[mapserver-commits] r13139 - trunk/mapserver
Mon Feb 13 06:20:32 EST 2012
Author: tbonfort
Date: 2012-02-13 03:20:31 -0800 (Mon, 13 Feb 2012)
New Revision: 13139
   trunk/mapserver/mapogcsld.c
   trunk/mapserver/mapogr.cpp
   trunk/mapserver/mapogroutput.c
allow ogr/sld code to compile with rfc77 changes
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c	2012-02-12 20:41:36 UTC (rev 13138)
+++ trunk/mapserver/mapogcsld.c	2012-02-13 11:20:31 UTC (rev 13139)
@@ -2898,15 +2898,21 @@
     CPLXMLNode *psTmpNode = NULL;
     char *pszClassText = NULL;
     char szTmp[100];
+    labelObj *psLabelObj = NULL;
     szFontName[0]='\0';
     if (!psRoot || !psClass || !psLayer)
         return MS_FAILURE;
+    if(psClass->numlabels == 0) {
+      if(msGrowClassLabels(psClass) == NULL) return(MS_FAILURE);
+      initLabel(psClass->labels[0]);
+    psLabelObj = psClass->labels[0];
         /*set the angle by default to auto. the angle can be
           modified Label Placement #2806*/
-        psClass->label.anglemode = MS_AUTO;
+        psLabelObj->anglemode = MS_AUTO;
         /* label  */
@@ -3036,15 +3042,15 @@
                     if ((msLookupHashTable(&(psLayer->map->fontset.fonts), szFontName) !=NULL))
                         bFontSet = 1;
-                        psClass->label.font = msStrdup(szFontName);
-                        psClass->label.type = MS_TRUETYPE;
-                        psClass->label.size = dfFontSize;
+                        psLabelObj->font = msStrdup(szFontName);
+                        psLabelObj->type = MS_TRUETYPE;
+                        psLabelObj->size = dfFontSize;
                 if (!bFontSet)
-                    psClass->label.type = MS_BITMAP;
-                    psClass->label.size = MS_MEDIUM;
+                    psLabelObj->type = MS_BITMAP;
+                    psLabelObj->size = MS_MEDIUM;
 /*      parse the label placement.                                      */
@@ -3070,7 +3076,7 @@
                     psHaloRadius =  CPLGetXMLNode(psHalo, "Radius");
                     if (psHaloRadius && psHaloRadius->psChild && psHaloRadius->psChild->pszValue)
-                      psClass->label.outlinewidth = atoi(psHaloRadius->psChild->pszValue);
+                      psLabelObj->outlinewidth = atoi(psHaloRadius->psChild->pszValue);
                     psHaloFill =  CPLGetXMLNode(psHalo, "Fill");
                     if (psHaloFill)
@@ -3099,9 +3105,9 @@
                                         /* expecting hexadecimal ex : #aaaaff */
                                         if (nLength == 7 && pszColor[0] == '#')
-                                            psClass->label.outlinecolor.red = msHexToInt(pszColor+1);
-                                            psClass->label.outlinecolor.green = msHexToInt(pszColor+3);
-                                            psClass->label.outlinecolor.blue = msHexToInt(pszColor+5);
+                                            psLabelObj->outlinecolor.red = msHexToInt(pszColor+1);
+                                            psLabelObj->outlinecolor.green = msHexToInt(pszColor+3);
+                                            psLabelObj->outlinecolor.blue = msHexToInt(pszColor+5);
@@ -3142,9 +3148,9 @@
-                                        psClass->label.color.red = msHexToInt(pszColor+1);
-                                        psClass->label.color.green = msHexToInt(pszColor+3);
-                                        psClass->label.color.blue = msHexToInt(pszColor+5);
+                                        psLabelObj->color.red = msHexToInt(pszColor+1);
+                                        psLabelObj->color.green = msHexToInt(pszColor+3);
+                                        psLabelObj->color.blue = msHexToInt(pszColor+5);
@@ -3171,12 +3177,18 @@
     CPLXMLNode *psDisplacement, *psDisplacementX, *psDisplacementY;
     CPLXMLNode *psRotation=NULL, *psPropertyName=NULL;
     char szTmp[100];
     if (!psRoot || !psClass)
         return MS_FAILURE;
         /* init the label with the default position */
-        psClass->label.position = MS_CL;
+        psLabelObj->position = MS_CL;
