[mapserver-commits] r12790 - sandbox/sdlime/rfc-77
svn at osgeo.org
svn at osgeo.org
Mon Nov 21 23:40:18 EST 2011
Author: sdlime
Date: 2011-11-21 20:40:18 -0800 (Mon, 21 Nov 2011)
New Revision: 12790
sandbox/sdlime/rfc-77/mapserver.h
sandbox/sdlime/rfc-77/maptemplate.c
sandbox/sdlime/rfc-77/maputil.c
Changed signature for msShapeGetAnnotation() to return an int (MS_SUCCESS/MS_FAILURE). For RFC 77 much of the work will be done in this function.
Modified: sandbox/sdlime/rfc-77/mapserver.h
--- sandbox/sdlime/rfc-77/mapserver.h 2011-11-21 13:25:43 UTC (rev 12789)
+++ sandbox/sdlime/rfc-77/mapserver.h 2011-11-22 04:40:18 UTC (rev 12790)
@@ -2275,7 +2275,7 @@
MS_DLL_EXPORT int msEvalContext(mapObj *map, layerObj *layer, char *context);
MS_DLL_EXPORT int msEvalExpression(layerObj *layer, shapeObj *shape, expressionObj *expression, int itemindex);
MS_DLL_EXPORT int msShapeGetClass(layerObj *layer, mapObj *map, shapeObj *shape, int *classgroup, int numclasses);
-MS_DLL_EXPORT char *msShapeGetAnnotation(layerObj *layer, shapeObj *shape);
+MS_DLL_EXPORT int msShapeGetAnnotation(layerObj *layer, shapeObj *shape);
MS_DLL_EXPORT int msShapeCheckSize(shapeObj *shape, double minfeaturesize);
MS_DLL_EXPORT int msAdjustImage(rectObj rect, int *width, int *height);
MS_DLL_EXPORT double msAdjustExtent(rectObj *rect, int width, int height);
Modified: sandbox/sdlime/rfc-77/maptemplate.c
--- sandbox/sdlime/rfc-77/maptemplate.c 2011-11-21 13:25:43 UTC (rev 12789)
+++ sandbox/sdlime/rfc-77/maptemplate.c 2011-11-22 04:40:18 UTC (rev 12790)
@@ -926,10 +926,11 @@
mapserv->resultshape.classindex = msShapeGetClass(layer, layer->map, &mapserv->resultshape, NULL, -1);
- if ( mapserv->resultshape.classindex>=0 &&
- (layer->class[mapserv->resultshape.classindex]->text.string || layer->labelitem) &&
- layer->class[mapserv->resultshape.classindex]->label.size != -1)
- mapserv->resultshape.text = msShapeGetAnnotation(layer, & mapserv->resultshape);
+ // if ( mapserv->resultshape.classindex>=0 &&
+ // (layer->class[mapserv->resultshape.classindex]->text.string || layer->labelitem) &&
+ // layer->class[mapserv->resultshape.classindex]->label.size != -1)
+ if(layer->class[mapserv->resultshape.classindex]->numlabels > 0)
+ msShapeGetAnnotation(layer, &mapserv->resultshape); // RFC 77 TODO: check return value
/* prepare any necessary JOINs here (one-to-one only) */
if(layer->numjoins > 0) {
@@ -1496,351 +1497,307 @@
return(MS_SUCCESS);
+// RFC 77 TODO: Need to validate these changes with Assefa...
