[mapserver-commits] r12807 - trunk/mapserver
Sat Nov 26 06:56:37 EST 2011
Author: tbonfort
Date: 2011-11-26 03:56:37 -0800 (Sat, 26 Nov 2011)
New Revision: 12807
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapdraw.c
   trunk/mapserver/mapdummyrenderer.c
   trunk/mapserver/mapprimitive.c
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/maputil.c
Add stable hatch rendering (#3847)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/HISTORY.TXT	2011-11-26 11:56:37 UTC (rev 12807)
@@ -14,6 +14,7 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Add stable hatch rendering (#3847)
 - Added vector field rendering (#4094)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/mapagg.cpp	2011-11-26 11:56:37 UTC (rev 12807)
@@ -37,7 +37,6 @@
 #include "renderers/agg/include/agg_math_stroke.h"
 #include "renderers/agg/include/agg_scanline_p.h"
 #include "renderers/agg/include/agg_scanline_u.h"
-#include "renderers/agg/include/agg_scanline_bin.h"
 #include "renderers/agg/include/agg_rasterizer_scanline_aa.h"
 #include "renderers/agg/include/agg_span_pattern_rgba.h"
 #include "renderers/agg/include/agg_span_allocator.h"
@@ -54,8 +53,6 @@
 #include "renderers/agg/include/agg_ellipse.h"
 #include "renderers/agg/include/agg_gamma_functions.h"
-#include "renderers/agg/include/agg_scanline_boolean_algebra.h"
-#include "renderers/agg/include/agg_scanline_storage_aa.h"
 #include "renderers/agg/include/agg_rasterizer_outline_aa.h"
 #include "renderers/agg/include/agg_renderer_outline_aa.h"
 #include "renderers/agg/include/agg_renderer_outline_image.h"
@@ -147,7 +144,6 @@
     than the perimeter, in number of pixels*/
    mapserver::scanline_u8 sl_line; /*unpacked scanlines, works faster if the area is roughly
     equal to the perimeter, in number of pixels*/
-   mapserver::scanline_bin m_sl_bin;
    bool use_alpha;
@@ -156,7 +152,6 @@
 template<class VertexSource>
 static void applyCJC(VertexSource &stroke, int caps, int joins) {
    switch (joins) {
-      case MS_CJC_NONE:
       case MS_CJC_ROUND:
          stroke.line_join(mapserver::round_join);
          break;
@@ -164,6 +159,7 @@
          stroke.line_join(mapserver::miter_join);
          break;
       case MS_CJC_BEVEL:
+      case MS_CJC_NONE:
          stroke.line_join(mapserver::bevel_join);
          break;
@@ -200,8 +196,12 @@
    if (style->patternlength <= 0) {
       mapserver::conv_stroke<line_adaptor> stroke(lines);
       stroke.width(style->width);
-      if(style->width>1)
+      if(style->width>1) {
          applyCJC(stroke, style->linecap, style->linejoin);
+      } else {
+         stroke.inner_join(mapserver::inner_bevel);
+         stroke.line_join(mapserver::bevel_join);
       r->m_rasterizer_aa.add_path(stroke);
    } else {
       mapserver::conv_dash<line_adaptor> dash(lines);
@@ -221,8 +221,12 @@
          dash.dash_start(patt_length - style->patternoffset);
       stroke_dash.width(style->width);
          applyCJC(stroke_dash, style->linecap, style->linejoin);
+      } else {
+         stroke_dash.inner_join(mapserver::inner_bevel);
+         stroke_dash.line_join(mapserver::bevel_join);
       r->m_rasterizer_aa.add_path(stroke_dash);
    mapserver::render_scanlines(r->m_rasterizer_aa, r->sl_line, r->m_renderer_scanline);
@@ -902,25 +906,34 @@
 // Function to create a custom hatch symbol based on an arbitrary angle.
