[mapserver-commits] r11649 - in trunk/msautotest/query: . template
svn at osgeo.org
svn at osgeo.org
Thu May 5 00:35:45 EDT 2011
Author: sdlime
Date: 2011-05-04 21:35:45 -0700 (Wed, 04 May 2011)
New Revision: 11649
Added:
trunk/msautotest/query/template/feature.tmpl
trunk/msautotest/query/template.map
New test to try and show all the feature-level template tags.
Added: trunk/msautotest/query/template/feature.tmpl
--- trunk/msautotest/query/template/feature.tmpl (rev 0)
+++ trunk/msautotest/query/template/feature.tmpl 2011-05-05 04:35:45 UTC (rev 11649)
@@ -0,0 +1,13 @@
+<!-- MapServer Template -->
+This template tests various per feature template output...
+[resultset layer="bdry_counpy2"]
+ [feature]
+ ITEM TAGS: [item name="cty_name"]:[item name="cty_abbr"]
+ OLD-STYLE TAG (case sensitive): [CTY_NAME], [cty_name]
+ SHPEXT (basic): [shpext]
+ SHPEXT (precision=0): [shpext precision="0"]
+ SHPXY (basic): [shpxy]
+ [/feature]
+[/resultset]
Modified: trunk/msautotest/query/template.map
--- trunk/msautotest/query/template.map 2011-05-05 04:04:47 UTC (rev 11648)
+++ trunk/msautotest/query/template.map 2011-05-05 04:35:45 UTC (rev 11649)
@@ -1,6 +1,7 @@
# Test 1: simple mode=query, HTML template
# RUN_PARMS: template_test001.html [MAPSERV] QUERY_STRING='map=[MAPFILE]&mode=query&qlayer=bdry_counpy2&mapxy=467000+5259000&qformat=html' > [RESULT_DEMIME]
+# RUN_PARMS: template_test002.html [MAPSERV] QUERY_STRING='map=[MAPFILE]&mode=query&qlayer=bdry_counpy2&mapxy=467000+5259000&qformat=feature' > [RESULT_DEMIME]
MAP
NAME 'query'
@@ -14,6 +15,13 @@
FORMATOPTION "FILE=template/html.tmpl"
END
+ OUTPUTFORMAT
+ NAME 'feature'
+ DRIVER 'TEMPLATE'
+ MIMETYPE 'text/html'
+ FORMATOPTION "FILE=template/feature.tmpl"
+ END
LAYER
NAME 'bdry_counpy2'
INCLUDE 'include/bdry_counpy2_shapefile.map'
More information about the mapserver-commits