+static int processShplabelTag(layerObj *layer, char **line, shapeObj *origshape) {
+ char *tag, *tagStart, *tagEnd;
+ char *tagValue=NULL;
+ hashTableObj *tagArgs=NULL;
+ int tagOffset, tagLength;
+ char *format;
+ char *argValue=NULL;
+ char *projectionString=NULL;
+ shapeObj tShape;
+ int precision=0;
+ int clip_to_map=MS_TRUE;
+ int use_label_settings=MS_FALSE;
+ double cellsize=0;
+ int labelposvalid = MS_FALSE;
+ pointObj labelPos;
+ int i,status;
+ char number[64]; /* holds a single number in the extent */
+ char numberFormat[16];
+ shapeObj *shape = NULL;
-static int processShplabelTag(layerObj *layer, char **line, shapeObj *origshape)
- char *tag, *tagStart, *tagEnd;
- char *tagValue=NULL;
- hashTableObj *tagArgs=NULL;
- int tagOffset, tagLength;
- char *format;
- char *argValue=NULL;
- char *projectionString=NULL;
- shapeObj tShape;
- int precision=0;
- int clip_to_map=MS_TRUE;
- int use_label_settings=MS_FALSE;
- double cellsize=0;
- int labelposvalid = MS_FALSE;
- pointObj labelPos;
- int i,status;
- char number[64]; /* holds a single number in the extent */
- char numberFormat[16];
- shapeObj *shape = NULL;
- if(!*line) {
+ if(!*line) {
msSetError(MS_WEBERR, "Invalid line pointer.", "processShplabelTag()");
return(MS_FAILURE);
- if( msCheckParentPointer(layer->map,"map")==MS_FAILURE )
- return MS_FAILURE;
+ if(msCheckParentPointer(layer->map,"map") == MS_FAILURE)
+ return MS_FAILURE;
- tagStart = findTag(*line, "shplabel");
+ tagStart = findTag(*line, "shplabel");
- /* It is OK to have no shplabel tags, just return. */
- if( !tagStart )
- return MS_SUCCESS;
+ /* It is OK to have no shplabel tags, just return. */
+ if(!tagStart)
+ return MS_SUCCESS;
- if(!origshape || origshape->numlines <= 0) { /* I suppose we need to make sure the part has vertices (need shape checker?) */
- msSetError(MS_WEBERR, "Null or empty shape.", "processShplabelTag()");
- return(MS_FAILURE);
+ if(!origshape || origshape->numlines <= 0) { /* I suppose we need to make sure the part has vertices (need shape checker?) */
+ msSetError(MS_WEBERR, "Null or empty shape.", "processShplabelTag()");
+ return(MS_FAILURE);
- while (tagStart)
- if (shape)
- msFreeShape(shape);
- shape = (shapeObj *) msSmallMalloc(sizeof(shapeObj));
- msInitShape(shape);
- msCopyShape(origshape, shape);
+ while(tagStart) {
+ if(shape) msFreeShape(shape);
+ shape = (shapeObj *) msSmallMalloc(sizeof(shapeObj));
+ msInitShape(shape);
+ msCopyShape(origshape, shape);
- projectionString = NULL;
- format = "$x,$y";
- tagOffset = tagStart - *line;
+ projectionString = NULL;
+ format = "$x,$y";
+ tagOffset = tagStart - *line;
- if(getTagArgs("shplabel", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
- if(tagArgs)
- argValue = msLookupHashTable(tagArgs, "format");
- if(argValue) format = argValue;
+ if(getTagArgs("shplabel", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
+ if(tagArgs) {
+ argValue = msLookupHashTable(tagArgs, "format");
+ if(argValue) format = argValue;
- argValue = msLookupHashTable(tagArgs, "precision");
- if(argValue) precision = atoi(argValue);
+ argValue = msLookupHashTable(tagArgs, "precision");
+ if(argValue) precision = atoi(argValue);
- argValue = msLookupHashTable(tagArgs, "proj");
- if(argValue) projectionString = argValue;
+ argValue = msLookupHashTable(tagArgs, "proj");
+ if(argValue) projectionString = argValue;
