[mapserver-commits] r12726 - branches/branch-6-0/docs/en/mapfile/symbology
Sun Oct 30 18:59:35 EDT 2011
Author: havatv
Date: 2011-10-30 15:59:35 -0700 (Sun, 30 Oct 2011)
New Revision: 12726
   branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
Fixed som errors in the symbol construction document (version 6.0)
Modified: branches/branch-6-0/docs/en/mapfile/symbology/construction.txt
--- branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-10-30 22:57:51 UTC (rev 12725)
+++ branches/branch-6-0/docs/en/mapfile/symbology/construction.txt	2011-10-30 22:59:35 UTC (rev 12726)
@@ -122,12 +122,24 @@
 - If the size is set in screen pixels, symbols look the same at all
   scales.
-MapServer implements the "screen pixels" size type for displaying
-cartographical elements.  "Real world units", as described above, can
-be achieved using the `SYMBOLSCALEDENOM` parameter of the
+The default behaviour of MapServer is to implement the "screen pixels"
+size type for displaying cartographical elements.
+"Real world units", as described above, can be achieved using either
+the `SIZEUNITS` or the `SYMBOLSCALEDENOM` parameter of the
 :ref:`layer`.
+- When `SIZEUNITS` is set (and is not `pixels`), symbol sizes are
+  specified in real world units (for instance meters).  For available
+  units, see the `SIZEUNIT` documentation.
+- When `SYMBOLSCALEDENOM` is set, the given symbols size is used for
+  the map scale 1:`SYMBOLSCALEDENOM`, for other scales, the symbols
+  are scaled proportionally.
+:ref:`style` `MAXSIZE` and `MINSIZE` limits the scaling of symbols.
 .. index::
    single: Symbol specification
@@ -226,23 +238,24 @@
 MapServer support raster output formats (e.g. PNG, JPEG and GIF) and
-vector output formats (e.g. PDF, SWG).  The raster formats (except for
-GIF) use anti-aliasing.  See :ref:`outputformat` for more.
+vector output formats (e.g. PDF, SVG).  The raster formats (except for
+GIF) use anti-aliasing.  See :ref:`outputformat` (and :ref:`map`
+`IMAGETYPE`) for more.
 Symbol units
 The units used for specifying dimensions is defined in the `SIZEUNITS`
-parameter of the :ref:`layer`.  `SIZEUNITS` can be `pixels`, `feet`,
-`inches`, `kilometers`, `meters`, `miles`, `dd` and `nauticalmiles`.
-The default is `pixels`.
+parameter of the :ref:`layer`.  The available units are listed there.
+The default unit is `pixels`.
 The `MAP` element's `RESOLUTION` and `DEFRESOLUTION` parameters will
-determine the actual scale of the resulting map and hence the size of
-the symbols on the map.  DEFRESOLUTION is by default 72 dpi (dots per
-inch).  If `RESOLUTION` is set to 144 (and `DEFRESOLUTION` is 72), all
-dimensions specified in the map file will be multiplied by 144/72 = 2.
-This can be used to produce higher resolution images.
+determine the resolution of the resulting map and hence the size in
+pixels of the symbols on the map.  `DEFRESOLUTION` is by default 72
+dpi (dots per inch).  If `RESOLUTION` is set to 144 (and
+`DEFRESOLUTION` is 72), all dimensions specified in the map file will
+be multiplied by 144/72 = 2.  This can be used to produce higher
+resolution images.
 Dimensions can be specified using decimals.
@@ -262,11 +275,13 @@
 symbols to the maximum and minimum size specified here (but does not
 affect the size calculations).
-When the scale changes, the elements (defined in :ref:`style`\s) of a
-composite cartographical symbol may change their positions relative to
-each other, especially at very small map scales (large scale
-denominators). They can also slightly change their shape when they are
-displayed as tiny little images.
+When symbols are scaled as the scale changes, the elements (defined in
+:ref:`style`\s) of a composite cartographical symbol may change their
+positions relative to each other.  This is due to rounding effects
+when creating the image.  The effect is most noticable at small scales
+(large scale denominators), when the symbols get small.  Due to the
+same effects, symbols can also slightly change their shape when they
+get small.
