[mapserver-commits] r11769 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Mon May 30 13:25:05 EDT 2011
Author: assefa
Date: 2011-05-30 10:25:05 -0700 (Mon, 30 May 2011)
New Revision: 11769
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/mapwfs.c
WFS: check if map projection is properly set before using it (#3897)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2011-05-30 13:15:57 UTC (rev 11768)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2011-05-30 17:25:05 UTC (rev 11769)
@@ -13,6 +13,8 @@
Current Version:
+- WFS: check if map projection is properly set before using it (#3897)
- Fix for the memory corruption when mapping the string data type in the Java bindings (#3491)
- Ensure the class is not marked BeforeFieldInit causing memory corruption with C#/CLR4 (#3438)
Modified: branches/branch-5-4/mapserver/mapwfs.c
--- branches/branch-5-4/mapserver/mapwfs.c 2011-05-30 13:15:57 UTC (rev 11768)
+++ branches/branch-5-4/mapserver/mapwfs.c 2011-05-30 17:25:05 UTC (rev 11769)
@@ -1130,7 +1130,8 @@
/* get the extent of the layer (bbox will get further filtered later */
/* if the client specifies BBOX or a spatial filter */
- if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS) {
+ if (msOWSGetLayerExtent(map, lp, "FO", &ext) == MS_SUCCESS &&
+ pszMapSRS != NULL) {
sprintf(szBuf, "init=epsg:%.10s", pszMapSRS+5);
if (szBuf != NULL) {
More information about the mapserver-commits
