg outputs.
+* GD support is limited to PC256 imagemodes, i.e. png or gif. It is the default
+  renderer for gif output.
+* SWF (flash) support has been dropped.
+* Header files for libpng, libjpeg and giflib are now required for building MapServer.
+  Install the -devel packages of these libraries.
+* All symbols now rotated anticlockwise following the ANGLE parameter. Previous versions
+  rotated vector symbols clockwise.
+* Polygon fills with vector symbols will not cleanly join at tile boundaries. For hatching
+  type symbology, use the HATCH symbol instead of a diagonal vector symbol.
+* Some inconsistencies between renderers have been ironed out. People relying on precise
+  symbol placement should check those, as there may have been some subtle changes in symbol
+  sizes and widths, or spacing between symbols on lines.
+* Style blocks with no associated symbol on point layers will produce no output, as opposed
+  to a single pixel in previous versions. Use an ellipse symbol instead.
+Mapfile Changes - line styling
+All line styling must now be specified in layer STYLEs.
+The following parameters/keywords have been moved from SYMBOL
+to STYLE:
+PATTERN POSITION GAP LINECAP LINEJOIN LINEJOINMAXSIZE
+The SYMBOL STYLE parameter/keyword was renamed to PATTERN in
+version 5.
+The SYMBOL TYPE cartoline has been removed.
+LINECAP triangle is not supported by AGG or Cairo, and is no longer
+available.  The triangle line end effect can be achieved using
+GEOMTRANSFORM start and end with a (filled) vector triangle symbol and
+ANGLE AUTO.  This will only work for the line ends, and not for
+dashes.
+CGI Changes
+Runtime subsitution now *requires* a validation pattern be present before the
+substitution will take place (this had been optional). This can be done via
+a layer metadata tag as before or within layer or web VALIDATION blocks. See
+ticket #3522 for more information.
+All of the query map related modes (e.g. NQUERYMAP, ITEMQUERYMAP, etc...) have
+been removed in favor of using the "qformat" parameter. That parameter takes
+an output format name or mime/type as a value and uses that to process a set
+of query results. For example:
+  ...&mode=nquerymap&... would become ...&mode=nquery&qformat=png24&...
+OGC Web Services
+All OGC Web Services are now disabled by default. If you want to enable them as
+they were in MapServer 5.6 and older releases, add the following metadata in the
+MAP::WEB section::
+ "ows_enable_request"   "*"
+See also: http://mapserver.org/development/rfc/ms-rfc-67.html
+Mapfile Changes - WCS Metadata
+To avoid confusion only "wcs_*" and "ows_*" prefixed metadata entries
+are evaluated in OGC WCS services. Previous versions used "wms_*"
+prefixed entries as fallback which is dropped in version 6.0 in favor of
+forcing explicit decisions.
+Mapfile Changes - Ability to escape single/double quotes
+We can now escape single and double quotes in strings and logical
+expressions. Examples:
+  NAME "RO\"AD" # double quote inside a a double quote delimited string
+  NAME 'RO\'AD' # single quote inside a a single quote delimited string
+  FILTER ('[CTY_NAME]' = 'Ita\'sca') # logical expression that contains a single quote
+NOTE: The escape character (backslash) will only work if the
+following character is ", ' or \.
+For Windows users: if you have a path string delimited by single/double
+quotes that ends with \, you will have to escape the last backslash.
+  SHAPEPATH "C:\ms4w\shapefiles\"
+  # should be modified to...
+  SHAPEPATH "C:\ms4w\shapefiles\\"
+PHP MapScript Changes
+* PHP 5.2.0 or more recent is required.
+* PHP/MapScript now uses exceptions for error report. All errors are catchable.
+* Object properties can be set like all other php object. ie. myObj->myProperty = 10;
+  NOTE: The set/setProperty methods are still available.
+* All object constructors throw an exception on failure
+* Objects can be created with the php "new" operator. ie.