 It is not possibile to define the display intervals with
 `MINSCALEDENOM` and `MAXSCALEDENOM` in the :ref:`style`\-section, so
@@ -275,9 +290,9 @@
 different scale levels.
 Always observe that cartographical symbols depend a lot on the scale!
-So be careful with the interaction of content, symbols and scale when
-creating projects.  All three parameters heavily interact and have to
-be coordinated to produce a good map.
+So be careful with the interaction of content, symbols and scale.  All
+three parameters heavily interact and have to be coordinated to
+produce a good map.
 .. index::
@@ -308,39 +323,51 @@
 Symbols of `TYPE` `vector` and `ellipse`
-The `TYPE` `vector` defines the shape of a symbol by setting X and
-Y values in a local two dimensional coordinate system with X values
-increasing to the right and Y values increasing downwards.
+For symbols of `TYPE` `vector` and `ellipse` the shape of the symbol
+by setting X and Y values in a local two dimensional coordinate system
+with X values increasing to the right and Y values increasing
+downwards.  The coordinates defining the symbol is listed in the
+`POINTS` parameter, which is explicitly ended using `END`.
-The coordinates defining the symbol is listed in the `POINTS`
-parameter, which is explicitly ended using `END`.  The maximum number
-of points can be increased by changing the parameter
-MS_MAXVECTORPOINTS in the file mapsymbols.h before compilation.  The
-current default is 100. Note that by setting the end point equal to
-the start point you obtain a closed shape (polygon).  A `vector`
-symbol can consist of several elements (lines, polygons).  The
-coordinates -99 -99 are used to separate the elements.
+- `TYPE` `ellipse` is used to create ellipses (and circles).  The
+  shape of the ellipse is defined in the `POINTS` parameter (X - size in
+  the horizontal direction, Y - size in the vertical direction).  To
+  create a circle, let X and Y have the same value.
-When creating symbols of `TYPE` `vector` you should observe some style
-guidelines.  Avoid downtilted lines in area symbols, as they will lead
-to heavy aliasing effects. Furthermore you should not go below a
-useful minimum size, which is relevant for all types of symbols. Keep
-in mind that for pixel images, every symbol of `TYPE` `vector` has to
-be rendered using pixels (`pixmap` symbols may be used directly for
-drawing).
+- `TYPE` `vector` is used to define advanced vector symbols.  The
+  shape of the symbol is defined in the `POINTS` parameter.  A `vector`
+  symbol can consist of several elements.  The coordinates -99 -99 are
+  used to separate the elements.
-.. note::
+  To create a polygon vector symbol, the :ref:`symbol` `FILLED`
+  parameter must be set to `true`.  If the end point is not equal to
+  the start point of a polygon geometry, it will be closed
+  automatically.
-  Current behaviour is for the bounding box of a vector symbol to
-  always have 0,0 (in the :ref:`symbol` coordinate system) as its upper
-  left corner.  This can be used to generate asymmetrical symbols.
+  The maximum number of points is 100, but this can be increased by
+  changing the parameter MS_MAXVECTORPOINTS in the file mapsymbols.h
+  before compilation.
-To create ellipses (and circles), use the `TYPE` `ellipse`.  The
-shape of the ellipse is set in the `POINTS` parameter (X - size in the
-horizontal direction, Y - size in the vertical direction).  To create
-a circle, let X and Y have the same value.
+  When creating symbols of `TYPE` `vector` you should observe some style
+  guidelines.
+  - Avoid downtilted lines in area symbols, as they will lead to heavy
+    aliasing effects.
+  - Do not go below a useful minimum size.  This is relevant for all
+    types of symbols.
+  - Keep in mind that for pixel images, every symbol of `TYPE`
+    `vector` has to be rendered using pixels.
+  .. note::
+    Current behaviour is for the bounding box of a vector symbol to
+    always have 0,0 (in the :ref:`symbol` coordinate system) as its
+    upper left corner.  This can be used to generate asymmetrical
+    symbols.
