[mapserver-commits] r12721 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Sat Oct 29 16:00:25 EDT 2011
Author: havatv
Date: 2011-10-29 13:00:25 -0700 (Sat, 29 Oct 2011)
New Revision: 12721
trunk/docs/en/mapfile/symbol.txt
Added documentation of the new parameter ANCHORPOINT to the symbol document (#4066)
Modified: trunk/docs/en/mapfile/symbol.txt
--- trunk/docs/en/mapfile/symbol.txt 2011-10-29 12:44:02 UTC (rev 12720)
+++ trunk/docs/en/mapfile/symbol.txt 2011-10-29 20:00:25 UTC (rev 12721)
@@ -31,6 +31,32 @@
.. index::
+ pair: ANCHORPOINT; SYMBOL
+ANCHORPOINT [x] [y]
+ Used to specify the location (within the symbol) that is to be
+ used as an anchorpoint when rotating the symbol and placing the
+ symbol on a map. Default is **0.5 0.5** (corresponding to the
+ center of the symbol).
+ `x`: A double in the range [0,1] that specifies the location
+ within the symbol along the x axis. 0 specifies the left edge
+ of the symbol, 1 specifies the right edge of the symbol. 0.5
+ specifies the center of the symbol (in the x direction).
+ `y`: A double in the range [0,1] that specifies the location
+ within the symbol along the y axis. 0 specifies the top edge of
+ the symbol, 1 specifies the lower edge of the symbol. 0.5
+ specifies the center of the symbol (in the y direction).
+ `ANCHORPOINT` can be used with `SYMBOL`\s of `TYPE` `ellipse`,
+ `pixmap`, `truetype` and `vector`. To ensure proper behaviour for
+ vector symbols, the left and top edges of the bounding box of the
+ symbol should be at 0.
+ .. versionadded:: 6.2
+.. index::
pair: ANTIALIAS; SYMBOL
ANTIALIAS [true|false]
More information about the mapserver-commits
