[mapserver-commits] r12727 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Mon Oct 31 03:58:26 EDT 2011
Author: havatv
Date: 2011-10-31 00:58:26 -0700 (Mon, 31 Oct 2011)
New Revision: 12727
trunk/docs/en/mapfile/style.txt
Documentation of the support for PATTERN on the lines of hatch fills (#4061)
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt 2011-10-30 22:59:35 UTC (rev 12726)
+++ trunk/docs/en/mapfile/style.txt 2011-10-31 07:58:26 UTC (rev 12727)
@@ -351,15 +351,18 @@
pair: STYLE; PATTERN
PATTERN [double on] [double off] [double on] [double off] ... END
- Currently used to defines a dash pattern for line work (lines,
- polygon outlines, ...). The numbers (doubles) specify the lengths
- of the dashes and gaps of the dash pattern in layer `SIZEUNITS`.
+ Currently used to define a dash pattern for line work (lines,
+ polygon outlines, hatch lines, ...). The numbers (doubles)
+ specify the lengths of the dashes and gaps of the dash pattern in
+ layer `SIZEUNITS`.
When scaling of symbols is in effect (`SYMBOLSCALEDENOM` is
specified for the :ref:`LAYER`), the numbers specify the lengths
of the dashes and gaps in layer `SIZEUNITS` at the map scale
1:`SYMBOLSCALEDENOM`.
+ `LINECAP`, `LINEJOIN` and `LINEJOINMAXSIZE` can be used to control
+ the appearance of the dashed lines.
To specify a dashed line that is 5 units wide, with dash lengths
of 5 units and gaps of 5 units, the following style can be used:
@@ -372,6 +375,10 @@
PATTERN 5.0 5.0 END
END
+ Since version 6.2, `PATTERN` can be used to create dashed lines in
+ :ref:`symbol`\s of `TYPE` `hatch`. Patterns in hatches are always
+ drawn with `LINECAP` `butt`.
.. versionadded:: 6.0 moved from :ref:`SYMBOL`
.. index::
More information about the mapserver-commits