-static mapserver::path_storage createHatch(int sx, int sy, double angle, double step)
+static mapserver::path_storage createHatch(double ox, double oy,
+      double rx, double ry,
+      int sx, int sy, double angle, double step)
     mapserver::path_storage path;
-    //path.start_new_path();
-    //restrict the angle to [0 180[
+    //restrict the angle to [0 180[, i.e ]-pi/2,pi/2] in radians
     angle = fmod(angle, 360.0);
     if(angle < 0) angle += 360;
     if(angle >= 180) angle -= 180;
     //treat 2 easy cases which would cause divide by 0 in generic case
     if(angle==0) {
-        for(double y=step/2.0;y<sy;y+=step) {
+       double y0 = step-fmod(oy-ry,step);
+       if((oy - ry) < 0) {
+          y0 -= step;
+        for(double y=y0; y<sy; y+=step) {
             path.move_to(0,y);
             path.line_to(sx,y);
         return path;
     if(angle==90) {
-        for(double x=step/2.0;x<sx;x+=step) {
+        double x0 = step-fmod(ox-rx,step);
+        if((ox - rx) < 0) {
+           x0 -= step;
+        for(double x=x0; x<sx; x+=step) {
             path.move_to(x,0);
             path.line_to(x,sy);
@@ -928,16 +941,39 @@
-    double theta = (90-angle)*MS_DEG_TO_RAD;
+    double theta = (90-angle)*MS_DEG_TO_RAD; /* theta in ]-pi/2 , pi/2] */
     double ct = cos(theta);
     double st = sin(theta);
-    double rmax = sqrt((double)sx*sx+sy*sy);
+    double invct = 1.0/ct;
+    double invst = 1.0/st;
+    double r0; /* distance from first hatch line to the top-left (if angle in  0,pi/2)
+                  or bottom-left (if angle in -pi/2,0) corner of the hatch bbox */
+    double rmax = sqrt(sx*sx+sy*sy); /* distance to the furthest hatch we will have to create
+TODO: this could be optimized for bounding boxes where width is very different than height for
+certain hatch angles */
+    double rref= rx*ct + ry*st; /* distance to the line passing through the refpoint, origin is
+                                   (0,0) of the imageObj */
+    double rcorner; /* distance to the line passing through the topleft or bottomleft corner
+                       of the hatch bbox (origin is (0,0) of imageObj) */
+    /* calculate the distance from the refpoint to the top right of the path */
+    if(angle < 90) {
+       rcorner = ox*ct + oy*st;
+       r0 = step - fmod(rcorner-rref,step);
+       if(rcorner-rref<0) r0 -= step;
+    } else {
+       rcorner = ox*ct + (oy+sy)*st;
+       st = -st;
     //parametrize each line as r = x.cos(theta) + y.sin(theta)
-    for(double r=(angle<90)?step/2.:-rmax;r<rmax;r+=step) {
+    for(double r=r0;r<rmax;r+=step) {
         int inter=0;
         double x,y;
-        double pt[8]; //array to store the coordinates of intersection of the line with the sides
+        double pt[4]; //array to store the coordinates of intersection of the line with the sides
         //in the general case there will only be two intersections
         //so pt[4] should be sufficient to store the coordinates of the intersection,
         //but we allocate pt[8] to treat the special and rare/unfortunate case when the
@@ -947,154 +983,124 @@
         //test for intersection with each side
-        y=r/st;x=0; // test for intersection with top of image
+        y=r*invst;x=0; // test for intersection with left of image
         if(y>=0&&y<=sy) {
             pt[2*inter]=x;pt[2*inter+1]=y;
             inter++;
-        x=sx;y=(r-sx*ct)/st;// test for intersection with bottom of image
+        x=sx;y=(r-sx*ct)*invst;// test for intersection with right of image
         if(y>=0&&y<=sy) {
             inter++;
-        y=0;x=r/ct;// test for intersection with left of image
-        if(x>=0&&x<=sx) {
-            pt[2*inter]=x;pt[2*inter+1]=y;
-            inter++;
+        if(inter<2) {
+           y=0;x=r*invct;// test for intersection with top of image
+           if(x>=0&&x<=sx) {
+              pt[2*inter]=x;pt[2*inter+1]=y;
+              inter++;
-        y=sy;x=(r-sy*st)/ct;// test for intersection with right of image
-        if(x>=0&&x<=sx) {
-            inter++;
+        if(inter<2) {
+           y=sy;x=(r-sy*st)*invct;// test for intersection with bottom of image
+           if(x>=0&&x<=sx) {
+              inter++;
         if(inter==2 && (pt[0]!=pt[2] || pt[1]!=pt[3])) {
             //the line intersects with two sides of the image, it should therefore be drawn
-            path.move_to(pt[0],pt[1]);
-            path.line_to(pt[2],pt[3]);
+            if(angle<90) {
+              path.move_to(pt[0],pt[1]);
+              path.line_to(pt[2],pt[3]);
+            } else {
+              path.move_to(pt[0],sy-pt[1]);
+              path.line_to(pt[2],sy-pt[3]);
     return path;
-int agg2RenderPolygonHatched(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color) {
