[mapserver-commits] r12645 - trunk/docs/en/mapfile
Sat Oct 8 05:08:07 EDT 2011
Author: havatv
Date: 2011-10-08 02:08:07 -0700 (Sat, 08 Oct 2011)
New Revision: 12645
   trunk/docs/en/mapfile/xmp_metadata.txt
Fixed som typos (xml_<namespace> -> xmp_<namespace>) and some formatting in the new xmp_metadata document (xmp support added in #3932).  One more fix.
Modified: trunk/docs/en/mapfile/xmp_metadata.txt
--- trunk/docs/en/mapfile/xmp_metadata.txt	2011-10-08 09:02:00 UTC (rev 12644)
+++ trunk/docs/en/mapfile/xmp_metadata.txt	2011-10-08 09:08:07 UTC (rev 12645)
@@ -52,7 +52,7 @@
 the `exempi` library on your system.
 1. Download libexempi from
-   http://libopenraw.freedesktop.org/wiki/Exempi
+   `http://libopenraw.freedesktop.org/wiki/Exempi`_
 2. Configure MapServer using the `--with-exempi` option, and re-build
@@ -131,6 +131,7 @@
 document.  The following tags can then reference the namespace the same
 way they reference the default namespaces.
+.. _http://libopenraw.freedesktop.org/wiki/Exempi: http://libopenraw.freedesktop.org/wiki/Exempi
 .. _meta: http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#xmp
 .. _cc: http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#cc
 .. _dc: http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/XMP.html#dc
