[mapserver-commits] r12722 - branches/branch-6-0/docs/en/mapfile
trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Sun Oct 30 05:17:52 EDT 2011
Author: havatv
Date: 2011-10-30 02:17:52 -0700 (Sun, 30 Oct 2011)
New Revision: 12722
branches/branch-6-0/docs/en/mapfile/map.txt
trunk/docs/en/mapfile/map.txt
Modified the description of IMAGETYPE in the map document to reflect the rendering changes in 6.0 (#3918).
Modified: branches/branch-6-0/docs/en/mapfile/map.txt
--- branches/branch-6-0/docs/en/mapfile/map.txt 2011-10-29 20:00:25 UTC (rev 12721)
+++ branches/branch-6-0/docs/en/mapfile/map.txt 2011-10-30 09:17:52 UTC (rev 12722)
@@ -285,11 +285,11 @@
.. _imagetype:
-IMAGETYPE [gif|png|jpeg|wbmp|gtiff|swf|userdefined]
- Output format to generate. See details in the :ref:`OUTPUTFORMAT`
- section for available formats. The name here must match the 'NAME'
- of a user defined or internally generated :ref:`OUTPUTFORMAT`
- section.
+IMAGETYPE [png|jpeg|pdf|...|userdefined]
+ Output format (raster or vector) to generate. The name used here
+ must match the 'NAME' of a user defined or internally available
+ :ref:`OUTPUTFORMAT`. For a complete list of available
+ `IMAGEFORMAT`\s, see the :ref:`OUTPUTFORMAT` section.
INTERLACE [on|off]
*Deprecated* Use **FORMATOPTION "INTERLACE=ON"** in the
Modified: trunk/docs/en/mapfile/map.txt
--- trunk/docs/en/mapfile/map.txt 2011-10-29 20:00:25 UTC (rev 12721)
+++ trunk/docs/en/mapfile/map.txt 2011-10-30 09:17:52 UTC (rev 12722)
.. _imagetype:
- section.
INTERLACE [on|off]
More information about the mapserver-commits
