[mapserver-commits] r12723 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Sun Oct 30 07:19:06 EDT 2011
Author: havatv
Date: 2011-10-30 04:19:06 -0700 (Sun, 30 Oct 2011)
New Revision: 12723
   branches/branch-6-0/docs/en/mapfile/symbol.txt
   trunk/docs/en/mapfile/symbol.txt
Modified the description of FILLED in the symbol document (polygon/line).
Modified: branches/branch-6-0/docs/en/mapfile/symbol.txt
--- branches/branch-6-0/docs/en/mapfile/symbol.txt	2011-10-30 09:17:52 UTC (rev 12722)
+++ branches/branch-6-0/docs/en/mapfile/symbol.txt	2011-10-30 11:19:06 UTC (rev 12723)
@@ -44,10 +44,18 @@
     to font character.
 FILLED [true|false]
-    Sets the symbol to be filled with a user defined color (See the
-    :ref:`STYLE` object). For marker symbols, if `OUTLINECOLOR` was
-    specified then the symbol is outlined with it.
+    If `true`, the symbol will be filled with a user defined color
+    (using :ref:`STYLE` `COLOR`).  Default is `false`.
+    If `true`, symbols of `TYPE` `ellipse` and `vector` will be
+    treated as polygons (fill color specified using :ref:`style`
+    `COLOR` and outline specified using :ref:`style` `OUTLINECOLOR`
+    and `WIDTH`).
+    If `false`, symbols of `TYPE` `ellipse` and `vector` will be
+    treated as lines (the lines can be given a color using
+    :ref:`style` `COLOR` and a width using :ref:`style` `WIDTH`).
 FONT [string]
     Name of TrueType font to use as defined in the :ref:`FONTSET`.
Modified: trunk/docs/en/mapfile/symbol.txt
--- trunk/docs/en/mapfile/symbol.txt	2011-10-30 09:17:52 UTC (rev 12722)
+++ trunk/docs/en/mapfile/symbol.txt	2011-10-30 11:19:06 UTC (rev 12723)
@@ -70,10 +70,18 @@
     to font character.
 FILLED [true|false]
+    and `WIDTH`).
 FONT [string]