+  $myShape = ms_newShapeObj(MS_SHAPE_LINE); // or
+  $myShape = new shapeObj(MS_SHAPE_LINE);
+  NOTE: "ms_newSymbolObj()" and "new symbolObj" are different:
+        - ms_newSymbolObj() returns the id of the new/existing symbol.
+        - new symbolObj() returns the symbolObj. You don't need to
+                          get it with getSymbolObjectById().
+* Cloneable objects should be cloned with the PHP clone keyword. There is no more clone methods.
+* Class properties that have been removed
+  - mapObj: imagetype, imagequality, interlace, scale, transparent
+  - classObj: maxscale, minscale
+  - layerObj: labelsizeitem, labelangleitem, labelmaxscale, labelminscale,
+              maxscale, minscale, symbolscale, transparency
+  - legendObj: interlace, transparent
+  - scalebarObj: interlace, transparent
+  - symbolObj: gap, stylelength
+  - webObj: minscale, maxscale
+* Class methods that have been removed
+  - projectionObj: free
+  - lineObj: free
+  - pointObj: free
+  - rectObj: free
+  - shapeObj: free, union_geos
+  - symbolObj: free, getstylearray
+  - imageObj: free
+  - outputFormatObj: getformatoption, setformatoption
+  - shapefileObj: free
+  - layerObj: getFilter, getShape
+* referenceMapObj has new properties: marker, markername, markersize, maxboxsize, minboxsize
+* shapeFileObj is automatically closed/writed on destroy. (At the end of the script or with an explicit unset())
+* layerObj->clearProcessing() method now returns void.
+* mapObj->queryByIndex(): default behavior for the addToQuery parameter was not ok, now it is.
+* Methods that now return MS_SUCCESS/MS_FAILURE:
+  - symbolObj: setPoints, setPattern
+  - scalebarObj: setImageColor
+  - outputFormatObj: validate
+  - layerObj: setProcessing, addFeature, draw
+  - mapObj: moveLayerUp, moveLayerDown, zoomRectangle, zoomScale, setProjection,
+            setWKTProjection, setLayersDrawingOrder
+* Methods that now return NULL on failure:
+  - classObj: clone
+  - styleObj: clone
+  - layerObj: nextShape, getExtent
+  - mapObj: clone, draw, drawQuery getLayerByName, getProjection,
+* Methods that now return an empty array
+  - symbolObj: getPatternArray
+  - layerObj: getItems, getProcessing, getGridIntersectionCoordinates
+  - mapObj: getLayersIndexByGroup, getAllGroupNames, getLayersDrawingOrder, getAllLayerNames
+MapScript (All Flavors)
+The layer query result handing has been re-worked (again) to address some issues introduced in
+the 5.4/5.6 versions. Gone are resultsGetShape and getFeature methods. You should now use a
+refactored getShape method to access layer shapes. That method takes a resultObj and returns
+a shapeObj. Typical use would be (in Perl):
+  $layer->queryByRect($map, $map->{extent}); # layer is still open
+  for($i=0; $i<$layer->getNumResults(); $i++) {
+    $shape = $layer->getShape($layer->getResult($i));
+    print "$i: ". $shape->getValue(1) ."\n";
+  $layer->close();
+A resultObj encapsulates the data used to manage a result set.
+To access shapes independently of a query use the new resultObj class:
+  $layer->open();
+  $shape = $layer->getShape(new mapscript::resultObj(1));
+  $layer->close();
+See http://mapserver.org/development/rfc/ms-rfc-65.html for more information.
+OUTPUTFORMAT
+The OUTPUTFORMAT parameter validation when reading from the mapfile
+will now trigger an error on some problems that in the past were
+silently fixed up.  For instance using RGBA IMAGEMODE with JPEG format
+now triggers an error instead of switching to IMAGEMODE RGB silently.
