[mapserver-commits] r11836 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Sat Jun 18 15:33:43 EDT 2011
Author: yjacolin
Date: 2011-06-18 12:33:43 -0700 (Sat, 18 Jun 2011)
New Revision: 11836
trunk/docs/en/mapfile/outputformat.txt
typo
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt 2011-06-18 18:40:32 UTC (rev 11835)
+++ trunk/docs/en/mapfile/outputformat.txt 2011-06-18 19:33:43 UTC (rev 11836)
@@ -90,7 +90,7 @@
NAME [name]
- The name to use use in the IMAGETYPE keyword of the map file to
+ The name to use in the IMAGETYPE keyword of the map file to
select this output format. This name is also used in metadata describing
wxs formats allowed, and can be used (sometimes along with mimetype) to
select the output format via keywords in OGC requests. (optional)
More information about the mapserver-commits
