[mapserver-commits] r11828 - trunk/mapserver
Thu Jun 16 10:17:54 EDT 2011
Author: aboudreault
Date: 2011-06-16 07:17:54 -0700 (Thu, 16 Jun 2011)
New Revision: 11828
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdraw.c
   trunk/mapserver/mapows.h
   trunk/mapserver/mapwms.c
   trunk/mapserver/mapwmslayer.c
Added WMS GetFeatureInfo Cascading (#3764)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-06-16 13:53:42 UTC (rev 11827)
+++ trunk/mapserver/HISTORY.TXT	2011-06-16 14:17:54 UTC (rev 11828)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Added WMS GetFeatureInfo Cascading (#3764)
 - Fixed png lib is not found on multiarch systems (#3921)
 - Fixed PHP MapScript opacity property of StyleObj no longer works (#3920)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-06-16 13:53:42 UTC (rev 11827)
+++ trunk/mapserver/mapdraw.c	2011-06-16 14:17:54 UTC (rev 11828)
@@ -331,7 +331,7 @@
 #ifdef USE_WMS_LYR
       if(lp->connectiontype == MS_WMS) {
-        if(msPrepareWMSLayerRequest(map->layerorder[i], map, lp, lastconnectiontype, &sLastWMSParams, pasOWSReqInfo, &numOWSRequests) == MS_FAILURE) {
+          if(msPrepareWMSLayerRequest(map->layerorder[i], map, lp, 1, lastconnectiontype, &sLastWMSParams, 0, 0, 0, NULL, pasOWSReqInfo, &numOWSRequests) == MS_FAILURE) {
           msFreeWmsParamsObj(&sLastWMSParams);
           msFreeImage(image);
           msFree(pasOWSReqInfo);
@@ -1314,8 +1314,8 @@
         msHTTPInitRequestObj(asReqInfo, 2);
-        if ( msPrepareWMSLayerRequest(1, map, layer,
-                                      0, NULL,
+        if ( msPrepareWMSLayerRequest(1, map, layer, 1,
+                                      0, NULL, 0, 0, 0, NULL,
                                       asReqInfo, &numReq) == MS_FAILURE  ||
              msOWSExecuteRequests(asReqInfo, numReq, map, MS_TRUE) == MS_FAILURE )
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2011-06-16 13:53:42 UTC (rev 11827)
+++ trunk/mapserver/mapows.h	2011-06-16 14:17:54 UTC (rev 11828)
@@ -382,8 +382,9 @@
 void msFreeWmsParamsObj(wmsParamsObj *wmsparams);
 int msPrepareWMSLayerRequest(int nLayerId, mapObj *map, layerObj *lp,
-                             enum MS_CONNECTION_TYPE lastconnectiontype,
+                             int nRequestType, enum MS_CONNECTION_TYPE lastconnectiontype,
                              wmsParamsObj *psLastWMSParams,
+                             int nClickX, int nClickY, int nFeatureCount, const char *pszInfoFormat,
                              httpRequestObj *pasReqInfo, int *numRequests);
 int msDrawWMSLayerLow(int nLayerId, httpRequestObj *pasReqInfo,
                       int numRequests, mapObj *map, layerObj *lp,
@@ -391,10 +392,9 @@
 MS_DLL_EXPORT char *msWMSGetFeatureInfoURL(mapObj *map, layerObj *lp,
                              const char *pszInfoFormat);
+int msWMSLayerFeatureInfo(mapObj *map, int nOWSLayers, int nClickX, int nClickY,
+                          int nFeatureCount, const char *pszInfoFormat);
  *   mapwfs.c
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2011-06-16 13:53:42 UTC (rev 11827)
+++ trunk/mapserver/mapwms.c	2011-06-16 14:17:54 UTC (rev 11828)
@@ -3100,6 +3100,9 @@
   int valid_format=MS_FALSE;
   int format_found = MS_FALSE;
   int use_bbox = MS_FALSE;
+  int wms_layer =  MS_FALSE;
+  const char *wms_connection = NULL;
+  int numOWSLayers = 0;
   encoding = msOWSLookupMetadata(&(map->web.metadata), "MO", "encoding");
@@ -3126,9 +3129,13 @@