-   msComputeBounds(poly);
-    * we create a hatch pattern that is the size of the shapeObj's bounds, expanded by the width
-    * of the stroke we want to apply to the lines to account for end-caps artifacts
-   int pw=(int)(poly->bounds.maxx-poly->bounds.minx+width*2)+1;
-   int ph=(int)(poly->bounds.maxy-poly->bounds.miny+width*2)+1;
-   //create a rectangular hatch of size pw,ph starting at 0,0
-   //the created hatch is of the size of the shape's bounding box
-   mapserver::path_storage hatch = createHatch(pw,ph,angle,spacing);
-   //translate the hatch so it overlaps the current shape
-   hatch.transform(mapserver::trans_affine_translation(poly->bounds.minx-width,poly->bounds.miny-width));
-   //render the hatch clipped by the shape
-   polygon_adaptor polygons(poly);
-	AGG2Renderer *r = AGG_RENDERER(img);
-   mapserver::rasterizer_scanline_aa<> ras1,ras2;
-   mapserver::scanline_storage_aa8 storage;
-   mapserver::scanline_storage_aa8 storage1;
-   mapserver::scanline_storage_aa8 storage2;
-   mapserver::scanline_p8 sl1,sl2;
-   ras1.filling_rule(mapserver::fill_non_zero);
-   if(patternlength>1) {
-      //dash the hatch and render it clipped by the shape
-      mapserver::conv_dash<mapserver::path_storage > dash(hatch);
-      mapserver::conv_stroke<mapserver::conv_dash<mapserver::path_storage> > stroke(dash);
-      for (int i=0; i<patternlength; i+=2) {
-         if (i < patternlength-1) {
-            dash.add_dash(pattern[i], pattern[i+1]);
-      stroke.width(width);
-      stroke.line_cap(mapserver::butt_cap);
-      ras1.add_path(stroke);
+template<class VertexSource> void renderPolygonHatches(imageObj *img,VertexSource &clipper, colorObj *color) {
+   if(img->format->renderer == MS_RENDER_WITH_AGG) {
+      AGG2Renderer *r = AGG_RENDERER(img);
+      r->m_rasterizer_aa_gamma.reset();
+      r->m_rasterizer_aa_gamma.filling_rule(mapserver::fill_non_zero);
+      r->m_rasterizer_aa_gamma.add_path(clipper);
+      r->m_renderer_scanline.color(aggColor(color));
+      mapserver::render_scanlines(r->m_rasterizer_aa_gamma, r->sl_poly, r->m_renderer_scanline);
    } else {
-      mapserver::conv_stroke <mapserver::path_storage > stroke(hatch);
-   mapserver::render_scanlines(ras1, r->sl_line, storage1);
-   ras2.filling_rule(mapserver::fill_even_odd);
-   ras2.add_path(polygons);
-   mapserver::render_scanlines(ras2,r->sl_poly,storage2);
-   mapserver::sbool_combine_shapes_aa(mapserver::sbool_and, storage1, storage2, sl1, sl2, r->sl_line, storage);
-   r->m_renderer_scanline.color(aggColor(color));
-   mapserver::render_scanlines ( storage, r->sl_poly, r->m_renderer_scanline );
-   return MS_SUCCESS;
-template<class VertexSource> void renderPolygonHatches(imageObj *img,VertexSource &clipper, colorObj *color) {
-   shapeObj shape;
-   msInitShape(&shape);
-   int allocated = 20;
-   lineObj line;
-   shape.line = &line;
-   shape.numlines = 1;
-   shape.line[0].point = (pointObj*)msSmallCalloc(allocated,sizeof(pointObj));
-   shape.line[0].numpoints = 0;
-   double x=0,y=0;
-   unsigned int cmd;
-   while((cmd = clipper.vertex(&x,&y)) != mapserver::path_cmd_stop) {
-      switch(cmd) {
-      case mapserver::path_cmd_line_to:
-         if(shape.line[0].numpoints == allocated) {
-            allocated *= 2;
-            shape.line[0].point = (pointObj*)msSmallRealloc(shape.line[0].point, allocated*sizeof(pointObj));
+      shapeObj shape;
+      msInitShape(&shape);
+      int allocated = 20;
+      lineObj line;
+      shape.line = &line;
+      shape.numlines = 1;
+      shape.line[0].point = (pointObj*)msSmallCalloc(allocated,sizeof(pointObj));
+      shape.line[0].numpoints = 0;
+      double x=0,y=0;
+      unsigned int cmd;
+      clipper.rewind(0);
+      while((cmd = clipper.vertex(&x,&y)) != mapserver::path_cmd_stop) {
+         switch(cmd) {
+            case mapserver::path_cmd_line_to:
+               if(shape.line[0].numpoints == allocated) {
+                  allocated *= 2;
+                  shape.line[0].point = (pointObj*)msSmallRealloc(shape.line[0].point, allocated*sizeof(pointObj));
+               shape.line[0].point[shape.line[0].numpoints].x = x;
+               shape.line[0].point[shape.line[0].numpoints].y = y;
+               shape.line[0].numpoints++;
+               break;
+            case mapserver::path_cmd_move_to:
+               shape.line[0].point[0].x = x;
+               shape.line[0].point[0].y = y;
+               shape.line[0].numpoints = 1;
+               break;
+            case mapserver::path_cmd_end_poly|mapserver::path_flags_close:
+               if(shape.line[0].numpoints > 2) {
+                  MS_IMAGE_RENDERER(img)->renderPolygon(img,&shape,color);
+               break;
+            default:
+               assert(0); //WTF?