- argValue = msLookupHashTable(tagArgs, "clip_to_map");
- if(argValue)
- if(strcasecmp(argValue,"false") == 0) clip_to_map = MS_FALSE;
+ argValue = msLookupHashTable(tagArgs, "clip_to_map");
+ if(argValue) {
+ if(strcasecmp(argValue,"false") == 0) clip_to_map = MS_FALSE;
- argValue = msLookupHashTable(tagArgs, "use_label_settings");
- if(argValue)
- if(strcasecmp(argValue,"true") == 0) use_label_settings = MS_TRUE;
+ argValue = msLookupHashTable(tagArgs, "use_label_settings");
+ if(argValue) {
+ if(strcasecmp(argValue,"true") == 0) use_label_settings = MS_TRUE;
- labelPos.x = -1;
- labelPos.y = -1;
- msInitShape(&tShape);
+ labelPos.x = -1;
+ labelPos.y = -1;
+ msInitShape(&tShape);
- tShape.type = MS_SHAPE_LINE;
- tShape.line = (lineObj *) msSmallMalloc(sizeof(lineObj));
- tShape.numlines = 1;
- tShape.line[0].point = NULL; /* initialize the line */
- tShape.line[0].numpoints = 0;
+ tShape.type = MS_SHAPE_LINE;
+ tShape.line = (lineObj *) msSmallMalloc(sizeof(lineObj));
+ tShape.numlines = 1;
+ tShape.line[0].point = NULL; /* initialize the line */
+ tShape.line[0].numpoints = 0;
- if (layer->map->cellsize <= 0)
- cellsize = MS_MAX(MS_CELLSIZE(layer->map->extent.minx, layer->map->extent.maxx, layer->map->width),
- MS_CELLSIZE(layer->map->extent.miny, layer->map->extent.maxy, layer->map->height));
- else
- cellsize = layer->map->cellsize ;
+ if(layer->map->cellsize <= 0)
+ cellsize = MS_MAX(MS_CELLSIZE(layer->map->extent.minx, layer->map->extent.maxx, layer->map->width), MS_CELLSIZE(layer->map->extent.miny, layer->map->extent.maxy, layer->map->height));
+ else
+ cellsize = layer->map->cellsize ;
- if (shape->type == MS_SHAPE_POINT)
- labelposvalid = MS_FALSE;
- if (shape->numlines > 0 && shape->line[0].numpoints > 0)
- labelposvalid = MS_TRUE;
- labelPos = shape->line[0].point[0];
- if(layer->transform == MS_TRUE)
- if (layer->project &&
- msProjectionsDiffer(&(layer->projection), &(layer->map->projection)))
- msProjectShape(&layer->projection, &layer->map->projection, shape);
+ if(shape->type == MS_SHAPE_POINT) {
+ labelposvalid = MS_FALSE;
+ if(shape->numlines > 0 && shape->line[0].numpoints > 0) {
+ labelposvalid = MS_TRUE;
+ labelPos = shape->line[0].point[0];
+ if(layer->transform == MS_TRUE) {
+ if(layer->project && msProjectionsDiffer(&(layer->projection), &(layer->map->projection)))
+ msProjectShape(&layer->projection, &layer->map->projection, shape);
- labelPos.x = MS_MAP2IMAGE_X(labelPos.x, layer->map->extent.minx, cellsize);
- labelPos.y = MS_MAP2IMAGE_Y(labelPos.y, layer->map->extent.maxy, cellsize);
+ labelPos.x = MS_MAP2IMAGE_X(labelPos.x, layer->map->extent.minx, cellsize);
+ labelPos.y = MS_MAP2IMAGE_Y(labelPos.y, layer->map->extent.maxy, cellsize);
- else if (shape->type == MS_SHAPE_LINE)
- pointObj **annopoints = NULL;
- double** angles = NULL, **lengths = NULL;
- int numpoints = 1;
+ } else if(shape->type == MS_SHAPE_LINE) {
+ pointObj **annopoints = NULL;
+ double **angles = NULL, **lengths = NULL;
+ int numpoints = 1;
- if(layer->transform == MS_TRUE) {
- if (clip_to_map)
- msClipPolylineRect(shape, layer->map->extent);
+ if(clip_to_map)
+ msClipPolylineRect(shape, layer->map->extent);
- msTransformShapeToPixelRound(shape, layer->map->extent, cellsize);
- else
- msOffsetShapeRelativeTo(shape, layer);
+ msTransformShapeToPixelRound(shape, layer->map->extent, cellsize);