+The default outputformats names, drivers and mimetypes have been significantly
+reorganized:
+* png : AGG/PNG (image/png)
+* jpeg : AGG/JPEG (image/jpeg)
+* gif : GD/GIF (image/gif)
+* png8 : AGG/PNG8 (same as AGG/PNG, but with 256 color quantization applied)
+  (image/png; mode=8bit)
+* png24 : AGG/PNG (for backwards compatibility) (image/png; mode=24bit)
+* pdf : CAIRO/PDF (application/x-pdf)
+* svg : CAIRO/SVG (image/svg+xml)
+* GTiff : GDAL/GTiff (image/tiff)
+* kml : KML (application/vnd.google-earth.kml++xml)
+* kmz : KMZ (application/vnd.google-earth.kmz)
+Rasters
+* The support for rendering rasters without GDAL has been removed.  Now
+  RASTER layers (or WMS layers) require that MapServer be built against
+  the GDAL library.
+* The above change also means there is no longer support for EPPL raster layers.
+Deprecated features
+- Support for Flash/SWF output has been removed as part of the rendering overhaul
+  because it was no longer compatible with the new architecture.
+  Support for Flash/SWF could be reintroduced but would require a non trivial
+  amount of work (i.e. would require funding).
+- Support for "CONNECTIONTYPE MyGIS" has been dropped since it was no longer
+  being maintained and there are better ways to use MySQL data sources theses
+  days, going through OGR for instance.
+MapServer 5.4 to 5.6 Migration
+applications when migrating from version 5.4.x (or earlier versions)
+to 5.6 (i.e. backwards incompatibilities), as well as information
+MapScript changes related to single pass queries
+In RFC-52, MapServer was modified to perform queries using a single pass
+on the data instead of two passes. This is transparent for CGI applications,
+but MapScript scripts must be modified to use the layer.resultsGetShape()
+method instead of layer.getShape().
+See also: http://mapserver.org/development/rfc/ms-rfc-52.html
+(Note: the new resultsGetShape() method is not yet available for PHP MapScript
+in 5.6.0-beta1)
+WFS 1.1 axis orientation
+The axis order in previous versions of the WFS specifications was to always use
+easting (x or lon ) and northing (y or lat).  WFS 1.1 specifies that, depending
+on the particular SRS, the x axis may or may not be oriented West-to-East, and
+the y axis may or may not be oriented South-to-North. The WFS portrayal operation
+shall account for axis order. This affects some of the EPSG codes that were commonly
+used such as ESPG:4326.  The current implementation makes sure that coordinates
+returned to the server for the GetFeature request reflect the inverse axis orders
+for EPSG codes between 4000 and 5000.
+Change of mime-type for the imagemap outputformat
+RFC 36 added support for templated outptformats, but this new feature
+was not available for WMS GetFeatureInfo ouptut (see ticket #3024).
+In MapServer 5.6 this has been resolved by implementing lookup of output
+formats for query templates by mime-type. However this caused a conflict
+for the text/html mime-type between the actual text/html query
+templates and the preconfigured imagemap outputformat which also used the
+text/html mime-type.
+In order to resolve this conflict, the mime-type of the imagemap outputformat
+has been changed to "text/html; driver=imagemap". This is unlikely to cause
+much side-effects to existing applications, but the change is documented here
+just in case.
+MapServer 5.2 to 5.4 Migration
+applications when migrating from version 5.2. (or earlier versions)
+to 5.4 (i.e. backwards incompatibilities), as well as information
+New requirements for mapfiles, symbolsets and templates
+Due to some potential security vulnerabilities that were uncovered in previous
+versions of MapServer, RFC-56 introduced a number of changes to tighten
+access control on mapfiles and templates and limit the risk of leaking
+arbitrary file contents. These changes were introduced in version 5.4.0,
+and were also backported to v5.2.2 and 4.10.4.
+The new requirements are as follows:
+* The MAP and SYMBOLSET keywords must be added to any mapfile and symbolset
+  that did not contain them already.
