[mapserver-commits] r13226 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Mar 9 11:48:43 EST 2012
Author: tbonfort
Date: 2012-03-09 08:48:43 -0800 (Fri, 09 Mar 2012)
New Revision: 13226
trunk/mapserver/mapdraw.c
trunk/mapserver/maputil.c
reverting changes from #4126 as they break mapfiles with no projection set on layers
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2012-03-09 15:51:46 UTC (rev 13225)
+++ trunk/mapserver/mapdraw.c 2012-03-09 16:48:43 UTC (rev 13226)
@@ -599,16 +599,12 @@
* Test whether a layer should be drawn or not in the current map view and
- * at the current scale and in the current extent.
+ * at the current scale.
* Returns TRUE if layer is visible, FALSE if not.
int msLayerIsVisible(mapObj *map, layerObj *layer)
int i;
- int shouldFreeProjection = MS_FALSE;
- projectionObj projection;
- rectObj ext;
- const char *value;
if(!layer->data && !layer->tileindex && !layer->connection && !layer->features && !layer->layerinfo)
return(MS_FALSE); /* no data associated with this layer, not an error since layer may be used as a template from MapScript */
@@ -678,59 +674,6 @@
- /* With wms_respect_extent true, mark layer is invisible if the request bbox is
- fully outside of the layer extent */
- value = msOWSLookupMetadata(&(layer->metadata), "MO", "respect_extent");
- if(value && strncasecmp(value, "true", 5) == 0) {
-#ifdef USE_PROJ
- /* Use a temporary projectionObj which does not affect further layer handling */
- if (layer->projection.numargs == 0) {
- msInitProjection(&projection);
- shouldFreeProjection = MS_TRUE;
- /* If layer has no projection (e.g. annotation layer), read it from wms_srs metadata */
- if ((value = (char*)msOWSGetEPSGProj(NULL, &(layer->metadata), "MO", MS_TRUE)) != NULL) {
- msLoadProjectionStringEPSG(&projection, (char *)value);
- /* Or use a pointer to the current layer projection, which we do not free afterwards */
- else {
- projection = layer->projection;
- /* Check presence of projection again */
- if ( projection.numargs == 0 ) {
- msDebug("msLayerIsVisible(): cannot comply with respect_extent metadata, layer has no projection.\n");
- /* Get the bounding box of this layer */
- else if (msOWSGetLayerExtent(map, layer, "MO", &ext) != MS_SUCCESS) {
- msDebug("msLayerIsVisible(): cannot comply with respect_extent metadata, layer has no extent.\n");
- else
- /* reproject layer extent to request srs */
- if (msProjectionsDiffer(&(map->projection), &projection) == MS_TRUE)
- msProjectRect(&projection, &(map->projection), &ext);
-#endif
- /* compare request extent to layer extent */
- if (MS_FALSE == msRectOverlap(&(map->extent), &ext)) {
- if (MS_TRUE == shouldFreeProjection) {
- msFreeProjection(&projection);
- return MS_FALSE;
-#ifdef USE_PROJ
-#endif
return MS_TRUE; /* All tests passed. Layer is visible. */
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c 2012-03-09 15:51:46 UTC (rev 13225)
+++ trunk/mapserver/maputil.c 2012-03-09 16:48:43 UTC (rev 13226)
@@ -2160,24 +2160,10 @@
rectObj map_extent;
rectObj layer_extent;
- int haveOwnProjection = MS_FALSE;
/* No extent info? Nothing we can do, return MS_UNKNOWN. */
- /* Otherwise copy extents and leave the originals intact, */
- /* beacuse we will need to transform our rectangles for comparison. */
if( (map->extent.minx == -1) && (map->extent.miny == -1) && (map->extent.maxx == -1 ) && (map->extent.maxy == -1) ) return MS_UNKNOWN;
- else MS_COPYRECT(&map_extent, &(map->extent) );
- /* For the layer extent, do a second try to read the extent */
- /* from wms_extent or layer data */
- if( (layer->extent.minx == -1) && (layer->extent.miny == -1) && (layer->extent.maxx == -1 ) && (layer->extent.maxy == -1) ) {
- if (msOWSGetLayerExtent(map, layer, "MO", &layer_extent) != MS_SUCCESS) {
- return MS_UNKNOWN;
- else MS_COPYRECT(&layer_extent, &(layer->extent) );
+ if( (layer->extent.minx == -1) && (layer->extent.miny == -1) && (layer->extent.maxx == -1 ) && (layer->extent.maxy == -1) ) return MS_UNKNOWN;
#ifdef USE_PROJ
@@ -2185,47 +2171,24 @@
if( ! (map->projection.numargs > 0) )
return MS_UNKNOWN;
- /* No layer projection? Try to get it from wms_srs. */
- if( ! (layer->projection.numargs > 0) ) {
- value = (char*)msOWSGetEPSGProj(NULL, &(layer->metadata), "MO", MS_TRUE);
- if (value != NULL) {
- haveOwnProjection = MS_TRUE;
- /* Agaian no layer projection? Return MS_UNKNOWN. We can not perform */
- /* naive comparison, because in WMS mode, map->extent is expressed in */
- /* the request SRS. */
- if( ! (layer->projection.numargs > 0) && ! (projection.numargs > 0) ) {
- if ( MS_TRUE == haveOwnProjection ) msFreeProjection(&projection);
+ /* No layer projection? Perform naive comparison, because they are
+ ** in the same projection. */
+ if( ! (layer->projection.numargs > 0) )
+ return msRectOverlap( &(map->extent), &(layer->extent) );
+ /* We need to transform our rectangles for comparison,
+ ** so we will work with copies and leave the originals intact. */
+ MS_COPYRECT(&map_extent, &(map->extent) );
+ MS_COPYRECT(&layer_extent, &(layer->extent) );
/* Transform map extents into geographics for comparison. */
- if( msProjectRect(&(map->projection), &(map->latlon), &map_extent) ) {
+ if( msProjectRect(&(map->projection), &(map->latlon), &map_extent) )
return MS_UNKNOWN;
/* Transform layer extents into geographics for comparison. */
- /* First case: using layer projection */
- /* Second case: using temporarily read projection from wms_srs */
- if( MS_FALSE == haveOwnProjection ) {
- if( msProjectRect(&(layer->projection), &(map->latlon), &layer_extent) )
- else {
- if( msProjectRect(&(projection), &(map->latlon), &layer_extent) ) {
+ if( msProjectRect(&(layer->projection), &(map->latlon), &layer_extent) )
+ return MS_UNKNOWN;
- /* Finally free the possibly created projectionObj agaian */
/* Simple case? Return simple answer. */
if ( map_extent.minx < map_extent.maxx && layer_extent.minx < layer_extent.maxx )
return msRectOverlap( &(map_extent), &(layer_extent) );
@@ -2236,7 +2199,7 @@
#else
/* No proj? Naive comparison. */
- if( msRectOverlap( &(map_extent), &(layer_extent) ) ) return MS_TRUE;
+ if( msRectOverlap( &(map->extent), &(layer->extent) ) ) return MS_TRUE;
return MS_FALSE;
#endif
More information about the mapserver-commits