 /*      parse anchor point. see function msSLDParseTextSymbolizer       */
@@ -3202,25 +3214,25 @@
                     (dfAnchorY == 0 || dfAnchorY == 0.5 || dfAnchorY == 1))
                     if (dfAnchorX == 0 && dfAnchorY == 0)
-                      psClass->label.position = MS_LL;
+                      psLabelObj->position = MS_LL;
                     if (dfAnchorX == 0 && dfAnchorY == 0.5)
                     if (dfAnchorX == 0 && dfAnchorY == 1)
-                      psClass->label.position = MS_UL;
+                      psLabelObj->position = MS_UL;
                     if (dfAnchorX == 0.5 && dfAnchorY == 0)
-                      psClass->label.position = MS_LC;
+                      psLabelObj->position = MS_LC;
                     if (dfAnchorX == 0.5 && dfAnchorY == 0.5)
-                      psClass->label.position = MS_CC;
+                      psLabelObj->position = MS_CC;
                     if (dfAnchorX == 0.5 && dfAnchorY == 1)
-                      psClass->label.position = MS_UC;
+                      psLabelObj->position = MS_UC;
                     if (dfAnchorX == 1 && dfAnchorY == 0)
-                      psClass->label.position = MS_LR;
+                      psLabelObj->position = MS_LR;
                     if (dfAnchorX == 1 && dfAnchorY == 0.5)
-                      psClass->label.position = MS_CR;
+                      psLabelObj->position = MS_CR;
                     if (dfAnchorX == 1 && dfAnchorY == 1)
-                      psClass->label.position = MS_UR;
+                      psLabelObj->position = MS_UR;
@@ -3241,8 +3253,8 @@
                 psDisplacementY->psChild &&
                 psDisplacementY->psChild->pszValue)
-                psClass->label.offsetx = atoi(psDisplacementX->psChild->pszValue);
-                psClass->label.offsety = atoi(psDisplacementY->psChild->pszValue);
+                psLabelObj->offsetx = atoi(psDisplacementX->psChild->pszValue);
+                psLabelObj->offsety = atoi(psDisplacementY->psChild->pszValue);
@@ -3256,13 +3268,13 @@
             if (psPropertyName)
                 snprintf(szTmp, sizeof(szTmp), "%s", CPLGetXMLValue(psPropertyName, NULL, NULL));
-                psClass->label.bindings[MS_LABEL_BINDING_ANGLE].item = msStrdup(szTmp);
-                psClass->label.numbindings++;
+                psLabelObj->bindings[MS_LABEL_BINDING_ANGLE].item = msStrdup(szTmp);
+                psLabelObj->numbindings++;
             else
                 if (psRotation->psChild && psRotation->psChild->pszValue)
-                  psClass->label.angle = atof(psRotation->psChild->pszValue);
+                  psLabelObj->angle = atof(psRotation->psChild->pszValue);
@@ -3277,27 +3289,34 @@
 int ParseTextLinePlacement(CPLXMLNode *psRoot, classObj *psClass)
   CPLXMLNode *psOffset = NULL, *psAligned=NULL;
       return MS_FAILURE;
         /*if there is a line placement, we will assume that the
           best setting for mapserver would be for the text to follow
           the line #2806*/
-        psClass->label.anglemode = MS_FOLLOW;
+        psLabelObj->anglemode = MS_FOLLOW;
         /*sld 1.1.0 has a parameter IsAligned. default value is true*/
         psAligned = CPLGetXMLNode(psRoot, "IsAligned");
         if (psAligned && psAligned->psChild && psAligned->psChild->pszValue &&
             strcasecmp(psAligned->psChild->pszValue, "false") == 0)
-            psClass->label.anglemode = MS_NONE;
+            psLabelObj->anglemode = MS_NONE;
         psOffset = CPLGetXMLNode(psRoot, "PerpendicularOffset");
         if (psOffset && psOffset->psChild && psOffset->psChild->pszValue)
-            psClass->label.offsetx = atoi(psOffset->psChild->pszValue);
-            psClass->label.offsety = atoi(psOffset->psChild->pszValue);
+            psLabelObj->offsetx = atoi(psOffset->psChild->pszValue);
+            psLabelObj->offsety = atoi(psOffset->psChild->pszValue);
             /*if there is a PerpendicularOffset, we will assume that the
               best setting for mapserver would be to use angle=0 and the
@@ -3306,7 +3325,7 @@
                set the angles if the parameter is not set*/
             if (!psAligned)
@@ -4132,6 +4151,7 @@
