[mapserver-commits] r12789 - sandbox/sdlime/rfc-77
svn at osgeo.org
svn at osgeo.org
Mon Nov 21 08:25:43 EST 2011
Author: sdlime
Date: 2011-11-21 05:25:43 -0800 (Mon, 21 Nov 2011)
New Revision: 12789
sandbox/sdlime/rfc-77/mapfile.c
sandbox/sdlime/rfc-77/mapprimitive.c
sandbox/sdlime/rfc-77/mapprimitive.h
shapeObj needs to hold mutliple text values.
Modified: sandbox/sdlime/rfc-77/mapfile.c
--- sandbox/sdlime/rfc-77/mapfile.c 2011-11-19 00:37:17 UTC (rev 12788)
+++ sandbox/sdlime/rfc-77/mapfile.c 2011-11-21 13:25:43 UTC (rev 12789)
@@ -67,26 +67,24 @@
static int loadGrid( layerObj *pLayer );
static int loadStyle(styleObj *style);
static void writeStyle(FILE* stream, int indent, styleObj *style);
-static int msResolveSymbolNames(mapObj *map);
+static int resolveSymbolNames(mapObj *map);
-/* int msIsAxisInverted */
-/* check to see if we shoudl invert the axis. */
+/* int isAxisInverted */
+/* check to see if we should invert the axis. */
-static int msIsAxisInverted(int epsg_code)
+static int isAxisInverted(int epsg_code)
- int i;
- /*check the static table*/
- for (i=0; i<AXIS_ORIENTATION_TABLE_SIZE; i++)
- if (axisOrientationEpsgCodes[i].code == epsg_code)
- return MS_TRUE;
+ int i;
- return MS_FALSE;
+ /* check the static table */
+ for (i=0; i<AXIS_ORIENTATION_TABLE_SIZE; i++) {
+ if (axisOrientationEpsgCodes[i].code == epsg_code)
+ return MS_TRUE;
+ return MS_FALSE;
@@ -1316,7 +1314,7 @@
p->numargs = 1;
- if( msIsAxisInverted(atoi(value+5)))
+ if( isAxisInverted(atoi(value+5)))
p->args[1] = msStrdup("+epsgaxis=ne");
p->numargs = 2;
@@ -1411,7 +1409,7 @@
p->args[0] = init_string;
p->numargs = 1;
- if( msIsAxisInverted(atoi(code)))
+ if( isAxisInverted(atoi(code)))
p->numargs = 2;
@@ -1447,7 +1445,7 @@
p->numargs = 1;
p->numargs = 2;
@@ -1506,7 +1504,7 @@
p->args[0] = msStrdup(init_string);
p->numargs = 1;
p->numargs = 2;
@@ -5404,7 +5402,7 @@
if(loadSymbolSet(&(map->symbolset), map) == -1) return MS_FAILURE;
- if (msResolveSymbolNames(map) == MS_FAILURE) return MS_FAILURE;
+ if (resolveSymbolNames(map) == MS_FAILURE) return MS_FAILURE;
#if defined (USE_GD_TTF) || defined (USE_GD_FT)
@@ -5619,7 +5617,7 @@
if (mappath != NULL) free(mappath);
msyylex_destroy();
- if (msResolveSymbolNames(map) == MS_FAILURE) return NULL;
+ if (resolveSymbolNames(map) == MS_FAILURE) return NULL;
return map;
@@ -6237,20 +6235,17 @@
-void initResultCache(resultCacheObj *resultcache)
- if (resultcache)
- resultcache->results = NULL;
- resultcache->numresults = 0;
- resultcache->cachesize = 0;
- resultcache->bounds.minx = resultcache->bounds.miny = resultcache->bounds.maxx = resultcache->bounds.maxy = -1;
- resultcache->usegetshape = MS_FALSE;
+void initResultCache(resultCacheObj *resultcache) {
+ if (resultcache) {
+ resultcache->results = NULL;
+ resultcache->numresults = 0;
+ resultcache->cachesize = 0;
+ resultcache->bounds.minx = resultcache->bounds.miny = resultcache->bounds.maxx = resultcache->bounds.maxy = -1;
+ resultcache->usegetshape = MS_FALSE;
-static int msResolveSymbolNames(mapObj* map)
+static int resolveSymbolNames(mapObj* map) {
int i, j;
/* step through layers and classes to resolve symbol names */
Modified: sandbox/sdlime/rfc-77/mapprimitive.c
--- sandbox/sdlime/rfc-77/mapprimitive.c 2011-11-19 00:37:17 UTC (rev 12788)
+++ sandbox/sdlime/rfc-77/mapprimitive.c 2011-11-21 13:25:43 UTC (rev 12789)
@@ -106,6 +106,7 @@
/* annotation component */
shape->text = NULL;
+ shape->numtext = 0;
/* bookkeeping component */
shape->classindex = 0; /* default class */
@@ -129,7 +130,12 @@
to->bounds.maxx = from->bounds.maxx;
to->bounds.maxy = from->bounds.maxy;
- if(from->text) to->text = msStrdup(from->text);
+ if(from->text) {
+ to->text = (char **)msSmallMalloc(sizeof(char *)*from->numtext);
+ for(i=0; i<from->numtext; i++)
+ to->text[i] = msStrdup(from->text[i]);
+ to->numtext = from->numtext;
to->classindex = from->classindex;
to->index = from->index;
@@ -158,9 +164,9 @@
for (c= 0; c < shape->numlines; c++)
free(shape->line[c].point);
- if (shape->line) free(shape->line);
+ if(shape->line) free(shape->line);
if(shape->values) msFreeCharArray(shape->values, shape->numvalues);
- if(shape->text) free(shape->text);
+ if(shape->text) msFreeCharArray(shape->text, shape->numtext);
#ifdef USE_GEOS
msGEOSFreeGeometry(shape);
Modified: sandbox/sdlime/rfc-77/mapprimitive.h
--- sandbox/sdlime/rfc-77/mapprimitive.h 2011-11-19 00:37:17 UTC (rev 12788)
+++ sandbox/sdlime/rfc-77/mapprimitive.h 2011-11-21 13:25:43 UTC (rev 12789)
@@ -70,6 +70,7 @@
#endif
int numlines;
int numvalues;
+ int numtext;
#ifndef SWIG
lineObj *line;
char **values;
@@ -86,7 +87,7 @@
long index;
int tileindex;
int classindex;
- char *text;
+ char **text;
int scratch;
int resultindex; /* index within a query result set */
More information about the mapserver-commits