+ } else
+ msOffsetShapeRelativeTo(shape, layer);
- if (shape->numlines > 0)
- annopoints = msPolylineLabelPoint(shape, -1, 0, &angles, &lengths, &numpoints, MS_FALSE);
- if (numpoints > 0)
- /*convert to geo*/
- labelPos.x = annopoints[0]->x;
- labelPos.y = annopoints[0]->y;
+ if(shape->numlines > 0) {
+ annopoints = msPolylineLabelPoint(shape, -1, 0, &angles, &lengths, &numpoints, MS_FALSE);
+ if(numpoints > 0) {
+ /* convert to geo */
+ labelPos.x = annopoints[0]->x;
+ labelPos.y = annopoints[0]->y;
- for (i=0; i<numpoints; i++)
- if (annopoints[i])
- msFree(annopoints[i]);
- if (angles[i])
- msFree(angles[i]);
- if (lengths[i])
- msFree(lengths[i]);
- msFree(angles);
- msFree(annopoints);
- msFree(lengths);
- else if (shape->type == MS_SHAPE_POLYGON)
- if (clip_to_map)
- msClipPolygonRect(shape, layer->map->extent);
+ for(i=0; i<numpoints; i++) {
+ if(annopoints[i]) msFree(annopoints[i]);
+ if(angles[i]) msFree(angles[i]);
+ if(lengths[i]) msFree(lengths[i]);
+ msFree(angles);
+ msFree(annopoints);
+ msFree(lengths);
+ } else if (shape->type == MS_SHAPE_POLYGON) {
- else
+ if(clip_to_map)
+ msClipPolygonRect(shape, layer->map->extent);
- if (msPolygonLabelPoint(shape, &labelPos, -1) == MS_SUCCESS)
- if (labelPos.x == -1 && labelPos.y == -1)
- else
+ } else
+ if(msPolygonLabelPoint(shape, &labelPos, -1) == MS_SUCCESS) {
+ if(labelPos.x == -1 && labelPos.y == -1)
+ else
- if (labelposvalid == MS_TRUE)
- pointObj p1;
- pointObj p2;
- int label_offset_x, label_offset_y;
- labelObj *label=NULL;
- rectObj r;
- shapeObj poly;
- double tmp;
- msInitShape(&poly);
+ if(labelposvalid == MS_TRUE) {
+ pointObj p1;
+ pointObj p2;
+ int label_offset_x, label_offset_y;
+ labelObj *label=NULL;
+ rectObj r;
+ shapeObj poly;
+ double tmp;
- p1.x =labelPos.x;
- p1.y =labelPos.y;
+ msInitShape(&poly);
+ p1.x =labelPos.x;
+ p1.y =labelPos.y;
- p2.x =labelPos.x;
- p2.y =labelPos.y;
- if (use_label_settings == MS_TRUE)
- if (shape->text && shape->classindex >=0)
- label = &layer->class[shape->classindex]->label;
- if(msGetLabelSize(layer->map,label,shape->text,label->size,&r,NULL) == MS_SUCCESS)
- label_offset_x = (int)(label->offsetx*layer->scalefactor);
- label_offset_y = (int)(label->offsety*layer->scalefactor);
+ p2.x =labelPos.x;
+ p2.y =labelPos.y;
+ if(use_label_settings == MS_TRUE) {
- p1 = get_metrics(&labelPos, label->position, r, label_offset_x, label_offset_y,
- label->angle, 0, &poly);
- /*should we use the point returned from get_metrics?. From few test done, It seems
- to return the UL corner of the text. For now use the bounds.minx/miny*/
+ /* RFC 77: classes (and shapes) can have more than 1 piece of annotation, here we only use the first (index=0) */
+ if(shape->numtext > 0 && shape->text[0] && shape->classindex >= 0) {
+ label = layer->class[shape->classindex]->labels[0];
+ if(msGetLabelSize(layer->map, label, shape->text[0], label->size, &r, NULL) == MS_SUCCESS) {
+ label_offset_x = (int)(label->offsetx*layer->scalefactor);
+ label_offset_y = (int)(label->offsety*layer->scalefactor);
- p1.x = poly.bounds.minx;
- p1.y = poly.bounds.miny;
- p2.x = poly.bounds.maxx;
- p2.y = poly.bounds.maxy;
- /* y's are flipped because it is in image coordinate systems */
- p1.x = MS_IMAGE2MAP_X(p1.x, layer->map->extent.minx, cellsize);
- tmp = p1.y;
- p1.y = MS_IMAGE2MAP_Y(p2.y, layer->map->extent.maxy, cellsize);