 .. index::
    single: Truetype symbols
@@ -361,33 +388,29 @@
 whenever they don't fit well into the raster matrix or show a visible
 pixel structure.
-In the :ref:`style` section of the :ref:`layer` object it is possible
-to define colours for `truetype` symbols (as with signatures of the
-`TYPE` `vector`).  You can specify both fill colour and outline
-colour.
+Colours for `truetype` symbols can be specified in :ref:`layer`
+:ref:`class` :ref:`style` (as with symbols of the `TYPE` `vector` and
+`ellipse`).  You can specify both fill colour and outline colour.
 To find out the character number of a symbol use one of the following
 options:
 - Use the software FontMap (Shareware, with free trial version for
-  download, thanks Till!)
+  download, thanks Till!).
-- Use the MS Windows truetype map
+- Use the MS Windows truetype map.
-- Trial and Error :-)
+- Trial and Error. :-)
 Please note that the numbering of the so-called "symbol fonts" starts
 at 61440!  So if you want to use character &#84, you have to use 61440
 + 84 = &#61524.  (ain't that a pain!!)
 You can also place truetype characters and strings on the map using
 `LABEL`.  Then you can control the placing of the text by using the
 `POSITION` parameter [ul|uc|ur|cl|cc|cr|ll|lc|lr], that specifies the
 position relative to the geometric origin of the geometry.
 .. index::
    single: Pixmap symbols
@@ -396,8 +419,8 @@
 Symbols of the `TYPE` `pixmap` are simply small raster images. The
 file name of the raster image is specified in the `IMAGE` parameter of
-the :ref:`symbol` element.  MapServer supports the raster formats GIF and
-PNG for `pixmap`\s.
+the :ref:`symbol` element.  MapServer supports the raster formats GIF
+and PNG for `pixmap`\s.
 Observe the colour depth of the images and avoid using 24 bit PNG
 symbols displayed in 8 bit mode as this may cause unexpected colour
@@ -412,9 +435,10 @@
 The `SIZE` parameter defines the height of `pixmap` symbols when
 rendered.  The pixel structure will show when the `SIZE` grows too
-large.  If you are using symbol scaling (`SYMBOLSCALEDENOM` is set)
-and want to prevent this from happening, you should set the `MAXSIZE`
-parameter.
+large.  If you are using symbol scaling (:ref:`layer`
+`SYMBOLSCALEDENOM` is set or :ref:`layer` `SIZEUNITS` is not `pixels`)
+and want to prevent this from happening, you should set the
+:ref:`style` `MAXSIZE` parameter.
 Symbol definitions for the figure that demonstrates point symbols
@@ -451,6 +475,7 @@
   SYMBOL
     NAME "v-line"
     TYPE vector
+    FILLED false
     POINTS
       0  0
       5  10
@@ -461,7 +486,7 @@
   SYMBOL
     NAME "v-poly"
     TYPE vector
-    FILLED false
+    FILLED true
     POINTS
       0  0
       3.5 8
@@ -696,11 +721,11 @@
 Construction of Line Symbols
-For displaying line geometries you specify the width of the lines
+For displaying line geometries, you specify the width of the lines
 using the `WIDTH` parameter and the colour using the `COLOR`
 parameter.  If no colour is specified, the line will not be rendered.
-If no width is specified, a thin line (one unit (pixel) wide) will
-result.  The `LINECAP`, `LINEJOIN` and `LINEJOINMAXSIZE` parameters
+If no width is specified, a thin line (one unit (pixel) wide) will be
+rendered.  The `LINECAP`, `LINEJOIN` and `LINEJOINMAXSIZE` parameters
 are used to specify how line ends and corners are to be rendered.
 .. index::
@@ -856,8 +881,7 @@
       STYLE
         COLOR 0 0 0
         WIDTH 5.0
-        LINECAP butt
-        PATTERN 40 5 END
+        PATTERN 40 10 END
       END # STYLE
     END # CLASS
   END # LAYER
@@ -1103,12 +1127,12 @@
 By default, all lines (and patterns) will be drawn with rounded ends
 (extending the lines slightly beyond their ends).  This effect gets
-more obvious the larger the width of line is.  It is possible to alter
-this behaviour using the `LINECAP` parameter of the :ref:`style`.
