[mapserver-commits] r12646 - branches/branch-6-0/docs/en/cgi
trunk/docs/en/cgi
svn at osgeo.org
svn at osgeo.org
Sat Oct 8 06:18:53 EDT 2011
Author: havatv
Date: 2011-10-08 03:18:53 -0700 (Sat, 08 Oct 2011)
New Revision: 12646
branches/branch-6-0/docs/en/cgi/controls.txt
branches/branch-6-0/docs/en/cgi/runsub.txt
trunk/docs/en/cgi/controls.txt
trunk/docs/en/cgi/runsub.txt
Added documentation of the runtime substitution parameters FORMATOPTION FILENAME and CLASS TEXT to runsub, and fixed the link to controls (#3751).
Modified: branches/branch-6-0/docs/en/cgi/controls.txt
--- branches/branch-6-0/docs/en/cgi/controls.txt 2011-10-08 09:08:07 UTC (rev 12645)
+++ branches/branch-6-0/docs/en/cgi/controls.txt 2011-10-08 10:18:53 UTC (rev 12646)
@@ -463,6 +463,8 @@
.. index::
single: Change map file parameters
+.. _cgi_mapfile_change_parameters:
Changing map file parameters via a form or a URL
Modified: branches/branch-6-0/docs/en/cgi/runsub.txt
--- branches/branch-6-0/docs/en/cgi/runsub.txt 2011-10-08 09:08:07 UTC (rev 12645)
+++ branches/branch-6-0/docs/en/cgi/runsub.txt 2011-10-08 10:18:53 UTC (rev 12646)
@@ -1,3 +1,6 @@
+.. index::
+ single: Run-time substitution
.. _runsub:
@@ -7,8 +10,7 @@
:Author: Steve Lime
:Contact: steve.lime at DNR.STATE.MN.US
:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2005/12/12
+:Last Updated: $Date$
.. contents:: Table of Contents
:depth: 2
@@ -58,21 +60,42 @@
slight performance hit. Often you would set a default class to draw features
that don't match, but that is not required.
+.. index::
+ pair: Run-time substitution; Supported parameters
Parameters Supported
Not every mapfile parameter supports run-time substitution and care has been
taken to try and support those that make the most sense. Remember, you also can
do run-time configuration using the map_object_property type syntax detailed
-elsewhere (todo- add link). Below is a list of properties that do allow
+in :ref:`cgi_mapfile_change_parameters`.
+Below is a list of properties that do allow
run-time substitution (todo- add MapServer version):
+* CLASS: EXPRESSION
+* CLASS: TEXT
+ .. versionadded:: 6.0
+* LAYER: CONNECTION
* LAYER: DATA (must validate against DATAPATTERN)
-* LAYER: TILEINDEX
-* LAYER: CONNECTION
* LAYER: FILTER
-* CLASS: EXPRESSION
+* LAYER: TILEINDEX
+* OUTPUTFORMAT: FORMATOPTION: FILENAME (must have a `MAP` `VALIDATION`
+ pattern)
+ .. versionadded:: 6.2
+.. index::
+ pair: Run-time substitution; FILTER
FILTERs
Modified: trunk/docs/en/cgi/controls.txt
--- trunk/docs/en/cgi/controls.txt 2011-10-08 09:08:07 UTC (rev 12645)
+++ trunk/docs/en/cgi/controls.txt 2011-10-08 10:18:53 UTC (rev 12646)
@@ -463,6 +463,8 @@
.. index::
Modified: trunk/docs/en/cgi/runsub.txt
--- trunk/docs/en/cgi/runsub.txt 2011-10-08 09:08:07 UTC (rev 12645)
+++ trunk/docs/en/cgi/runsub.txt 2011-10-08 10:18:53 UTC (rev 12646)
@@ -1,3 +1,6 @@
+.. index::
.. _runsub:
@@ -7,8 +10,7 @@
:Author: Steve Lime
-:Date: $Date$
:depth: 2
@@ -58,21 +60,42 @@
+.. index::
+* CLASS: TEXT
-* LAYER: TILEINDEX
* LAYER: FILTER
+* LAYER: TILEINDEX
+ pattern)
+.. index::
FILTERs
More information about the mapserver-commits
