[mapserver-commits] r11634 - in trunk/msautotest/wxs: . expected
Tue May 3 06:32:10 EDT 2011
Author: schpidi
Date: 2011-05-03 03:32:10 -0700 (Tue, 03 May 2011)
New Revision: 11634
Added:
   trunk/msautotest/wxs/expected/wcs_20_getcov_trim_x_y_both_1px.tif
   trunk/msautotest/wxs/expected/wcs_20_multi_getcov_trim_x_to_1px.tif
   trunk/msautotest/wxs/expected/wcs_20_multi_getcov_trim_y_to_1px.tif
   trunk/msautotest/wxs/expected/wcs_20_post_getcov_trim_x_y_both_1px.tif
   trunk/msautotest/wxs/wcs_multi.map
   trunk/msautotest/wxs/wcs_post.map
   trunk/msautotest/wxs/wcs_simple.map
Adding tests for #3857.
Added: trunk/msautotest/wxs/expected/wcs_20_getcov_trim_x_y_both_1px.tif
(Binary files differ)
Property changes on: trunk/msautotest/wxs/expected/wcs_20_getcov_trim_x_y_both_1px.tif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/wxs/expected/wcs_20_multi_getcov_trim_x_to_1px.tif
Property changes on: trunk/msautotest/wxs/expected/wcs_20_multi_getcov_trim_x_to_1px.tif
Added: trunk/msautotest/wxs/expected/wcs_20_multi_getcov_trim_y_to_1px.tif
Property changes on: trunk/msautotest/wxs/expected/wcs_20_multi_getcov_trim_y_to_1px.tif
Added: trunk/msautotest/wxs/expected/wcs_20_post_getcov_trim_x_y_both_1px.tif
Property changes on: trunk/msautotest/wxs/expected/wcs_20_post_getcov_trim_x_y_both_1px.tif
Modified: trunk/msautotest/wxs/wcs_multi.map
--- trunk/msautotest/wxs/wcs_multi.map	2011-05-03 10:29:12 UTC (rev 11633)
+++ trunk/msautotest/wxs/wcs_multi.map	2011-05-03 10:32:10 UTC (rev 11634)
@@ -23,6 +23,10 @@
 # RUN_PARMS: wcs_20_post_bands_name_new.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>multi_new</wcs:CoverageID><wcs:rangeSubset><wcs:band>Band9</wcs:band><wcs:band>Band5</wcs:band><wcs:band>Band1</wcs:band></wcs:rangeSubset></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
 # RUN_PARMS: wcs_20_post_bands_name_new.dat [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>multi_new</wcs:CoverageID><wcs:Mediatype>multipart/mixed</wcs:Mediatype><wcs:rangeSubset><wcs:band>Band9</wcs:band><wcs:band>Band5</wcs:band><wcs:band>Band1</wcs:band></wcs:rangeSubset></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Trim to 1px (#3857):
+# RUN_PARMS: wcs_20_multi_getcov_trim_y_to_1px.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>multi</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>10.1</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_multi_getcov_trim_x_to_1px.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>multi</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>10.1</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
 MAP
 NAME TEST
Modified: trunk/msautotest/wxs/wcs_post.map
--- trunk/msautotest/wxs/wcs_post.map	2011-05-03 10:29:12 UTC (rev 11633)
+++ trunk/msautotest/wxs/wcs_post.map	2011-05-03 10:32:10 UTC (rev 11634)
@@ -71,6 +71,8 @@
 # RUN_PARMS: wcs_20_post_getcov_trim_y_min.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
 # RUN_PARMS: wcs_20_post_getcov_trim_y_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
 # RUN_PARMS: wcs_20_post_getcov_trim_x_y_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# (#3857):
+# RUN_PARMS: wcs_20_post_getcov_trim_x_y_both_1px.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>10.1</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>10.1</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
 # RUN_PARMS: wcs_20_post_getcov_full_multipart.dat [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Mediatype>multipart/mixed</wcs:Mediatype></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
 # Subsetting in diverse CRS
Modified: trunk/msautotest/wxs/wcs_simple.map
--- trunk/msautotest/wxs/wcs_simple.map	2011-05-03 10:29:12 UTC (rev 11633)
+++ trunk/msautotest/wxs/wcs_simple.map	2011-05-03 10:32:10 UTC (rev 11634)
@@ -150,6 +150,8 @@
 # GetCoverage 2.0 image/tiff trim x y both
 # RUN_PARMS: wcs_20_getcov_trim_x_y_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(10,20)&SUBSET=y(10,20)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim x y both to 1x1px image (#3857)
+# RUN_PARMS: wcs_20_getcov_trim_x_y_both_1px.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(10,10.1)&SUBSET=y(10,10.1)" > [RESULT_DEMIME]
 # GetCoverage 2.0 gml+image/tiff full
 # RUN_PARMS: wcs_20_getcov_full.dat [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&MEDIATYPE=multipart/mixed" > [RESULT_DEMIME]