-`LINECAP` `butt` will give butt ends (stops the line exactly at the
-end), with no extension of the line.  `LINECAP` `square` will give
-square ends, with an extension of the line.  `LINECAP` `round` is the
-default.
+more obvious the larger the width of the line is.  It is possible to
+alter this behaviour using the `LINECAP` parameter of the
+:ref:`style`.  `LINECAP` `butt` will give butt ends (stops the line
+exactly at the end), with no extension of the line.  `LINECAP`
+`square` will give square ends, with an extension of the line.
+`LINECAP` `round` is the default.
 .. index::
@@ -1527,10 +1551,10 @@
 way as for pixmap symbols.  Precision is necessary to get nice
-Both polygon (`FILL` on) and line (`FILL` off) vector symbols can be
-used.  For line symbols, the `WIDTH` parameter of the :ref:`style`
-will give the line width and the `SIZE` parameter will specify the
-height of the symbol.
+Both polygon (`FILLED` `true`) and line (`FILLED` `false`) vector
+symbols can be used.  For line symbols, the `WIDTH` parameter of the
+:ref:`style` will give the line width and the `SIZE` parameter will
+specify the height of the symbol.
 .. note::
@@ -1580,10 +1604,6 @@
         COLOR 0 0 0
         SIZE 35
       END # STYLE
-      STYLE
-        OUTLINECOLOR 0 0 0
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1606,10 +1626,6 @@
         WIDTH 5
         SIZE 35
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1631,10 +1647,6 @@
         COLOR 0 0 0
         SIZE 35
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1651,19 +1663,12 @@
       END # Points
     END # Feature
     CLASS
-      #STYLE
-      #  COLOR 255 255 0
-      #END
       STYLE
         SYMBOL "circlef"
         COLOR 0 0 0
         SIZE 20
         GAP 18
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1684,12 +1689,7 @@
         COLOR 0 0 0
         SYMBOL "x-poly-fill"
         SIZE 35
-        #WIDTH 2
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1711,10 +1711,6 @@
         SYMBOL "ind_marsh_poly"
         SIZE 25
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1735,12 +1731,7 @@
         COLOR  255 230 51
         SYMBOL "diag_dots"
         SIZE 30
-        #WIDTH 10
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1748,7 +1739,6 @@
   LAYER  # diagonal holes in yellow
     STATUS DEFAULT
     TYPE POLYGON
-    #OPACITY 50
     FEATURE
       POINTS
         55 80
@@ -1764,14 +1754,6 @@
         SIZE 30
         COLOR 250 220 102
       END # STYLE
-      #STYLE
-      #  COLOR 255 255 255
-      #  SIZE 30
-      #END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1803,10 +1785,6 @@
         WIDTH 10
         GAP 45
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1834,10 +1812,6 @@
         COLOR 250 220 0
         OPACITY 75
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1868,10 +1842,6 @@
         WIDTH 3
         GAP 30
       END # STYLE
-      STYLE
-        WIDTH 1
-      END # STYLE
     END # CLASS
   END # LAYER
@@ -1926,7 +1896,6 @@
   SYMBOL
     NAME "x-line"
     TYPE vector
-    #FILLED true
     POINTS
       0 0
       1 1
@@ -1985,21 +1954,21 @@
     TYPE vector
     FILLED true
     POINTS
-      # Et halvt linjestykke
+      # Half line
       0 2
       4.5 2
       4.5 3
       0 3
       0 2
       -99 -99
+      # Half line
       7 2
       11.5 2
       11.5 3
       7 3
       7 2
       -99 -99
-      # Det hele linjestykket
+      # Hole line
       1.25 5
       10.25 5
       10.25 6
@@ -2162,7 +2131,7 @@
 Polygon outlines can be created by using `OUTLINECOLOR` in the
-:ref:`STYLE`.  `WIDTH` specifies the width of the outlineline.
+:ref:`STYLE`.  `WIDTH` specifies the width of the outline.
 .. code-block:: mapfile