     int i = 0;
     char sCssParam[30];
     char sNameSpace[10];
     sCssParam[0] = '\0';
     if (nVersion > OWS_1_0_0)
@@ -4145,8 +4165,9 @@
     if (psClass && psLayer && psLayer->labelitem &&
-        strlen(psLayer->labelitem) > 0)
+        strlen(psLayer->labelitem) > 0 && psClass->numlabels > 0)
         snprintf(szTmp, sizeof(szTmp), "<%sTextSymbolizer>\n",  sNameSpace);
         pszSLD = msStringConcatenate(pszSLD, szTmp);
@@ -4161,9 +4182,9 @@
 /*      font-weight (bold, normal). These 3 elements are separated      */
 /*      with -.                                                         */
-        if (psClass->label.type == MS_TRUETYPE && psClass->label.font)
+        if (psLabelObj->type == MS_TRUETYPE && psLabelObj->font)
-            aszFontsParts = msStringSplit(psClass->label.font, '-', &nFontParts);
+            aszFontsParts = msStringSplit(psLabelObj->font, '-', &nFontParts);
             if (nFontParts > 0)
                 snprintf(szTmp, sizeof(szTmp), "<%sFont>\n",  sNameSpace);
@@ -4194,11 +4215,11 @@
                 /* size */
-                if (psClass->label.size > 0)
+                if (psLabelObj->size > 0)
                             "<%s name=\"font-size\">%.2f</%s>\n",
-                            sCssParam, psClass->label.size, sCssParam);
+                            sCssParam, psLabelObj->size, sCssParam);
                 snprintf(szTmp, sizeof(szTmp), "</%sFont>\n",  sNameSpace);
@@ -4217,49 +4238,49 @@
         snprintf(szTmp, sizeof(szTmp), "<%sAnchorPoint>\n", sNameSpace);
-        if (psClass->label.position == MS_LL)
+        if (psLabelObj->position == MS_LL)
             dfAnchorX =0;
             dfAnchorY = 0;
-        else if (psClass->label.position == MS_CL)
+        else if (psLabelObj->position == MS_CL)
             dfAnchorX =0;
             dfAnchorY = 0.5;
-        else if (psClass->label.position == MS_UL)
+        else if (psLabelObj->position == MS_UL)
             dfAnchorX =0;
             dfAnchorY = 1;
-        else if (psClass->label.position == MS_LC)
+        else if (psLabelObj->position == MS_LC)
             dfAnchorX =0.5;
             dfAnchorY = 0;
-        else if (psClass->label.position == MS_CC)
+        else if (psLabelObj->position == MS_CC)
             dfAnchorX =0.5;
             dfAnchorY = 0.5;
-        else if (psClass->label.position == MS_UC)
+        else if (psLabelObj->position == MS_UC)
             dfAnchorX =0.5;
             dfAnchorY = 1;
-        else if (psClass->label.position == MS_LR)
+        else if (psLabelObj->position == MS_LR)
             dfAnchorX =1;
             dfAnchorY = 0;
-        else if (psClass->label.position == MS_CR)
+        else if (psLabelObj->position == MS_CR)
             dfAnchorX =1;
             dfAnchorY = 0.5;
-        else if (psClass->label.position == MS_UR)
+        else if (psLabelObj->position == MS_UR)
             dfAnchorX =1;
             dfAnchorY = 1;
@@ -4275,21 +4296,21 @@
         /* displacement */
-        if (psClass->label.offsetx > 0 || psClass->label.offsety > 0)
+        if (psLabelObj->offsetx > 0 || psLabelObj->offsety > 0)
             snprintf(szTmp, sizeof(szTmp), "<%sDisplacement>\n",  sNameSpace);
-            if (psClass->label.offsetx > 0)
+            if (psLabelObj->offsetx > 0)
                 snprintf(szTmp, sizeof(szTmp), "<%sDisplacementX>%d</%sDisplacementX>\n",
-                         sNameSpace, psClass->label.offsetx, sNameSpace);
+                         sNameSpace, psLabelObj->offsetx, sNameSpace);
-            if (psClass->label.offsety > 0)
+            if (psLabelObj->offsety > 0)
                 snprintf(szTmp, sizeof(szTmp), "<%sDisplacementY>%d</%sDisplacementY>\n",
-                         sNameSpace, psClass->label.offsety, sNameSpace);
+                         sNameSpace, psLabelObj->offsety, sNameSpace);
@@ -4297,10 +4318,10 @@
         /* rotation */
-        if (psClass->label.angle > 0)
+        if (psLabelObj->angle > 0)
             snprintf(szTmp, sizeof(szTmp), "<%sRotation>%.2f</%sRotation>\n",
-                     sNameSpace, psClass->label.angle, sNameSpace);
