[mapserver-commits] r13137 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Feb 12 04:49:41 EST 2012
Author: rouault
Date: 2012-02-12 01:49:40 -0800 (Sun, 12 Feb 2012)
New Revision: 13137
trunk/mapserver/HISTORY.TXT
trunk/mapserver/shp2img.c
shp2img: make it possible to specify layers (with -l option) that match GROUP names
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2012-02-12 09:45:59 UTC (rev 13136)
+++ trunk/mapserver/HISTORY.TXT 2012-02-12 09:49:40 UTC (rev 13137)
@@ -15,6 +15,8 @@
Current Version (SVN trunk, 6.1-dev, future 6.2):
+- shp2img: make it possible to specify layers (with -l option) that match GROUP names.
- reuse a pre-parsed mapfile across fastcgi loops in case the mapfile is
specified with the MS_MAPFILE env variable. (#4018)
Modified: trunk/mapserver/shp2img.c
--- trunk/mapserver/shp2img.c 2012-02-12 09:45:59 UTC (rev 13136)
+++ trunk/mapserver/shp2img.c 2012-02-12 09:49:40 UTC (rev 13137)
@@ -277,17 +277,18 @@
for(j=0; j<map->numlayers; j++) {
- if(GET_LAYER(map, j)->status == MS_DEFAULT)
- continue;
- else {
- GET_LAYER(map, j)->status = MS_OFF;
- for(k=0; k<num_layers; k++) {
- if(GET_LAYER(map, j)->name && strcasecmp(GET_LAYER(map, j)->name, layers[k]) == 0) {
- GET_LAYER(map, j)->status = MS_ON;
- break;
+ if(GET_LAYER(map, j)->status == MS_DEFAULT)
+ continue;
+ else {
+ GET_LAYER(map, j)->status = MS_OFF;
+ for(k=0; k<num_layers; k++) {
+ if((GET_LAYER(map, j)->name && strcasecmp(GET_LAYER(map, j)->name, layers[k]) == 0) ||
+ (GET_LAYER(map, j)->group && strcasecmp(GET_LAYER(map, j)->group, layers[k]) == 0)) {
+ GET_LAYER(map, j)->status = MS_ON;
+ break;
msFreeCharArray(layers, num_layers);
More information about the mapserver-commits
