[mapserver-commits] r11648 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu May 5 00:04:47 EDT 2011
Author: sdlime
Date: 2011-05-04 21:04:47 -0700 (Wed, 04 May 2011)
New Revision: 11648
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapquery.c
trunk/mapserver/mapserver.h
Removed obsolete msQueryByOperator() function.
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2011-05-05 03:51:06 UTC (rev 11647)
+++ trunk/mapserver/HISTORY.TXT 2011-05-05 04:04:47 UTC (rev 11648)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- Removed obsolete msQueryByOperator() function
- Call msLayerClose() before msLayerOpen() in the various query functions (#3692)
- Use full list of epsg codes with inverted axis (#3582)
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2011-05-05 03:51:06 UTC (rev 11647)
+++ trunk/mapserver/mapquery.c 2011-05-05 04:04:47 UTC (rev 11648)
@@ -52,8 +52,6 @@
query->shapeindex = query->tileindex = -1;
query->clear_resultcache = MS_TRUE; /* index queries allow the old results to persist */
- query->op = -1;
query->item = query->str = NULL;
query->filter = NULL;
@@ -101,9 +99,6 @@
case MS_QUERY_BY_FILTER:
status = msQueryByFilter(map);
break;
- case MS_QUERY_BY_OPERATOR:
- status = msQueryByOperator(map);
- break;
case MS_QUERY_BY_SHAPE:
status = msQueryByShape(map);
break;
@@ -306,9 +301,7 @@
fprintf(stream, "%s\n", (map->query.item)?map->query.item:"NULL"); /* by attribute */
fprintf(stream, "%s\n", (map->query.str)?map->query.str:"NULL");
- fprintf(stream, "%d\n", map->query.op); /* by operator */
- if(map->query.shape) { /* by shape/by operator */
+ if(map->query.shape) { /* by shape */
int i, j;
shapeObj *s = map->query.shape;
@@ -362,9 +355,6 @@
break;
case 8:
- if(sscanf(buffer, "%d\n", &map->query.op) != 1) goto parse_error;
- break;
- case 9:
if(sscanf(buffer, "%d\n", &shapetype) != 1) goto parse_error;
if(shapetype != MS_SHAPE_NULL) { /* load the rest of the shape */
@@ -1904,252 +1894,6 @@
return(MS_FAILURE);
-/* msQueryByOperator */
-/* query using a shape and a valid operator : all queries are */
-/* done using geos. */
-int msQueryByOperator(mapObj *map)
-#ifdef USE_GEOS
- int start, stop=0, l;
- shapeObj shape, *qshape=NULL;
- layerObj *lp;
- int status;
- rectObj searchrect;
- int nclasses = 0;
- int *classgroup = NULL;
- double dfValue;
- double minfeaturesize = -1;
- if(map->query.type != MS_QUERY_BY_OPERATOR) {
- msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByOperator()");
- return(MS_FAILURE);
- msInitShape(&shape);
- qshape = map->query.shape; /* for brevity */
- /* this should not be a necessary test for queries using geos */
- if(selectshape->type != MS_SHAPE_POLYGON) {
- msSetError(MS_QUERYERR, "Search shape MUST be a polygon.", "msQueryByShape()");
- if(map->query.layer < 0 || map->query.layer >= map->numlayers)
- start = map->numlayers-1;
- else
- start = stop = map->query.layer;
- msComputeBounds(qshape); /* make sure an accurate extent exists */
- for(l=start; l>=stop; l--) { /* each layer */
- lp = (GET_LAYER(map, l));
- /* conditions may have changed since this layer last drawn, so set
- layer->project true to recheck projection needs (Bug #673) */
- lp->project = MS_TRUE;
- /* free any previous search results, do it now in case one of the next few tests fail */
- if(lp->resultcache) {
- if(lp->resultcache->results) free(lp->resultcache->results);
- free(lp->resultcache);
- lp->resultcache = NULL;
- if(!msIsLayerQueryable(lp)) continue;
- if(lp->status == MS_OFF) continue;
- if(map->scaledenom > 0) {
- if((lp->maxscaledenom > 0) && (map->scaledenom > lp->maxscaledenom)) continue;
- if((lp->minscaledenom > 0) && (map->scaledenom <= lp->minscaledenom)) continue;
- if (lp->maxscaledenom <= 0 && lp->minscaledenom <= 0) {
- if((lp->maxgeowidth > 0) && ((map->extent.maxx - map->extent.minx) > lp->maxgeowidth)) continue;
- if((lp->mingeowidth > 0) && ((map->extent.maxx - map->extent.minx) < lp->mingeowidth)) continue;
- /* Raster layers are handled specially. */
- if( lp->type == MS_LAYER_RASTER ) {
- if( msRasterQueryByShape(map, lp, qshape) == MS_FAILURE )
- return MS_FAILURE;
- continue;
- msLayerClose(lp); /* reset */
- status = msLayerOpen(lp);
- if(status != MS_SUCCESS) return(MS_FAILURE);
- /* build item list, we want *all* items */
- status = msLayerWhichItems(lp, MS_TRUE, NULL);
- /* identify target shapes */
- if (map->query.op == MS_GEOS_BEYOND)
- searchrect = map->extent;
- else
- searchrect = qshape->bounds;
-#ifdef USE_PROJ
- if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
- msProjectRect(&(map->projection), &(lp->projection), &searchrect); /* project the searchrect to source coords */
