[mapserver-commits] r12725 - trunk/docs/en/mapfile/symbology
Sun Oct 30 18:57:52 EDT 2011
Author: havatv
Date: 2011-10-30 15:57:51 -0700 (Sun, 30 Oct 2011)
New Revision: 12725
   trunk/docs/en/mapfile/symbology/construction.txt
Update of the symbol construction document for version 6.2 (#3867, #3868, #3879, #4061, #4066) - small fix.
Modified: trunk/docs/en/mapfile/symbology/construction.txt
--- trunk/docs/en/mapfile/symbology/construction.txt	2011-10-30 22:18:21 UTC (rev 12724)
+++ trunk/docs/en/mapfile/symbology/construction.txt	2011-10-30 22:57:51 UTC (rev 12725)
@@ -1603,8 +1603,8 @@
 way as for pixmap symbols.  Precision is necessary to get nice
 symmetrical symbols.
-Both polygon (`FILL` `true`) and line (`FILL` `false`) vector symbols
-can be used.  For line symbols, the `WIDTH` parameter of the
+Both polygon (`FILLED` `true`) and line (`FILLED` `false`) vector
+symbols can be used.  For line symbols, the `WIDTH` parameter of the
 :ref:`style` will give the line width and the `SIZE` parameter will
 specify the height of the symbol.
@@ -1791,7 +1791,6 @@
   LAYER  # diagonal holes in yellow
     STATUS DEFAULT
     TYPE POLYGON
-    #OPACITY 50
     FEATURE
       POINTS
         55 80
@@ -1949,7 +1948,6 @@
   SYMBOL
     NAME "x-line"
     TYPE vector
-    #FILLED true
     POINTS
       0 0
       1 1
