[mapserver-commits] r13166 - trunk/mapserver/mapscript/java
svn at osgeo.org
svn at osgeo.org
Thu Feb 23 08:31:33 EST 2012
Author: unicoletti
Date: 2012-02-23 05:31:33 -0800 (Thu, 23 Feb 2012)
New Revision: 13166
trunk/mapserver/mapscript/java/Makefile.in
trunk/mapserver/mapscript/java/README
trunk/mapserver/mapscript/java/javamodule.i
trunk/mapserver/mapscript/java/makefile.vc
rename java mapscript shared library (#2595) and add a make install target
Modified: trunk/mapserver/mapscript/java/Makefile.in
--- trunk/mapserver/mapscript/java/Makefile.in 2012-02-23 12:48:30 UTC (rev 13165)
+++ trunk/mapserver/mapscript/java/Makefile.in 2012-02-23 13:31:33 UTC (rev 13166)
@@ -43,27 +43,30 @@
.SUFFIXES:
.SUFFIXES: .cpp .c .$(OBJ_SUFFIX)
-all: mapscript.jar
+all: javamapscript.jar
-libmapscript.la: mapscript_wrap.lo $(MS_LIB)
- $(LINK) -o $@ mapscript_wrap.lo $(MS_LIB)
+libjavamapscript.la: javamapscript_wrap.lo $(MS_LIB)
+ $(LINK) -o $@ javamapscript_wrap.lo $(MS_LIB)
%.lo: %.c
$(LTCC) $(CC) -fno-strict-aliasing -fpic -c $(CFLAGS) $(JAVA_INCLUDE) -c -o $@ $<
-mapscript_wrap.c: ../mapscript.i
+javamapscript_wrap.c: ../mapscript.i
mkdir -p edu/umn/gis/mapscript
- $(SWIG) -java -package edu.umn.gis.mapscript $(DEFINES) -outdir edu/umn/gis/mapscript -o mapscript_wrap.c ../mapscript.i
+ $(SWIG) -java -package edu.umn.gis.mapscript $(DEFINES) -outdir edu/umn/gis/mapscript -o javamapscript_wrap.c ../mapscript.i
-mapscript_java: mapscript_wrap.c
+javamapscript_java: javamapscript_wrap.c
$(JAVAC) edu/umn/gis/mapscript/*.java
-mapscript_javadoc: mapscript_wrap.c
+mapscript_javadoc: javamapscript_wrap.c
$(JAVADOC) -d doc -sourcepath edu/umn/gis/mapscript/*.java
-mapscript.jar: mapscript_java libmapscript.la
+javamapscript.jar: javamapscript_java libjavamapscript.la
$(JAR) cf mapscript.jar edu
+install: mapscript.jar
+ $(LTINSTALL) $(INSTALL) libjavamapscript.la $(DESTDIR)$(libdir)
clean:
-rm -rf .libs *.lo *.la *.so *.o pygdioctx/*.o pygdioctx/*.lo
@@ -76,18 +79,18 @@
test:
$(JAVAC) -classpath ./:examples/:./mapscript.jar -d examples/ examples/RFC24.java examples/ConnPool.java examples/DrawMap.java examples/DumpShp.java examples/MakePoint.java examples/QueryByAttribute.java examples/ShapeInfo.java examples/WxSTest.java examples/Metadata.java examples/RunTimeBuiltWMSClient.java
$(JAVAC) -encoding utf8 -classpath ./:examples/:./mapscript.jar -d examples/ examples/QueryByAttributeUnicode.java
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. DumpShp ../../tests/point.shp
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. ShapeInfo ../../tests/point.shp ../../tests/point.dbf
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. DrawMap ../../tests/test.map ./map.png
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. ConnPool
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. QueryByAttribute ../../tests/test.map
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ DumpShp ../../tests/point.shp
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ ShapeInfo ../../tests/point.shp ../../tests/point.dbf
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ DrawMap ../../tests/test.map ./map.png
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ ConnPool
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ QueryByAttribute ../../tests/test.map
ifneq ($(findstring USE_WCS_SVR, $(DEFINES)),)
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. WxSTest ../../tests/test.map
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ WxSTest ../../tests/test.map
else
@echo "WARN: Skipping WxSTest because OWS is not enabled"
endif
- $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. RFC24 ../../tests/test.map
- LC_ALL=en_US.UTF-8 $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=. QueryByAttributeUnicode data/subset-umlauts.map
+ $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ RFC24 ../../tests/test.map
+ LC_ALL=en_US.UTF-8 $(JAVA) -classpath ./:examples/:./mapscript.jar -Djava.library.path=.libs/ QueryByAttributeUnicode data/subset-umlauts.map
else
test:
@echo "To run the tests GDAL and PROJ must be enabled"
Modified: trunk/mapserver/mapscript/java/README
--- trunk/mapserver/mapscript/java/README 2012-02-23 12:48:30 UTC (rev 13165)
+++ trunk/mapserver/mapscript/java/README 2012-02-23 13:31:33 UTC (rev 13166)
@@ -1,18 +1,14 @@
Java mapscript
-Before you begin, the JAVA_HOME environment variable must be properly set
-and the Java programs "java" and "javac" must be on your path.
