[mapserver-commits] r12720 - trunk/docs/en/mapfile
Sat Oct 29 08:44:03 EDT 2011
Author: havatv
Date: 2011-10-29 05:44:02 -0700 (Sat, 29 Oct 2011)
New Revision: 12720
   trunk/docs/en/mapfile/style.txt
Documentation of initialgap (new) and gap (improved) (#3879 and #3867)
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-10-28 14:43:13 UTC (rev 12719)
+++ trunk/docs/en/mapfile/style.txt	2011-10-29 12:44:02 UTC (rev 12720)
@@ -129,16 +129,17 @@
     specified for the :ref:`LAYER`), `GAP` specifies the distance in
     layer `SIZEUNITS` at the map scale 1:`SYMBOLSCALEDENOM`.
-    - For lines, the first symbol will be placed `GAP`/2 from the
-      start of the line.
+    - For lines, if `INITIALGAP` is not specified, the first symbol
+      will be placed `GAP`/2 from the start of the line.
     - For lines, a negative `GAP` value will cause the symbols' X axis
       to be aligned relative to the tangent of the line.
     - For lines, a positive `GAP` value aligns the symbols' X axis
       relative to the X axis of the output device.
     - For lines, a `GAP` of 0 (the default value) will cause the symbols
       to be rendered edge to edge
-    - For polygons, a missing `GAP` or a `GAP` of 0 will cause the
-      symbols to be rendered edge to edge.
+    - For polygons, a missing `GAP` or a `GAP` of less than or equal
+      to the size of the symbol will cause the symbols to be rendered
+      edge to edge.
     Symbols can be rotated using `ANGLE`.
@@ -149,9 +150,8 @@
       The behaviour of `GAP` has not been stable over time.  It has
       specified the amount of space between the symbols, and also
       something in between the amount of space between the symbols and
-      the center to center distance.  The goal is to have `GAP`
-      specify the center to center distance, but in version 6.0 it is
-      the amount of space between the symbols that is specified.
+      the center to center distance.  Since 6.2 `GAP` specifies the
+      center to center distance between the symbols.
 .. index::
    pair: STYLE; GEOMTRANSFORM
@@ -178,6 +178,53 @@
       angle formed by the two adjacent line segments.
 .. index::
+   pair: STYLE; INITIALGAP
+INITIALGAP [double]
+    `INITIALGAP` is useful for styling dashed lines.
+    If used with `GAP`, `INITIALGAP` specifies the distance to the
+    first symbol on a styled line.
+    If used with `PATTERN`, `INITIALGAP` specifies the distance to
+    the first dash on a dashed line.
+    Example 1 - dashed line styled with circles:
+    .. code-block:: mapfile
+      STYLE
+        COLOR 0 0 0
+        WIDTH 4
+        PATTERN 40 10 END
+      END
+      STYLE
+        SYMBOL "circlef"
+        COLOR 0 0 0
+        SIZE 8
+        INITIALGAP 20
+        GAP 50
+      END
+    Example 1 - dashed line styled with dashed line overlay:
+      STYLE
+        COLOR 0 0 0
+        WIDTH 6
+        PATTERN 40 10
+      END
+      STYLE
+        COLOR 255 255 255
+        WIDTH 4
+        INITIALGAP 2
+        PATTERN 36 14
+      END
+    .. versionadded:: 6.2
+.. index::
    pair: STYLE; LINECAP
 LINECAP [butt|round|square]