- p2.x = MS_IMAGE2MAP_X(p2.x, layer->map->extent.minx, cellsize);
- p2.y = MS_IMAGE2MAP_Y(tmp, layer->map->extent.maxy, cellsize);
- msProjectPoint(&layer->map->projection, &layer->projection, &p1);
- msProjectPoint(&layer->map->projection, &layer->projection, &p2);
- msAddPointToLine(&(tShape.line[0]), &p1);
- msAddPointToLine(&(tShape.line[0]), &p2);
+ p1 = get_metrics(&labelPos, label->position, r, label_offset_x, label_offset_y, label->angle, 0, &poly);
+ /* should we use the point returned from get_metrics?. From few test done, It seems
+ to return the UL corner of the text. For now use the bounds.minx/miny */
+ p1.x = poly.bounds.minx;
+ p1.y = poly.bounds.miny;
+ p2.x = poly.bounds.maxx;
+ p2.y = poly.bounds.maxy;
- else
- tShape.numlines = 0;
+ /* y's are flipped because it is in image coordinate systems */
+ p1.x = MS_IMAGE2MAP_X(p1.x, layer->map->extent.minx, cellsize);
+ tmp = p1.y;
+ p1.y = MS_IMAGE2MAP_Y(p2.y, layer->map->extent.maxy, cellsize);
+ p2.x = MS_IMAGE2MAP_X(p2.x, layer->map->extent.minx, cellsize);
+ p2.y = MS_IMAGE2MAP_Y(tmp, layer->map->extent.maxy, cellsize);
+ if(layer->project && msProjectionsDiffer(&(layer->projection), &(layer->map->projection))) {
+ msProjectPoint(&layer->map->projection, &layer->projection, &p1);
+ msProjectPoint(&layer->map->projection, &layer->projection, &p2);
+ msAddPointToLine(&(tShape.line[0]), &p1);
+ msAddPointToLine(&(tShape.line[0]), &p2);
+ } else
+ tShape.numlines = 0;
- if(projectionString && strcasecmp(projectionString,"image") == 0) {
- precision = 0;
+ if(projectionString && strcasecmp(projectionString,"image") == 0) {
+ precision = 0;
- /* if necessary, project the shape to match the map */
- if(msProjectionsDiffer(&(layer->projection), &(layer->map->projection)))
- msProjectShape(&layer->projection, &layer->map->projection, &tShape);
+ /* if necessary, project the shape to match the map */
+ if(msProjectionsDiffer(&(layer->projection), &(layer->map->projection)))
+ msProjectShape(&layer->projection, &layer->map->projection, &tShape);
- msClipPolylineRect(&tShape, layer->map->extent);
+ msClipPolylineRect(&tShape, layer->map->extent);
- msTransformShapeToPixelRound(&tShape, layer->map->extent, layer->map->cellsize);
+ msTransformShapeToPixelRound(&tShape, layer->map->extent, layer->map->cellsize);
+ } else if(projectionString) {
+ projectionObj projection;
+ msInitProjection(&projection);
- } else if(projectionString) {
- projectionObj projection;
- msInitProjection(&projection);
+ status = msLoadProjectionString(&projection, projectionString);
+ if(status != MS_SUCCESS) return MS_FAILURE;
- status = msLoadProjectionString(&projection, projectionString);
- if(status != MS_SUCCESS) return MS_FAILURE;
+ if(msProjectionsDiffer(&(layer->projection), &projection))
+ msProjectShape(&layer->projection, &projection, &tShape);
- if(msProjectionsDiffer(&(layer->projection), &projection))
- msProjectShape(&layer->projection, &projection, &tShape);
+ /* find the end of the tag */
+ tagEnd = findTagEnd(tagStart);
+ tagEnd++;
- /* find the end of the tag */
- tagEnd = findTagEnd(tagStart);
- tagEnd++;
+ /* build the complete tag so we can do substitution */
+ tagLength = tagEnd - tagStart;
+ tag = (char *) msSmallMalloc(tagLength + 1);
+ strlcpy(tag, tagStart, tagLength+1);
- /* build the complete tag so we can do substitution */
- tagLength = tagEnd - tagStart;