+WARNING: Starting with version 6.1 Mapserver (and Mapscript) uses libtool to build
+the shared libraries. Some files have changed names and the javamapscript.so shared
+library now depends on libmapserver.so.
+The easiest way way to handle the dependency is to simply use the 'make install'
+target.
To generate the SWIG wrappers you need swig > 1.3.24.
-| IMPORTANT API CHANGE: swig 1.3.24 introduced a new way of wrapping |
-| enumerations in Java which breaks compatibility with the mapscript |
-| generated by previous versions of swig. |
-| This will change again in the next major version of mapserver (version 5). |
MAPSCRIPT Reference
@@ -32,7 +28,7 @@
Nevertheless it is recommended that you generate your own using the "interface"
target in the Java Makefile.
-Requires swig > 1.3.24. Version 1.3.28 or 1.3.29 are recommended.
+Requires swig > 1.3.24. Version above 1.3.28 or 1.3.29 are recommended.
Installation
@@ -41,16 +37,17 @@
mapscript location and execute:
$ cd mapscript/java
- $ make interface
$ make
- $ make test (optional)
+ $ make test (recommended)
$ make threadtests (optional)
+ $ make install (recommended)
-The 'make interface' step is optional, but strongly recommended, see 'SWIG Wrappers'
-above for the details.
+Copy .libs/libmapscript.so and mapscript.jar to the appropriate location or
+use let make install install them in the configured location (defaults to
+/urs/local/lib).
+Remember to set the appropriate variable (LD_LIBRARY_PATH, java.library.path
+or edit /etc/ld.so.conf) to make sure Java can locate and load the libraries.
-Copy libmapscript.so and mapscript.jar to the appropriate location.
Windows
Modified: trunk/mapserver/mapscript/java/javamodule.i
--- trunk/mapserver/mapscript/java/javamodule.i 2012-02-23 12:48:30 UTC (rev 13165)
+++ trunk/mapserver/mapscript/java/javamodule.i 2012-02-23 13:31:33 UTC (rev 13166)
@@ -9,7 +9,7 @@
%pragma(java) jniclasscode=%{
static {
- String library = System.getProperty("mapserver.library.name", "mapscript");
+ String library = System.getProperty("mapserver.library.name", "javamapscript");
System.loadLibrary(library);
/* TODO Throw when return value not MS_SUCCESS? */
Modified: trunk/mapserver/mapscript/java/makefile.vc
--- trunk/mapserver/mapscript/java/makefile.vc 2012-02-23 12:48:30 UTC (rev 13165)
+++ trunk/mapserver/mapscript/java/makefile.vc 2012-02-23 13:31:33 UTC (rev 13166)
@@ -22,7 +22,7 @@
CC= cl /MD
LINK= link
-MS_DLL = mapscript.dll
+MS_DLL = javamapscript.dll
LDFLAGS = /NODEFAULTLIB:"MSVCRTD" /NODEFAULTLIB:libcd /NODEFAULTLIB:libcmtd /NODEFAULTLIB:msvcrtd /NODEFAULTLIB:LIBC /DEBUG
More information about the mapserver-commits
