[mapserver-commits] r11647 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed May 4 23:51:06 EDT 2011
Author: sdlime
Date: 2011-05-04 20:51:06 -0700 (Wed, 04 May 2011)
New Revision: 11647
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapquery.c
Call msLayerClose() before msLayerOpen() in query operations to ensure all parser data is cleaned up. (#3692)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-05-04 18:46:39 UTC (rev 11646)
+++ trunk/mapserver/HISTORY.TXT 2011-05-05 03:51:06 UTC (rev 11647)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- Call msLayerClose() before msLayerOpen() in the various query functions (#3692)
- Use full list of epsg codes with inverted axis (#3582)
- PHP/Mapscript: Added getResultsBounds() method in layer object (#2967)
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2011-05-04 18:46:39 UTC (rev 11646)
+++ trunk/mapserver/mapquery.c 2011-05-05 03:51:06 UTC (rev 11647)
@@ -510,7 +510,7 @@
- /* open this layer */
+ msLayerClose(lp); /* reset */
status = msLayerOpen(lp);
if(status != MS_SUCCESS) return(MS_FAILURE);
@@ -659,7 +659,7 @@
msInitShape(&shape);
if(status != MS_SUCCESS) {
msRestoreOldFilter(lp, old_filtertype, old_filteritem, old_filterstring); /* manually reset the filter */
@@ -839,6 +839,7 @@
msCopyExpression(&lp->filter, map->query.filter); /* apply new filter */
if(status != MS_SUCCESS) goto query_error;
@@ -1028,7 +1029,7 @@
continue;
@@ -1235,7 +1236,7 @@
else
tolerance = layer_tolerance * (msInchesPerUnit(lp->toleranceunits,0)/msInchesPerUnit(map->units,0));
@@ -1539,7 +1540,7 @@
rect.miny = map->query.point.y - t;
rect.maxy = map->query.point.y + t;
@@ -1733,7 +1734,7 @@
else
@@ -1980,7 +1981,7 @@
continue;
More information about the mapserver-commits