+                     sNameSpace, psLabelObj->angle, sNameSpace);
@@ -4311,21 +4332,21 @@
         /* color */
-        if (psClass->label.color.red != -1 &&
-            psClass->label.color.green != -1 &&
-            psClass->label.color.blue != -1)
+        if (psLabelObj->color.red != -1 &&
+            psLabelObj->color.green != -1 &&
+            psLabelObj->color.blue != -1)
-            nColorRed = psClass->label.color.red;
-            nColorGreen = psClass->label.color.green;
-            nColorBlue = psClass->label.color.blue;
+            nColorRed = psLabelObj->color.red;
+            nColorGreen = psLabelObj->color.green;
+            nColorBlue = psLabelObj->color.blue;
-        else if (psClass->label.outlinecolor.red != -1 &&
-                 psClass->label.outlinecolor.green != -1 &&
-                 psClass->label.outlinecolor.blue != -1)
+        else if (psLabelObj->outlinecolor.red != -1 &&
+                 psLabelObj->outlinecolor.green != -1 &&
+                 psLabelObj->outlinecolor.blue != -1)
-            nColorRed = psClass->label.outlinecolor.red;
-            nColorGreen = psClass->label.outlinecolor.green;
-            nColorBlue = psClass->label.outlinecolor.blue;
+            nColorRed = psLabelObj->outlinecolor.red;
+            nColorGreen = psLabelObj->outlinecolor.green;
+            nColorBlue = psLabelObj->outlinecolor.blue;
         if (nColorRed >= 0 && nColorGreen >= 0  && nColorBlue >=0)
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp	2012-02-12 20:41:36 UTC (rev 13138)
+++ trunk/mapserver/mapogr.cpp	2012-02-13 11:20:31 UTC (rev 13139)
@@ -2902,7 +2902,7 @@
       poStylePart->SetUnit(OGRSTUPixel, map->cellsize*72.0*39.37);
 #endif
-      if (eStylePartType == OGRSTCLabel)
+      if (eStylePartType == OGRSTCLabel && c->numlabels >= 1)
 #if GDAL_VERSION_NUM >= 1500 /* Use OGR Style C API */
           OGRStyleToolH hLabelStyle = hStylePart;
@@ -2918,16 +2918,16 @@
                                  (char*)CPLSPrintf("\"%s\"", escapedTextString));
           free(escapedTextString);
-          c->label.angle = OGR_ST_GetParamDbl(hLabelStyle,
+          c->labels[0]->angle = OGR_ST_GetParamDbl(hLabelStyle,
                                               OGRSTLabelAngle, &bIsNull);
-          c->label.size = OGR_ST_GetParamDbl(hLabelStyle,
+          c->labels[0]->size = OGR_ST_GetParamDbl(hLabelStyle,
                                              OGRSTLabelSize, &bIsNull);
-          if( c->label.size < 1 ) /* no point dropping to zero size */
-              c->label.size = 1;
+          if( c->labels[0]->size < 1 ) /* no point dropping to zero size */
+              c->labels[0]->size = 1;
           // OGR default is anchor point = LL, so label is at UR of anchor
-          c->label.position = MS_UR;
+          c->labels[0]->position = MS_UR;
           int nPosition = OGR_ST_GetParamNum(hLabelStyle,
                                              OGRSTLabelAnchor,
@@ -2935,18 +2935,18 @@
           if( !bIsNull )
               switch( nPosition ) {
-                case 1: c->label.position = MS_UR; break;
-                case 2: c->label.position = MS_UC; break;
-                case 3: c->label.position = MS_UL; break;
-                case 4: c->label.position = MS_CR; break;
-                case 5: c->label.position = MS_CC; break;
-                case 6: c->label.position = MS_CL; break;
-                case 7: c->label.position = MS_LR; break;
-                case 8: c->label.position = MS_LC; break;
-                case 9: c->label.position = MS_LL; break;
-                case 10: c->label.position = MS_UR; break; /*approximate*/
-                case 11: c->label.position = MS_UC; break;
-                case 12: c->label.position = MS_UL; break;
+                case 1:  c->labels[0]->position = MS_UR; break;
+                case 2:  c->labels[0]->position = MS_UC; break;
+                case 3:  c->labels[0]->position = MS_UL; break;
+                case 4:  c->labels[0]->position = MS_CR; break;
+                case 5:  c->labels[0]->position = MS_CC; break;
+                case 6:  c->labels[0]->position = MS_CL; break;
+                case 7:  c->labels[0]->position = MS_LR; break;
