[mapserver-commits] r13225 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Mar 9 10:51:46 EST 2012
Author: tbonfort
Date: 2012-03-09 07:51:46 -0800 (Fri, 09 Mar 2012)
New Revision: 13225
trunk/mapserver/maplabel.c
re-activate masked-layer functionality for simple labels
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2012-03-09 14:13:01 UTC (rev 13224)
+++ trunk/mapserver/maplabel.c 2012-03-09 15:51:46 UTC (rev 13225)
@@ -322,6 +322,14 @@
if(numactivelabels == 0) return MS_SUCCESS;
+ /* if the number of labels is 1 then call msAddLabel() accordingly */
+ if(numactivelabels == 1) {
+ for(i=0;i<classPtr->numlabels;i++) {
+ if(classPtr->labels[i]->status == MS_ON)
+ return msAddLabel(map, classPtr->labels[i], layerindex, classindex, shape, point, NULL, featuresize);
assert(layerPtr->type != MS_LAYER_ANNOTATION || numactivelabels == 1);
/* check that the label intersects the layer mask */
@@ -351,13 +359,6 @@
- /* if the number of labels is 1 then call msAddLabel() accordingly */
- if(numactivelabels == 1) {
- for(i=0;i<classPtr->numlabels;i++) {
- if(classPtr->labels[i]->status == MS_ON)
- return msAddLabel(map, classPtr->labels[i], layerindex, classindex, shape, point, NULL, featuresize);
/* Validate label priority value and get ref on label cache for it */
priority = classPtr->labels[0]->priority; /* take priority from the first label */
@@ -493,7 +494,53 @@
layerPtr = (GET_LAYER(map, layerindex)); /* set up a few pointers for clarity */
classPtr = GET_LAYER(map, layerindex)->class[classindex];
+ /* check that the label intersects the layer mask */
+ if (layerPtr->masklayer) {
+ int maskLayerIdx = msGetLayerIndex(map, layerPtr->masklayer);
+ layerObj *maskLayer = GET_LAYER(map, maskLayerIdx);
+ if (maskLayer->maskimage && MS_IMAGE_RENDERER(maskLayer->maskimage)->supports_pixel_buffer) {
+ rasterBufferObj rb;
+ memset(&rb, 0, sizeof (rasterBufferObj));
+ MS_IMAGE_RENDERER(maskLayer->maskimage)->getRasterBufferHandle(maskLayer->maskimage, &rb);
+ if (point) {
+ int x = MS_NINT(point->x);
+ int y = MS_NINT(point->y);
+ if (rb.type == MS_BUFFER_BYTE_RGBA) {
+ unsigned char *alphapixptr = rb.data.rgba.a + rb.data.rgba.row_step * y + rb.data.rgba.pixel_step*x;
+ if (!*alphapixptr) {
+ /* label point does not intersect mask */
+ return MS_SUCCESS;
+ } else {
+ if (!gdImageGetPixel(rb.data.gd_img, x, y))
+ } else if (labelpath) {
+ int i = 0;
+ for (i = 0; i < labelpath->path.numpoints; i++) {
+ int x = MS_NINT(labelpath->path.point[i].x);
+ int y = MS_NINT(labelpath->path.point[i].y);
+ } else {
+ } else {
+ msSetError(MS_MISCERR, "Layer (%s) references references a mask layer, but the selected renderer does not support them", "msAddLabel()", layerPtr->name);
+ return (MS_FAILURE);
if (label->priority < 1)
label->priority = 1;
More information about the mapserver-commits