-         shape.line[0].point[shape.line[0].numpoints].x = x;
-         shape.line[0].point[shape.line[0].numpoints].y = y;
-         shape.line[0].numpoints++;
-         break;
-      case mapserver::path_cmd_move_to:
-         shape.line[0].point[0].x = x;
-         shape.line[0].point[0].y = y;
-         shape.line[0].numpoints = 1;
-         break;
-      case mapserver::path_cmd_end_poly|mapserver::path_flags_close:
-         if(shape.line[0].numpoints > 2) {
-            MS_IMAGE_RENDERER(img)->renderPolygon(img,&shape,color);
-         break;
-      default:
-         assert(0); //WTF?
+      free(shape.line[0].point);
-   free(shape.line[0].point);
 int msHatchPolygon(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color) {
    assert(MS_RENDERER_PLUGIN(img->format));
-   mapserver::path_storage lines = createHatch(pw,ph, angle, spacing);
-   lines.transform(mapserver::trans_affine_translation(poly->bounds.minx-width,poly->bounds.miny-width));
+   /* amount we should expand the bounding box by */
+   double exp = width * 0.7072;
+   /* width and height of the bounding box we will be creating the hatch in */
+   int pw=(int)(poly->bounds.maxx-poly->bounds.minx+exp*2)+1;
+   int ph=(int)(poly->bounds.maxy-poly->bounds.miny+exp*2)+1;
+   /* position of the top-left corner of the bounding box */
+   double ox = poly->bounds.minx - exp;
+   double oy = poly->bounds.miny - exp;
+   //create a rectangular hatch of size pw,ph starting at 0,0
+   //the created hatch is of the size of the shape's bounding box
+   mapserver::path_storage hatch = createHatch(ox,oy,
+         img->refpt.x,img->refpt.y,pw,ph,angle,spacing);
+   if(hatch.total_vertices()<=0) return MS_SUCCESS;
+   //translate the hatch so it overlaps the current shape
+   hatch.transform(mapserver::trans_affine_translation(ox,oy));
-      mapserver::conv_dash<mapserver::path_storage > dash(lines);
+      mapserver::conv_dash<mapserver::path_storage > dash(hatch);
@@ -1104,15 +1110,13 @@
       mapserver::conv_clipper<polygon_adaptor,mapserver::conv_stroke<mapserver::conv_dash<mapserver::path_storage> > > clipper(polygons,stroke, mapserver::clipper_and);
-      clipper.rewind(0);
       renderPolygonHatches(img,clipper,color);
    } else {
-      mapserver::conv_stroke <mapserver::path_storage > stroke(lines);
+      mapserver::conv_stroke <mapserver::path_storage > stroke(hatch);
       mapserver::conv_clipper<polygon_adaptor,mapserver::conv_stroke<mapserver::path_storage> > clipper(polygons,stroke, mapserver::clipper_and);
@@ -1136,7 +1140,6 @@
    renderer->renderPolygon = &agg2RenderPolygon;
    renderer->renderPolygonTiled = &agg2RenderPolygonTiled;
-   renderer->renderPolygonHatched = &agg2RenderPolygonHatched;
    renderer->renderLineTiled = &agg2RenderLineTiled;
    renderer->renderGlyphs = &agg2RenderGlyphs;
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/mapdraw.c	2011-11-26 11:56:37 UTC (rev 12807)
@@ -246,6 +246,9 @@
         GET_LAYER(map, i)->scalefactor = map->resolution/map->defresolution;
+    image->refpt.x = MS_MAP2IMAGE_X_IC_DBL(0, map->extent.minx, 1.0/map->cellsize);
+    image->refpt.y = MS_MAP2IMAGE_Y_IC_DBL(0, map->extent.maxy, 1.0/map->cellsize);
     return image;
Modified: trunk/mapserver/mapdummyrenderer.c
--- trunk/mapserver/mapdummyrenderer.c	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/mapdummyrenderer.c	2011-11-26 11:56:37 UTC (rev 12807)
@@ -254,7 +254,6 @@
     renderer->cleanup = &cleanupDummy;
     renderer->startShape = NULL;
     renderer->endShape = NULL;
-    renderer->renderPolygonHatched = NULL;
     return MS_SUCCESS;