               (map->name && strcasecmp(map->name, layers[k]) == 0) ||
               (GET_LAYER(map, j)->group && strcasecmp(GET_LAYER(map, j)->group, layers[k]) == 0)) &&
              (msIntegerInArray(GET_LAYER(map, j)->index, ows_request->enabled_layers, ows_request->numlayers)) )
-                numlayers_found++;
-                GET_LAYER(map, j)->status = MS_ON;
+             if (GET_LAYER(map, j)->connectiontype == MS_WMS) {
+                 wms_layer = MS_TRUE;
+                 wms_connection = GET_LAYER(map, j)->connection;
+             numlayers_found++;
+             GET_LAYER(map, j)->status = MS_ON;
@@ -3173,7 +3180,7 @@
   if(numlayers_found == 0)
       if (query_layer)
@@ -3196,16 +3203,33 @@
 /*      check if all layers selected are queryable. If not send an      */
 /*      exception.                                                      */
+  /* If a layer of type WMS was found... all layers have to be of that type and with the same connection */
   for (i=0; i<map->numlayers; i++)
-      if (GET_LAYER(map, i)->status == MS_ON && !msIsLayerQueryable(GET_LAYER(map, i)))
-          msSetError(MS_WMSERR, "Requested layer(s) are not queryable.", "msWMSFeatureInfo()");
-          return msWMSException(map, nVersion, "LayerNotQueryable", wms_exception_format);
+      if (GET_LAYER(map, i)->status == MS_ON)
+          if (!msIsLayerQueryable(GET_LAYER(map, i)))
+              msSetError(MS_WMSERR, "Requested layer(s) are not queryable.", "msWMSFeatureInfo()");
+              return msWMSException(map, nVersion, "LayerNotQueryable", wms_exception_format);
+          else if (wms_layer == MS_TRUE)
+              if ( (GET_LAYER(map, i)->connectiontype != MS_WMS) || (strcasecmp(wms_connection, GET_LAYER(map, i)->connection) != 0) )
+                  msSetError(MS_WMSERR, "Requested WMS layer(s) are not queryable: type or connection differ", "msWMSFeatureInfo()");
+              ++numOWSLayers;
+  /* It's a valid Cascading WMS GetFeatureInfo request */
+  if (wms_layer)
+      return msWMSLayerFeatureInfo(map, numOWSLayers, point.x, point.y, feature_count, info_format);
   if( use_bbox == MS_FALSE ) {
     if(point.x == -1.0 || point.y == -1.0) {
Modified: trunk/mapserver/mapwmslayer.c
--- trunk/mapserver/mapwmslayer.c	2011-06-16 13:53:42 UTC (rev 11827)
+++ trunk/mapserver/mapwmslayer.c	2011-06-16 14:17:54 UTC (rev 11828)
@@ -934,8 +934,9 @@
 #ifdef USE_WMS_LYR
@@ -963,9 +964,22 @@
  * Build the request URL, this will also set layer projection and
  * compute BBOX in that projection.
-    if ( msBuildWMSLayerURL(map, lp, WMS_GETMAP,
-                            0, 0, 0, NULL, &bbox, &bbox_width, &bbox_height,
-                            &sThisWMSParams) != MS_SUCCESS)
+    if (nRequestType == WMS_GETMAP &&
+        ( msBuildWMSLayerURL(map, lp, WMS_GETMAP,
+                             0, 0, 0, NULL, &bbox, &bbox_width, &bbox_height,
+                             &sThisWMSParams) != MS_SUCCESS) )
+        /* an error was already reported. */
+        msFreeWmsParamsObj(&sThisWMSParams);
+        return MS_FAILURE;
+    else if (msBuildWMSLayerURL(map, lp, WMS_GETFEATUREINFO,
+                                nClickX, nClickY, nFeatureCount, pszInfoFormat,
+                                NULL, NULL, NULL,
+                                &sThisWMSParams) == MS_FAILURE)
@@ -976,12 +990,12 @@
  * Check if the request is empty, perhaps due to reprojection problems
  * or wms_extents restrictions.