- tag = (char *) msSmallMalloc(tagLength + 1);
- strlcpy(tag, tagStart, tagLength+1);
+ /* do the replacement */
+ tagValue = msStrdup(format);
+ if(precision > 0)
+ snprintf(numberFormat, sizeof(numberFormat), "%%.%dlf", precision);
+ else
+ snprintf(numberFormat, sizeof(numberFormat), "%%f");
- /* do the replacement */
- tagValue = msStrdup(format);
- if(precision > 0)
- snprintf(numberFormat, sizeof(numberFormat), "%%.%dlf", precision);
- else
- snprintf(numberFormat, sizeof(numberFormat), "%%f");
- if (tShape.numlines > 0)
- if(strcasestr(tagValue, "$x") != 0)
- snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[0].x);
- tagValue = msReplaceSubstring(tagValue, "$x", number);
- if(strcasestr(tagValue, "$y") != 0)
- snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[0].y);
- tagValue = msReplaceSubstring(tagValue, "$y", number);
+ if(tShape.numlines > 0) {
+ if(strcasestr(tagValue, "$x") != 0) {
+ snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[0].x);
+ tagValue = msReplaceSubstring(tagValue, "$x", number);
+ if(strcasestr(tagValue, "$y") != 0) {
+ snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[0].y);
+ tagValue = msReplaceSubstring(tagValue, "$y", number);
- if(strcasestr(tagValue, "$minx") != 0)
- tagValue = msReplaceSubstring(tagValue, "$minx", number);
- if(strcasestr(tagValue, "$miny") != 0)
- tagValue = msReplaceSubstring(tagValue, "$miny", number);
- if(strcasestr(tagValue, "$maxx") != 0)
- snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[1].x);
- tagValue = msReplaceSubstring(tagValue, "$maxx", number);
- if(strcasestr(tagValue, "$maxy") != 0)
- snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[1].y);
- tagValue = msReplaceSubstring(tagValue, "$maxy", number);
- tagEnd++;
+ if(strcasestr(tagValue, "$minx") != 0) {
+ tagValue = msReplaceSubstring(tagValue, "$minx", number);
+ if(strcasestr(tagValue, "$miny") != 0) {
+ tagValue = msReplaceSubstring(tagValue, "$miny", number);
+ if(strcasestr(tagValue, "$maxx") != 0) {
+ snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[1].x);
+ tagValue = msReplaceSubstring(tagValue, "$maxx", number);
+ if(strcasestr(tagValue, "$maxy") != 0) {
+ snprintf(number, sizeof(number), numberFormat, tShape.line[0].point[1].y);
+ tagValue = msReplaceSubstring(tagValue, "$maxy", number);
+ tagEnd++;
- *line = msReplaceSubstring(*line, tag, tagValue);
+ *line = msReplaceSubstring(*line, tag, tagValue);
- /* clean up */
- msFreeShape(&tShape);
- free(tag); tag = NULL;
- msFreeHashTable(tagArgs); tagArgs=NULL;
- msFree(tagValue); tagValue=NULL;
+ /* clean up */
+ msFreeShape(&tShape);
+ free(tag); tag = NULL;
+ msFreeHashTable(tagArgs); tagArgs=NULL;
+ msFree(tagValue); tagValue=NULL;
- if((*line)[tagOffset] != '\0')
- tagStart = findTag(*line+tagOffset+1, "shplabel");
- else
- tagStart = NULL;
- if (shape)
+ if((*line)[tagOffset] != '\0')
+ tagStart = findTag(*line+tagOffset+1, "shplabel");
+ else
+ tagStart = NULL;
+ if(shape)
+ msFreeShape(shape);
- return(MS_SUCCESS);
+ return(MS_SUCCESS);
Modified: sandbox/sdlime/rfc-77/maputil.c
--- sandbox/sdlime/rfc-77/maputil.c 2011-11-21 13:25:43 UTC (rev 12789)
+++ sandbox/sdlime/rfc-77/maputil.c 2011-11-22 04:40:18 UTC (rev 12790)
@@ -566,64 +566,77 @@
return(-1); /* no match */
-char *msShapeGetAnnotation(layerObj *layer, shapeObj *shape)
