[mapserver-commits] r13165 - trunk/mapserver/mapscript/java
svn at osgeo.org
svn at osgeo.org
Thu Feb 23 07:48:30 EST 2012
Author: unicoletti
Date: 2012-02-23 04:48:30 -0800 (Thu, 23 Feb 2012)
New Revision: 13165
trunk/mapserver/mapscript/java/Makefile.in
Make Java mapscript compile and work again after libtool changes, still need to fix the .so name
Modified: trunk/mapserver/mapscript/java/Makefile.in
--- trunk/mapserver/mapscript/java/Makefile.in 2012-02-22 17:25:14 UTC (rev 13164)
+++ trunk/mapserver/mapscript/java/Makefile.in 2012-02-23 12:48:30 UTC (rev 13165)
@@ -49,7 +49,7 @@
$(LINK) -o $@ mapscript_wrap.lo $(MS_LIB)
%.lo: %.c
- $(LTCC) $(CC) $(CFLAGS) $(JAVA_INCLUDE) -c -o $@ $<
+ $(LTCC) $(CC) -fno-strict-aliasing -fpic -c $(CFLAGS) $(JAVA_INCLUDE) -c -o $@ $<
mapscript_wrap.c: ../mapscript.i
mkdir -p edu/umn/gis/mapscript
@@ -71,8 +71,8 @@
rm -rf tests/threadtest/*.class
-ifneq ($(PROJ),)
-ifneq ($(GDAL),)
+ifneq ($(findstring PROJ, $(DEFINES)),)
+ifneq ($(findstring GDAL, $(DEFINES)),)
test:
$(JAVAC) -classpath ./:examples/:./mapscript.jar -d examples/ examples/RFC24.java examples/ConnPool.java examples/DrawMap.java examples/DumpShp.java examples/MakePoint.java examples/QueryByAttribute.java examples/ShapeInfo.java examples/WxSTest.java examples/Metadata.java examples/RunTimeBuiltWMSClient.java
$(JAVAC) -encoding utf8 -classpath ./:examples/:./mapscript.jar -d examples/ examples/QueryByAttributeUnicode.java
@@ -81,7 +81,7 @@
$(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. DrawMap ../../tests/test.map ./map.png
$(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. ConnPool
$(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. QueryByAttribute ../../tests/test.map
-ifneq ($(findstring USE_WCS_SVR, $(OWS)),)
+ifneq ($(findstring USE_WCS_SVR, $(DEFINES)),)
$(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. WxSTest ../../tests/test.map
else
@echo "WARN: Skipping WxSTest because OWS is not enabled"
More information about the mapserver-commits