-    if( bbox_width == 0 || bbox_height == 0 )
+    if ((nRequestType == WMS_GETMAP) && (bbox_width == 0 || bbox_height == 0) )
         return MS_SUCCESS;  /* No overlap. */
  * Check if layer overlaps current view window (using wms_latlonboundingbox)
@@ -1324,9 +1338,10 @@
         pszURL = NULL;
         pasReqInfo[(*numRequests)].pszHTTPCookieData = pszHTTPCookieData;
         pszHTTPCookieData = NULL;
-        if( bCacheToDisk )
+        if( bCacheToDisk ) {
             pasReqInfo[(*numRequests)].pszOutputFile =
-                msTmpFile(map, map->mappath, NULL, "img.tmp");
+                msTmpFile(map, map->mappath, NULL, "wms.tmp");
         else
             pasReqInfo[(*numRequests)].pszOutputFile = NULL;
         pasReqInfo[(*numRequests)].nStatus = 0;
@@ -1626,3 +1641,107 @@
+#ifdef USE_WMS_LYR
+    msIOContext *context;
+    httpRequestObj *pasReqInfo;
+    wmsParamsObj sLastWMSParams;
+    int i, numReq = 0;
+    pasReqInfo = (httpRequestObj *)msSmallMalloc((nOWSLayers+1)*sizeof(httpRequestObj));
+    msHTTPInitRequestObj(pasReqInfo, nOWSLayers+1);
+    msInitWmsParamsObj(&sLastWMSParams);
+    /* Generate the http request */
+    for (i=0; i<map->numlayers; i++)
+        if (GET_LAYER(map,map->layerorder[i])->status == MS_ON)
+            if (msPrepareWMSLayerRequest(map->layerorder[i], map, GET_LAYER(map,map->layerorder[i]), WMS_GETFEATUREINFO,
+                                         MS_WMS, &sLastWMSParams,
+                                         pasReqInfo, &numReq) == MS_FAILURE)
+                msFreeWmsParamsObj(&sLastWMSParams);
+                msFree(pasReqInfo);
+    if (msOWSExecuteRequests(pasReqInfo, numReq, map, MS_FALSE) == MS_FAILURE)
+        msHTTPFreeRequestObj(pasReqInfo, numReq);
+    context = msIO_getHandler( stdout );
+    if( context == NULL )
+    msIO_printf("Content-type: %s%c%c",pasReqInfo[0].pszContentType, 10,10);
+    if( pasReqInfo[0].pszOutputFile )
+        FILE *fp;
+        char szBuf[MS_BUFFER_LENGTH];
+        fp = fopen(pasReqInfo[0].pszOutputFile, "r");
+        if (fp)
+            while(1)
+                size_t nSize;
+                nSize = fread(szBuf, sizeof(char), MS_BUFFER_LENGTH-1, fp);
+                if (nSize > 0)
+                    msIO_contextWrite( context,
+                                       szBuf,
+                                       nSize);
+                if (nSize != MS_BUFFER_LENGTH-1)
+                    break;
+            fclose(fp);
+            if (!map->debug)
+                unlink(pasReqInfo[0].pszOutputFile);
+        else
+            msSetError(MS_IOERR, "'%s'.",
+                       "msWMSLayerFeatureInfo()", pasReqInfo[0].pszOutputFile);
+    else
+                           pasReqInfo[0].result_data,
+                           pasReqInfo[0].result_size );
+    return MS_SUCCESS;
+#else
+ * WMS CONNECTION Support not included...
+  msSetError(MS_WMSCONNERR, "WMS CLIENT CONNECTION support is not available.",
+             "msWMSLayerFeatureInfo()");
+  return(MS_FAILURE);
+#endif /* USE_WMS_LYR */