+* All MapServer templates must be updated to contain the "MapServer Template"
+  magic string on the first line. This string can be embedded
+  in a commment depending on the template formet and the whole line will
+  be skipped in the output generation. e.g.
+  * In HTML: <!-- MapServer Template -->
+  * In JavaScript: // MapServer Template
+See also: http://mapserver.org/development/rfc/ms-rfc-56.html
+MapServer 4.10 to 5.0 Migration
+applications when migrating from version 4.10.x (or earlier versions)
+to 5.x (i.e. backwards incompatibilities), as well as information
+Mapfile changes
+Attribute Bindings: In an effort to stem the tide of keyword overload
+and add functionality MapServer 5.0 supports a new method of binding
+feature attributes to STYLE and LABEL properties. In the past keywords
+like ANGLEITEM or LABELSIZEITEM were used, now you denote the attribute
+in the context of the property being bound. For example, to bind an
+attribute to a label size you'd do:
+  LABEL
+    SIZE [mySizeItem]
+  END
+The []'s denote a binding (as with logical expressions). The following
+keywords are no longer supported and their presence will throw an error:
+* Layer: LABELANGLEITEM, LABELSIZEITEM
+* Style: ANGLEITEM, SIZEITEM
+The following properties can accept bindings:
+* Style: angle, color, outlinecolor, size, symbol
+* Label: angle, color, outlinecolor, size, font, priority
+Colors may be given as a hex value (e.g. #FFFFFF) or an RGB triplet
+(e.g. 255 255 255).
+Layer Transparency: The values for the TRANSPARENCY parameter have always
+been backwards and in an effort to resolve that the parameter has been
+renamed OPACITY. TRANSPARENCY is still recognized by the mapfile parser
+but is depricated and should be avoided.
+Scale Parameters: MapServer's handling of scale has long been a source
+for confusion. The values use in a layer MINSCALE are really the denominators
+from a representative fraction (e.g. 1:24000). To help clarify this all
+scale parameters are now end with DENOM. So MINSCALE => MINSCALEDENOM,
+SYMBOLSCALE => SYMBOLSCALEDENOM, and so on. The mapfile parser still
+recognizes the older keywords but they are depricated and should be avoided.
+Symbol file changes
+Symbol Style: STYLEs are used within a symbol definition to store dash
+patterns for line symbolization. However, there is potential confusion
+with the style object that is used within class definitions. To resolve
+that confusion the symbol STYLE parameter has been renamed PATTERN. The
+symbol file parser will still recognize the STYLE keyword but it is
+depricated and should be avoided.
+Styling/Symbolgy changes
+Prior to MapsServer 5.0, if a pixmap symbol was used in style on a Line
+Layer, the symbol was used as a brush to draw the line. In MapServer 5.0,
+it is possible to draw the pixmap symbol along the line (Note that this
+was available using a true type symbol). To achieve  this, the user needs
+to use the parameter GAP with it's pixmap symbol definition in the symbol
+file. The GAP represents the distance between the symbols. If the GAP is not
+given, the pixmap symbol will be used as a brush.
+AGG rendering changes
+see `the AGG rendering specifics`_ for the changes relating to the addition
+of the `Antigrain Geometry`_ rendering engine.
+.. _`the AGG rendering specifics`: http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
+.. _`Antigrain Geometry`: http://www.antigrain.com
+URL configuration changes
+Previous versions of the MapServer CGI program allowed certain parameters
+to be changed via a URL using a cumbersome syntax such as
+map_layer_0_class_0_color=255+0+0 which changes the color in one classObj.
+Not only was this cumbersome for users but also from a code maintenance
+perspective since we had to maintain seperate loaders for URL-based config
+and file-based config. RFC-31 attempts to streamline both by migrating to
+a single object loading function that can be used with strings (either in
+MapScript or via URL) or with files.
+So, in the past you have to change parameters one-at-a-time. Now you can
+pass chunks of mapfiles (with security restrictions) to the CGI interface.
