[mapserver-commits] r11635 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue May 3 11:14:20 EDT 2011
Author: tamas
Date: 2011-05-03 08:14:20 -0700 (Tue, 03 May 2011)
New Revision: 11635
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapunion.c
Union layer: fix for the failure if one or more of the source layers are not in the current extent (#3858)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-05-03 10:32:10 UTC (rev 11634)
+++ trunk/mapserver/HISTORY.TXT 2011-05-03 15:14:20 UTC (rev 11635)
@@ -15,6 +15,9 @@
Current Version (SVN trunk):
+- Union layer: fix for the failure if one or more of the source layers
+ are not in the current extent (#3858)
- Fix memory leak in msResampleGDALToMap() (#3857)
- Fix missing initialization of default formats in WCS 1.x.
Modified: trunk/mapserver/mapunion.c
--- trunk/mapserver/mapunion.c 2011-05-03 10:32:10 UTC (rev 11634)
+++ trunk/mapserver/mapunion.c 2011-05-03 15:14:20 UTC (rev 11635)
@@ -49,6 +49,7 @@
int classIndex; /* current class index */
int layerCount; /* number of the source layers */
layerObj* layers; /* structure to the source layers */
+ int *status; /* the layer status */
int *classgroup; /* current array of the valid classes */
int nclasses; /* number of the valid classes */
} msUnionLayerInfo;
@@ -71,6 +72,7 @@
freeLayer(&layerinfo->layers[i]);
msFree(layerinfo->layers);
+ msFree(layerinfo->status);
msFree(layerinfo->classgroup);
msFree(layerinfo);
layer->layerinfo = NULL;
@@ -130,6 +132,9 @@
layerinfo->layers =(layerObj*)malloc(layerCount * sizeof(layerObj));
MS_CHECK_ALLOC(layerinfo->layers, layerCount * sizeof(layerObj), MS_FAILURE);
+ layerinfo->status =(layerObj*)malloc(layerCount * sizeof(int));
+ MS_CHECK_ALLOC(layerinfo->status, layerCount * sizeof(int), MS_FAILURE);
for(i=0; i < layerCount; i++)
int layerindex = msGetLayerIndex(map, layerNames[i]);
@@ -170,7 +175,8 @@
/* disable the connection pool for this layer */
msLayerSetProcessingKey(&layerinfo->layers[i], "CLOSE_CONNECTION", "ALWAYS");
- if (msLayerOpen(&layerinfo->layers[i]) != MS_SUCCESS)
+ layerinfo->status[i] = msLayerOpen(&layerinfo->layers[i]);
+ if (layerinfo->status[i] != MS_SUCCESS)
if(layerNames)
msFreeCharArray(layerNames, layerinfo->layerCount);
@@ -318,7 +324,8 @@
if(srclayer->transform == MS_TRUE && srclayer->project && layer->transform == MS_TRUE && layer->project &&msProjectionsDiffer(&(srclayer->projection), &(layer->projection)))
msProjectRect(&layer->projection, &srclayer->projection, &srcRect); /* project the searchrect to source coords */
#endif
- if (msLayerWhichShapes(srclayer, srcRect) != MS_SUCCESS)
+ layerinfo->status[i] = msLayerWhichShapes(srclayer, srcRect);
+ if (layerinfo->status[i] == MS_FAILURE)
return MS_FAILURE;
@@ -395,58 +402,61 @@
while (layerinfo->layerIndex < layerinfo->layerCount)
- srclayer = &layerinfo->layers[layerinfo->layerIndex];
- while (srclayer->vtable->LayerNextShape(srclayer, shape) == MS_SUCCESS)
+ if (layerinfo->status[layerinfo->layerIndex] == MS_SUCCESS)
- if(layer->styleitem)
+ srclayer = &layerinfo->layers[layerinfo->layerIndex];
+ while (srclayer->vtable->LayerNextShape(srclayer, shape) == MS_SUCCESS)
- /* need to retrieve the source layer classindex if styleitem AUTO is set */
- layerinfo->classIndex = msShapeGetClass(srclayer, layer->map, shape, layerinfo->classgroup, layerinfo->nclasses);
- if(layerinfo->classIndex < 0 || layerinfo->classIndex >= srclayer->numclasses)
+ if(layer->styleitem)
- // this shape is not visible, skip it
- msFreeShape(shape);
- if (rv == MS_SUCCESS)
- continue;
- else
- break;
+ /* need to retrieve the source layer classindex if styleitem AUTO is set */
+ layerinfo->classIndex = msShapeGetClass(srclayer, layer->map, shape, layerinfo->classgroup, layerinfo->nclasses);
+ if(layerinfo->classIndex < 0 || layerinfo->classIndex >= srclayer->numclasses)
+ // this shape is not visible, skip it
+ msFreeShape(shape);
+ if (rv == MS_SUCCESS)
+ continue;
+ else
+ break;
+ if(strcasecmp(srclayer->styleitem, "AUTO") != 0)
+ /* Generic feature style handling as per RFC-61 */
+ msLayerGetFeatureStyle(layer->map, srclayer, srclayer->class[layerinfo->classIndex], shape);
- if(strcasecmp(srclayer->styleitem, "AUTO") != 0)
- /* Generic feature style handling as per RFC-61 */
- msLayerGetFeatureStyle(layer->map, srclayer, srclayer->class[layerinfo->classIndex], shape);
#ifdef USE_PROJ
- /* reproject to the target layer */
- if(srclayer->project && msProjectionsDiffer(&(srclayer->projection), &(layer->projection)))
- msProjectShape(&(srclayer->projection), &(layer->projection), shape);
- else
- srclayer->project = MS_FALSE;
+ /* reproject to the target layer */
+ if(srclayer->project && msProjectionsDiffer(&(srclayer->projection), &(layer->projection)))
+ msProjectShape(&(srclayer->projection), &(layer->projection), shape);
+ else
+ srclayer->project = MS_FALSE;
#endif
- shape->tileindex = layerinfo->layerIndex;
+ shape->tileindex = layerinfo->layerIndex;
- /* construct the item array */
- if (layer->iteminfo)
- rv = BuildFeatureAttributes(layer, srclayer, shape);
+ /* construct the item array */
+ if (layer->iteminfo)
+ rv = BuildFeatureAttributes(layer, srclayer, shape);
- /* check the layer filter condition */
- if(layer->filter.string != NULL && layer->numitems > 0 && layer->iteminfo)
- if (layer->filter.type == MS_EXPRESSION && layer->filter.tokens == NULL)
- msTokenizeExpression(&(layer->filter), layer->items, &(layer->numitems));
+ /* check the layer filter condition */
+ if(layer->filter.string != NULL && layer->numitems > 0 && layer->iteminfo)
+ if (layer->filter.type == MS_EXPRESSION && layer->filter.tokens == NULL)
+ msTokenizeExpression(&(layer->filter), layer->items, &(layer->numitems));
- if (!msEvalExpression(layer, shape, &(layer->filter), layer->filteritemindex))
- /* this shape is filtered */
- continue;
+ if (!msEvalExpression(layer, shape, &(layer->filter), layer->filteritemindex))
+ /* this shape is filtered */
+ continue;
+ return rv;
- return rv;
++layerinfo->layerIndex;
More information about the mapserver-commits
