[mapserver-commits] r11771 - branches/branch-6-0/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Mon May 30 18:19:57 EDT 2011
Author: havatv
Date: 2011-05-30 15:19:57 -0700 (Mon, 30 May 2011)
New Revision: 11771
branches/branch-6-0/docs/en/mapfile/style.txt
Fixed style-angle documentation - no rotation of ellipse symbols with GD (#3832)
Modified: branches/branch-6-0/docs/en/mapfile/style.txt
--- branches/branch-6-0/docs/en/mapfile/style.txt 2011-05-30 18:36:06 UTC (rev 11770)
+++ branches/branch-6-0/docs/en/mapfile/style.txt 2011-05-30 22:19:57 UTC (rev 11771)
@@ -24,13 +24,13 @@
- For points, it specifies the rotation of the symbol around its
center.
- For decorated lines, the behaviour depends on the value of
- the GAP element.
+ the `GAP` element.
- - For negative GAP values it specifies the rotation of the
+ - For negative `GAP` values it specifies the rotation of the
decoration symbol relative to the direction of the line.
An angle of 0 means that the symbol's x-axis is oriented
along the direction of the line.
- - For non-negativ (or absent) GAP values it specifies the
+ - For non-negativ (or absent) `GAP` values it specifies the
rotation of the decoration symbol around its center.
An angle of 0 means that the symbol is not rotated.
- For polygons, it specifies the angle of the lines in a HATCH
@@ -59,6 +59,11 @@
- The `AUTO` keyword was added in version 5.4, and currently only
applies when coupled with the `GEOMTRANSFORM` keyword.
+ .. note::
+ Rotation using `ANGLE` is not supported for :ref:`SYMBOL`\s
+ of `TYPE` `ellipse` with the GD renderer (gif).
ANGLEITEM [string]
ANGLE[attribute] must now be used instead.
More information about the mapserver-commits