+                case 8:  c->labels[0]->position = MS_LC; break;
+                case 9:  c->labels[0]->position = MS_LL; break;
+                case 10: c->labels[0]->position = MS_UR; break; /*approximate*/
+                case 11: c->labels[0]->position = MS_UC; break;
+                case 12: c->labels[0]->position = MS_UL; break;
                 default: break;
@@ -2957,7 +2957,7 @@
           if (!bIsNull && OGR_ST_GetRGBFromString(hLabelStyle, pszColor,
                                                   &r, &g, &b, &t))
-              MS_INIT_COLOR(c->label.color, r, g, b, t);
+              MS_INIT_COLOR(c->labels[0]->color, r, g, b, t);
           pszColor = OGR_ST_GetParamStr(hLabelStyle,
@@ -2966,7 +2966,7 @@
                                                   &r, &g, &b, &t))
-              MS_INIT_COLOR(c->label.shadowcolor, r, g, b, t);
+              MS_INIT_COLOR(c->labels[0]->shadowcolor, r, g, b, t);
 #if GDAL_VERSION_NUM >= 1600
@@ -2976,7 +2976,7 @@
                                                   &r, &g, &b, &t))
-              MS_INIT_COLOR(c->label.outlinecolor, r, g, b, t);
+              MS_INIT_COLOR(c->labels[0]->outlinecolor, r, g, b, t);
 #endif /* GDAL_VERSION_NUM >= 1600 */
@@ -2999,23 +2999,23 @@
               if (msLookupHashTable(&(map->fontset.fonts), (char*)pszName) != NULL)
-                  c->label.type = MS_TRUETYPE;
-                  c->label.font = msStrdup(pszName);
+                  c->labels[0]->type = MS_TRUETYPE;
+                  c->labels[0]->font = msStrdup(pszName);
                   if (layer->debug >= MS_DEBUGLEVEL_VVV)
                       msDebug("** Using '%s' TTF font **\n", pszName);
               else if ( (strcmp(pszFontName,pszName) != 0) &&
                         msLookupHashTable(&(map->fontset.fonts), (char*)pszFontName) != NULL)
-                  c->label.font = msStrdup(pszFontName);
+                  c->labels[0]->font = msStrdup(pszFontName);
                       msDebug("** Using '%s' TTF font **\n", pszFontName);
               else if (msLookupHashTable(&(map->fontset.fonts),"default") != NULL)
-                  c->label.font = msStrdup("default");
+                  c->labels[0]->font = msStrdup("default");
                       msDebug("** Using 'default' TTF font **\n");
@@ -3026,8 +3026,8 @@
           if (!bFont)
 #endif /* USE_GD_FT || USE_GD_FT */
-              c->label.type = MS_BITMAP;
-              c->label.size = MS_MEDIUM;
+              c->labels[0]->type = MS_BITMAP;
+              c->labels[0]->size = MS_MEDIUM;
                   msDebug("** Using 'medium' BITMAP font **\n");
@@ -3046,31 +3046,31 @@
-          c->label.angle = poLabelStyle->Angle(bIsNull);
+          c->labels[0]->angle = poLabelStyle->Angle(bIsNull);
-          c->label.size = (int)poLabelStyle->Size(bIsNull);
+          c->labels[0]->size = (int)poLabelStyle->Size(bIsNull);
           const char *pszColor = poLabelStyle->ForeColor(bIsNull);
           if (!bIsNull && poLabelStyle->GetRGBFromString(pszColor,r,g,b,t))
           pszColor = poLabelStyle->BackColor(bIsNull);
-              MS_INIT_COLOR(c->label.backgroundcolor, r, g, b, t);
+              MS_INIT_COLOR(c->labels[0]->backgroundcolor, r, g, b, t);
 #if GDAL_VERSION_NUM >= 1400
           pszColor = poLabelStyle->ShadowColor(bIsNull);
 #endif
           // Label font... do our best to use TrueType fonts, otherwise
@@ -3086,23 +3086,23 @@
@@ -3113,8 +3113,8 @@
           if (!bFont)
Modified: trunk/mapserver/mapogroutput.c
--- trunk/mapserver/mapogroutput.c	2012-02-12 20:41:36 UTC (rev 13138)
+++ trunk/mapserver/mapogroutput.c	2012-02-13 11:20:31 UTC (rev 13139)
@@ -867,7 +867,8 @@
             if( resultshape.classindex >= 0
                 && (layer->class[resultshape.classindex]->text.string
                     || layer->labelitem)
-                && layer->class[resultshape.classindex]->label.size != -1 )
+                && layer->class[resultshape.classindex]->numlabels > 0
+                && layer->class[resultshape.classindex]->labels[0]->size != -1 )
                 resultshape.text = msShapeGetAnnotation(layer, &resultshape);