+The map_object notation is still necessary to identify which object you
+want to modify but you can change multiple properties at one time. Note
+that you can use either a '_' or a '.' to seperate identifiers.
+Example 1, changing a scalebar object:
+  ...&map.scalebar=UNITS+MILES+COLOR+121+121+121+SIZE+300+2&...
+Example 2, changing a presentation style:
+ ...&map.layer[lakes].class[0].style[0]=SYMBOL+crosshatch+COLOR+151+51+151+SIZE+15&...
+Example 3, creating a new feature
+  ...&map_layer[3]=FEATURE+POINTS+500000+1000000+END+TEXT+'A+test+point'+END&...
+The variable identifies an object uniquely (by name or index in the case of
+layerObj's and classObj's). The value is a snippet of a mapfile. You
+cannot create new objects other than inline features at this point.
+Validation patterns for mapserv attribute queries
+Attribute queries (qstring) done via the mapserv CGI could theoretically
+be used for SQL injection.
+No exploit has been reported, but in order to mitigate the risk, a new
+validation pattern mechanism has been added in 5.0.
+In the case of qstring attribute queries, the qstring_validation_pattern
+layer-level metadata is required for qstring queries to work. The metadata
+value is a regular expression that the qstring value must match otherwise
+mapserv produces a fatal error. A fatal error is also produced if qstring
+is used but qstring_validation_pattern is not provided.
+Note that similar validation pattern mechanism has been available for
+%variable% substitutions since version 4.10, but in this case it is optional.
+The  pattern for %myvar% is provided via a metadata called
+myvar_validation_pattern.
+SWIG MapScript (Python, Perl, CSharp, Java) changes
+Layer Transparency: The layerObj transparency parameter is now called
+opacity. Scripts setting that value in code must be updated.
+Symbol Style: the symbolObj style parameter is now called pattern. MapScript
+does not allow direct modification of that parameter. In Swig-based languages
+the symbolObj method setStyle is now called setPattern. In PHP/MapScript, the
+methods setStyle and getStyle are now called setPattern and getPattern.
+A new msGetVersionInt() function returning the current MapServer version in
+integer format has been added to facilitate version checks in the future.
+Given version x.y.z, it returns (x*0x10000 + y*0x100 + z). For instance, for
+v5.0.0 it will return 0x050000 (note the hexadecimal notation).
+CSharp related changes
+The MapScript C# classes are now placed into the OSGeo.MapServer namespace
+The scripts should use the fully qualified names of the classes or apply
+the
+  using OSGeo.MapServer;
+or the corresponding language equivalent.
+PHP/MapScript changes
+opacity. The old "transparency" name is deprecated and will be removed in
+a future release. Scripts getting/setting that value in code must be updated.
+All occurences of scale, minscale, maxscale, etc... parameters have been
+deprecated and renamed with a "denom" suffix (e.g. minscale becomes
+minscaledenom, etc.). The deprecated parameters will be removed in a
+future release. Scripts getting/setting them must be updated.
+SymbolObj style has been renamed pattern. The old "stylelength" parameter
+and setStyle() and getStyleArray() methods have been deprecated and
+"patternlength", setPattern() and getPatternArray() should be used
+instead. They will be removed in a future release.
+layer.getShape(int tileindex, int shapeindex)) has been deprecated and
+renamed to layer.getFeature(int shapeindex [, int tileindex = -1]) to
+match the SWIG MapScript equivalent. Note that the order of the arguments
+is reversed since tileindex is optional in getFeature().
+class.getExpression() and layer.getFilter() have been deprecated and
+renamed to class.getExpressionString() and layer.getFilterString() to
+match what we have in SWIG MapScript. The String suffix in the function
+name also more clearly indicates that the return value is not an object
+but a string representation of it.