+int msShapeGetAnnotation(layerObj *layer, shapeObj *shape)
- char *tmpstr=NULL;
+ char *tmpstr;
+ int i, j;
- if(layer->class[shape->classindex]->text.string) { /* test for global label first */
- switch(layer->class[shape->classindex]->text.type) {
- case(MS_STRING):
- char *target=NULL;
- tokenListNodeObjPtr node=NULL;
- tokenListNodeObjPtr nextNode=NULL;
+ /* RFC 77 TODO: check and throw some errors here... */
+ if(!layer || !shape) return MS_FAILURE;
- tmpstr = msStrdup(layer->class[shape->classindex]->text.string);
+ j = shape->classindex;
+ for(i=0; i<layer->class[j].numlabels; i++) {
- node = layer->class[shape->classindex]->text.tokens;
- if(node) {
- while(node != NULL) {
- nextNode = node->next;
- if(node->token == MS_TOKEN_BINDING_DOUBLE || node->token == MS_TOKEN_BINDING_INTEGER || node->token == MS_TOKEN_BINDING_STRING || node->token == MS_TOKEN_BINDING_TIME) {
- target = (char *) msSmallMalloc(strlen(node->tokenval.bindval.item) + 3);
- sprintf(target, "[%s]", node->tokenval.bindval.item);
- tmpstr = msReplaceSubstring(tmpstr, target, shape->values[node->tokenval.bindval.index]);
- msFree(target);
- node = nextNode;
+ /* RFC 77 TODO: will evaluate label expressions here... */
+ tmpstr = NULL; /* initialize */
+ if(layer->class[j]->text.string) { /* RFC 77 TODO: will check for a label text value first, then class text and finally try labelitem */
+ switch(layer->class[j]->text.type) {
+ case(MS_STRING):
+ char *target=NULL;
+ tokenListNodeObjPtr node=NULL;
+ tokenListNodeObjPtr nextNode=NULL;
+ tmpstr = msStrdup(layer->class[j]->text.string);
+ node = layer->class[j]->text.tokens;
+ if(node) {
+ while(node != NULL) {
+ nextNode = node->next;
+ if(node->token == MS_TOKEN_BINDING_DOUBLE || node->token == MS_TOKEN_BINDING_INTEGER || node->token == MS_TOKEN_BINDING_STRING || node->token == MS_TOKEN_BINDING_TIME) {
+ target = (char *) msSmallMalloc(strlen(node->tokenval.bindval.item) + 3);
+ sprintf(target, "[%s]", node->tokenval.bindval.item);
+ tmpstr = msReplaceSubstring(tmpstr, target, shape->values[node->tokenval.bindval.index]);
+ msFree(target);
+ node = nextNode;
- break;
- case(MS_EXPRESSION):
- int status;
- parseObj p;
+ break;
+ case(MS_EXPRESSION):
+ int status;
+ parseObj p;
- p.shape = shape;
- p.expr = &(layer->class[shape->classindex]->text);
- p.expr->curtoken = p.expr->tokens; /* reset */
- p.type = MS_PARSE_TYPE_STRING;
+ p.shape = shape;
+ p.expr = &(layer->class[j]->text);
+ p.expr->curtoken = p.expr->tokens; /* reset */
+ p.type = MS_PARSE_TYPE_STRING;
- status = yyparse(&p);
+ status = yyparse(&p);
- if (status != 0) {
- msSetError(MS_PARSEERR, "Failed to process text expression: %s", "msShapeGetAnnotation", layer->class[shape->classindex]->text.string);
- return NULL;
+ if (status != 0) {
+ msSetError(MS_PARSEERR, "Failed to process text expression: %s", "msShapeGetAnnotation", layer->class[c]->text.string);
+ tmpstr = p.result.strval;
+ break;
- tmpstr = p.result.strval;
+ default:
break;
- default:
- break;
+ } else {
+ if (shape->values && layer->labelitemindex >= 0)
+ tmpstr = msStrdup(shape->values[layer->labelitemindex]);
- } else {
- if (shape->values && layer->labelitemindex >= 0)
- tmpstr = msStrdup(shape->values[layer->labelitemindex]);
+ shape->text[i] = tmpstr;
- return(tmpstr);
/* Check if the shape is enough big to be drawn with the
More information about the mapserver-commits