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/mapprimitive.c	2011-11-26 11:56:37 UTC (rev 12807)
@@ -204,8 +204,7 @@
         break;
-  if(i == shape->numlines)
-     return; /* no lines inside the shape contain any points */
+  if(i == shape->numlines) return;
   for( i=0; i<shape->numlines; i++ ) {
     for( j=0; j<shape->line[i].numpoints; j++ ) {
@@ -832,6 +831,7 @@
     pointObj *point;
     double inv_cs = 1.0 / cellsize; /* invert and multiply much faster */
     if(shape->numlines == 0) return; /* nothing to transform */
+    int ok = 0;
     if(shape->type == MS_SHAPE_LINE) {
@@ -870,8 +870,11 @@
                 shape->line[i].numpoints=k;
             /* skip degenerate line once more */
-            if(shape->line[i].numpoints<2)
+            if(shape->line[i].numpoints<2) {
                shape->line[i].numpoints=0;
+            } else {
+               ok = 1; /* we have at least one line with more than two points */
     else if(shape->type == MS_SHAPE_POLYGON) {
@@ -907,6 +910,7 @@
             point[k].x = MS_MAP2IMAGE_X_IC_DBL(point[j].x, extent.minx, inv_cs);
             point[k].y = MS_MAP2IMAGE_Y_IC_DBL(point[j].y, extent.maxy, inv_cs);
             shape->line[i].numpoints=k+1;
+            ok = 1;
     else { /* only for untyped shapes, as point layers don't go through this function */
@@ -917,7 +921,11 @@
                 point[j].y = MS_MAP2IMAGE_Y_IC_DBL(point[j].y, extent.maxy, inv_cs);
+        ok = 1;
+    if(!ok) {
+       shape->numlines = 0 ;
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/maprendering.c	2011-11-26 11:56:37 UTC (rev 12807)
@@ -642,11 +642,7 @@
                pattern[i] = style->pattern[i]*width/style->width;
-            if(renderer->renderPolygonHatched) {
-               ret = renderer->renderPolygonHatched(image,offsetPolygon,spacing,width,pattern,style->patternlength,style->angle, &style->color);
-            } else {
-               ret = msHatchPolygon(image,offsetPolygon,spacing,width,pattern,style->patternlength,style->angle, &style->color);
+            ret = msHatchPolygon(image,offsetPolygon,spacing,width,pattern,style->patternlength,style->angle, &style->color);
             goto cleanup;
          else {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/mapserver.h	2011-11-26 11:56:37 UTC (rev 12807)
@@ -1632,6 +1632,7 @@
     unsigned char *raw_byte;
   } img;
   ms_bitarray  img_mask;
+  pointObj refpt;
 #endif
 } imageObj;
@@ -2678,7 +2679,6 @@
 	int (*renderLine)(imageObj *img, shapeObj *p, strokeStyleObj *style);
 	int (*renderPolygon)(imageObj *img, shapeObj *p, colorObj *color);
 	int (*renderPolygonTiled)(imageObj *img, shapeObj *p, imageObj *tile);
-	int (*renderPolygonHatched)(imageObj *img, shapeObj *poly, double spacing, double width, double *pattern, int patternlength, double angle, colorObj *color);
 	int (*renderLineTiled)(imageObj *img, shapeObj *p, imageObj *tile);
 	int (*renderBitmapGlyphs)(imageObj *img, double x, double y,
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2011-11-25 20:59:20 UTC (rev 12806)
+++ trunk/mapserver/maputil.c	2011-11-26 11:56:37 UTC (rev 12807)
@@ -1465,8 +1465,6 @@
             image->imagepath = msStrdup(imagepath);
         if (imageurl)
             image->imageurl = msStrdup(imageurl);
-        return image;
     else if( MS_RENDERER_RAWDATA(format) )
@@ -1551,8 +1549,6 @@
                 memset( image->img.raw_byte, nv, i );
-        return image;
     else if( MS_RENDERER_IMAGEMAP(format) )
@@ -1570,7 +1566,7 @@
     if(!image)
         msSetError(MS_GDERR, "Unable to initialize image.", "msImageCreate()");
+    image->refpt.x = image->refpt.y = 0;
     return image;