- else
- lp->project = MS_FALSE;
-#endif
- status = msLayerWhichShapes(lp, searchrect);
- if(status == MS_DONE) { /* no overlap */
- msLayerClose(lp);
- continue;
- } else if(status != MS_SUCCESS) {
- msLayerClose(lp);
- lp->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj)); /* allocate and initialize the result cache */
- MS_CHECK_ALLOC(lp->resultcache, sizeof(resultCacheObj), MS_FAILURE);
- initResultCache( lp->resultcache);
- classgroup = NULL;
- if (lp->classgroup && lp->numclasses > 0)
- classgroup = msAllocateValidClassGroups(lp, &nclasses);
- if (lp->minfeaturesize > 0)
- minfeaturesize = Pix2LayerGeoref(map, lp, lp->minfeaturesize);
- while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step through the shapes */
- /* Check if the shape size is ok to be drawn */
- if ( (shape.type == MS_SHAPE_LINE || shape.type == MS_SHAPE_POLYGON) && (minfeaturesize > 0) )
- if (msShapeCheckSize(&shape, minfeaturesize) == MS_FALSE)
- if( lp->debug >= MS_DEBUGLEVEL_V )
- msDebug("msQueryByOperator(): Skipping shape (%d) because LAYER::MINFEATURESIZE is bigger than shape size\n", shape.index);
- msFreeShape(&shape);
- continue;
- shape.classindex = msShapeGetClass(lp, map, &shape, classgroup, nclasses);
- if(!(lp->template) && ((shape.classindex == -1) || (lp->class[shape.classindex]->status == MS_OFF))) { /* not a valid shape */
- continue;
- if(!(lp->template) && !(lp->class[shape.classindex]->template)) { /* no valid template */
- continue;
-#ifdef USE_PROJ
- msProjectShape(&(lp->projection), &(map->projection), &shape);
- else
-#endif
- switch(map->query.op)
- case MS_GEOS_EQUALS:
- status = msGEOSEquals(&shape, qshape);
- if (status != MS_TRUE && status != MS_FALSE)
- status = MS_FALSE;
- break;
- case MS_GEOS_DISJOINT:
- status = msGEOSDisjoint(&shape, qshape);
- break;
- case MS_GEOS_TOUCHES:
- status = msGEOSTouches(&shape, qshape);
- break;
- case MS_GEOS_OVERLAPS:
- status = msGEOSOverlaps(&shape, qshape);
- break;
- case MS_GEOS_CROSSES:
- status = msGEOSCrosses(&shape, qshape);
- break;
- case MS_GEOS_INTERSECTS:
- status = msGEOSIntersects(&shape, qshape);
- break;
- case MS_GEOS_WITHIN:
- status = msGEOSWithin(&shape, qshape);
- break;
- case MS_GEOS_CONTAINS:
- status = msGEOSContains(qshape, &shape);
- break;
- /* beyond is opposite of dwithin use in filter encoding see tickets #2105 and #2564 */
- case MS_GEOS_BEYOND:
- dfValue = msGEOSDistance(&shape, qshape);
- if (dfValue > 0.0)
- status = MS_TRUE;
- break;
- /* dwithin is used with filter encoding (#2564) */
- case MS_GEOS_DWITHIN:
- if (dfValue == 0.0)
- status = MS_TRUE;
- break;
- default:
- msSetError(MS_QUERYERR, "Unknown GEOS Operator.", "msQueryByOperator()");
- if(status == MS_TRUE)
- addResult(lp->resultcache, &shape);
- } /* next shape */
- if(status != MS_DONE) return(MS_FAILURE);
- if(lp->resultcache->numresults == 0) msLayerClose(lp); /* no need to keep the layer open */
- } /* next layer */
- /* was anything found? */
- if(GET_LAYER(map, l)->resultcache && GET_LAYER(map, l)->resultcache->numresults > 0)
- return(MS_SUCCESS);
- msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByOperator()");
-#else
- msSetError(MS_GEOSERR, "GEOS support is not available.", "msQueryByOperator()");
-#endif
/* msGetQueryResultBounds()
* Compute the BBOX of all query results, returns the number of layers found
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2011-05-05 03:51:06 UTC (rev 11647)
+++ trunk/mapserver/mapserver.h 2011-05-05 04:04:47 UTC (rev 11648)
@@ -467,7 +467,7 @@
#define MS_MULTIPLE 1
enum MS_QUERY_MODE {MS_QUERY_SINGLE, MS_QUERY_MULTIPLE};
-enum MS_QUERY_TYPE {MS_QUERY_IS_NULL, MS_QUERY_BY_POINT, MS_QUERY_BY_RECT, MS_QUERY_BY_SHAPE, MS_QUERY_BY_ATTRIBUTE, MS_QUERY_BY_INDEX, MS_QUERY_BY_OPERATOR, MS_QUERY_BY_FILTER};
+enum MS_QUERY_TYPE {MS_QUERY_IS_NULL, MS_QUERY_BY_POINT, MS_QUERY_BY_RECT, MS_QUERY_BY_SHAPE, MS_QUERY_BY_ATTRIBUTE, MS_QUERY_BY_INDEX, MS_QUERY_BY_FILTER};
enum MS_ALIGN_VALUE {MS_ALIGN_LEFT, MS_ALIGN_CENTER, MS_ALIGN_RIGHT};
@@ -775,8 +775,6 @@
expressionObj *filter; /* by filter */
- int op; /* by GEOS operator */
int slayer; /* selection layer, used for msQueryByFeatures() (note this is not a query mode per se) */
} queryObj;
#endif
@@ -1853,7 +1851,6 @@
MS_DLL_EXPORT int msQueryByRect(mapObj *map);
MS_DLL_EXPORT int msQueryByFeatures(mapObj *map);
MS_DLL_EXPORT int msQueryByShape(mapObj *map);
-MS_DLL_EXPORT int msQueryByOperator(mapObj *map);
MS_DLL_EXPORT int msQueryByFilter(mapObj *map);
MS_DLL_EXPORT int msGetQueryResultBounds(mapObj *map, rectObj *bounds);
More information about the mapserver-commits
