[mapserver-commits] r11829 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Jun 17 09:44:38 EDT 2011
Author: warmerdam
Date: 2011-06-17 06:44:38 -0700 (Fri, 17 Jun 2011)
New Revision: 11829
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapprojhack.c
Fix GetMapserverUnitUsingProj() for proj=latlong (#3883)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-06-16 14:17:54 UTC (rev 11828)
+++ trunk/mapserver/HISTORY.TXT 2011-06-17 13:44:38 UTC (rev 11829)
@@ -63,6 +63,9 @@
- Improve rangeset item checking so that Bands=1,2,3 is supported with WCS 1.0
(#3919).
+- Fix GetMapserverUnitUsingProj() for proj=latlong (#3883)
Version 6.0.0 (2011-05-11)
Modified: trunk/mapserver/mapprojhack.c
--- trunk/mapserver/mapprojhack.c 2011-06-16 14:17:54 UTC (rev 11828)
+++ trunk/mapserver/mapprojhack.c 2011-06-17 13:44:38 UTC (rev 11829)
@@ -81,8 +81,13 @@
int GetMapserverUnitUsingProj(projectionObj *psProj)
#ifdef USE_PROJ
- char *proj_str = pj_get_def( psProj->proj, 0 );
+ char *proj_str;
+ if( pj_is_latlong( psProj ) )
+ return MS_DD;
+ proj_str = pj_get_def( psProj->proj, 0 );
/* Handle case of named units. */
More information about the mapserver-commits