+A new ms_GetVersionInt() function returning the current MapServer version in
+OGC Web Map Service (WMS)
+Required Parameters for GetMap and GetFeatureInfo: previously, MapServer
+did not check for the following parameters when responding to an OGC:WMS
+GetMap or GetFeatureInfo request:
+ - SRS
+ - FORMAT
+ - WIDTH
+ - HEIGHT
+ - STYLES or SLD / SLD_BODY
+ - BBOX
+That is, a GetMap request would process without error if these were not
+passed by the WMS client.
+A compliant OGC:WMS 1.1.0 and 1.1.1 REQUIRES these parameters.  This may
+affect OGC:WMS client requests who were not passing these values. Ticket
+1088 fully documents this issue.  In addition to WMS compliance, this was also
+decided that by adding this constraint, if an OGC client request (as described
+earlier) breaks something, people should fix their client anyway since
+if they change WMS vendor, they will have problems as well.
+OGC Web Feature Service (WFS)
+OGC Sensor Observation Service (SOS)
+- The format of MAP/LAYER/METADATA/sos_describesensor_url
+  has been changed such that users now must format the value
+  per:
+"sos_describesensor_url" "http://example.org/sml/%procedure%.xml"
+  This change has been made to clarify and unify the meaning of procedure
+  within SOS Server's context of a DescribeSensor request.
+- Metadata associated with an observedProperty element's
+  swe:component value have been changed to support a URN
+  scheme, instead of the previous "sos_componenturl" metadata.  The
+  "sos_componenturl" metadata is no longer supported.  Instead,
+  "sos_observedproperty_authority" and "sos_observedproperty_version"
+  should be used to format the swe:component value.
+Build Changes
+MapServer's main include file has been renamed from "map.h" to "mapserver.h".
+A new mapserver-config script has been created with the following options:
+  Usage: mapserver-config [OPTIONS]
+  Options:
+   [--libs]
+   [--dep-libs]
+   [--cflags]
+   [--defines]
+   [--includes]
+   [--version]
+The shared and static link libraries for MapSserver have been renamed
+libmapserver.x.y.so and libmapserver.a respectively.
+The --enable-coverage configure option has been renamed to --enable-gcov
+since the former name led users to think it might be related to enabling
+support for WCS or Arc/Info coverages:
+  --enable-gcov           Enable source code coverage testing using gcov
+Features Heading for Deprecation
+Some features present in MapServer are likely to be removed in a future
+release. Features might be headed for deprecation because:
+ - they have been replaced by a superior or more capable solution
+ - they have stopped being maintained
+Users of these features should be prepared for these upcoming changes
+and start adapting their mapfiles in consequence. If you have strong
+and motivated objections as to the removal of one or more of these
+features please open a discussion in the usual Mapserver communication
+channels.
+Cartoline symbols: these were a hack to overcome GD weaknesses, and their
+functionality is now supported by the AGG renderer. They have become poorly
+supported in current MapServer versions. Keywords allowing for setting the
+style of line joins and caps will be moved to the STYLE block.
+RGB/RGBA output with GD: support for RGB and RGBA image types will likely not
+be maintained anymore. PC256 will continue to be supported with GD, while RGB
+and RGBA will liekly only be supported with AGG
Modified: trunk/docs/zh_cn/documentation.txt
--- trunk/docs/zh_cn/documentation.txt	2011-06-14 13:57:29 UTC (rev 11814)
+++ trunk/docs/zh_cn/documentation.txt	2011-06-14 14:16:06 UTC (rev 11815)
@@ -5,11 +5,9 @@
 .. note::
-    The entire documentation is also available as a single
-    `PDF document <./MapServer.pdf>`__ |image|  and `ePub document <./MapServer.epub>`__
+    完整的文档有单独的 `PDF document <./MapServer.pdf>`__ |image| 和 `ePub document <./MapServer.epub>`__
-    If you plan on upgrading to the MapServer 6.0 release, be sure to review the
-    :ref:`MapServer Migration Guide <migration>`.
+    如果您计划升级到MapServer 6.0正式版,请务必阅读 :ref:`MapServer Migration Guide <migration>` 。
 .. include:: ./include/docnav.inc
Modified: trunk/docs/zh_cn/download.txt
--- trunk/docs/zh_cn/download.txt	2011-06-14 13:57:29 UTC (rev 11814)
+++ trunk/docs/zh_cn/download.txt	2011-06-14 14:16:06 UTC (rev 11815)
@@ -6,10 +6,10 @@
 .. _source:
-Source
+源代码
-Current Release(s)
+当前版本
 * **2012-05-12** `mapserver-6.0.0.tar.gz`_
@@ -17,12 +17,12 @@
 .. _`mapserver-6.0.0.tar.gz`: http://download.osgeo.org/mapserver/mapserver-6.0.0.tar.gz
-Development Releases
+开发中版本
-* none available
+* n无
-Past Releases
+以前版本
 * **2011-01-17** `mapserver-5.6.6.tar.gz`_
@@ -50,32 +50,30 @@
 .. _`mapserver-4.10.6.tar.gz`: http://download.osgeo.org/mapserver/mapserver-4.10.6.tar.gz
-Development Source
+开发版本源代码
-* Current Trunk: http://svn.osgeo.org/mapserver/trunk/
+* 当前仓库:http://svn.osgeo.org/mapserver/trunk/
-* Latest Release Branch: http://svn.osgeo.org/mapserver/branches/branch-6-0
+* 最新正式版仓库:http://svn.osgeo.org/mapserver/branches/branch-6-0
     .. note::
-        More information about MapServer development can be found at
-        :ref:`development`
+        有关MapServer开发的更多消息,参见 :ref:`development`
-Documentation
+文档
 .. note::
+    如果您打算升级到MapServer 6.0正式版,请务必阅读 :ref:`MapServer Migration Guide <migration>`.
-The entire documentation is available as a single PDF document.
+全部文档提供了PDF版本。
-Current Release
+当前版本
 * `MapServer-Documentation.pdf <./MapServer.pdf>`__ |image|
-Previous Releases
+以前版本
 * `MapServer-5.6-Documentation.pdf <./MapServer-56.pdf>`__ |image|
@@ -87,7 +85,7 @@
    :alt: PDF icon
    :target: /MapServer.pdf
-Binaries
+二进制文件
 .. _windows:
@@ -96,9 +94,7 @@
 `FWTools`_
-    A collection of Open Source GIS tools provided by Frank Warmerdam. This
-    goes beyond your basic web mapping tools and include many useful utilities
-    for creating, manipulating, and serving geo-spatial data.
+    由Frank Warmerdam提供的一系列开源的GIS工具。这些工具不属于基础地图工具,包含了许多适用于创建、操作和发布地理空间数据的功能。
 .. _`FWTools`: http://fwtools.maptools.org/
@@ -179,10 +175,10 @@
 .. _`Kyng Chaos`: http://www.kyngchaos.com/software/mapserver
-Demo Application
+演示程序
-Download `MapServer 5.4.x Demo`_
+下载 `MapServer 5.4.x Demo`_
     Download and unzip this file into your computer.  Follow the directions in
     ReadMe.txt. You will most likely need to move the demo directory tree to an
     appropriate location in your httpd server.  You will also need to edit some
Modified: trunk/docs/zh_cn/include/docnav.inc
--- trunk/docs/zh_cn/include/docnav.inc	2011-06-14 13:57:29 UTC (rev 11814)
+++ trunk/docs/zh_cn/include/docnav.inc	2011-06-14 14:16:06 UTC (rev 11815)
@@ -1,6 +1,6 @@
-..   csv-table:: Quick Links
+..   csv-table:: 快速通道
     :ref:`introduction`,:ref:`installation`,:ref:`mapfile`
     :ref:`mapscript`,:ref:`input`,:ref:`output`
