[mapserver-commits] [mapserver/mapserver] bbfa86: Repeat transformation if extent is extreme
GitHub
noreply at github.com
Mon Nov 13 13:33:26 PST 2017
Branch: refs/heads/branch-7-0
Home: https://github.com/mapserver/mapserver
Commit: bbfa86661216c370fa5e4860ca4d4a9efcbc3a7e
https://github.com/mapserver/mapserver/commit/bbfa86661216c370fa5e4860ca4d4a9efcbc3a7e
Author: David Shorthouse <davidpshorthouse at gmail.com>
Date: 2016-12-13 (Tue, 13 Dec 2016)
Changed paths:
M mapresample.c
Log Message:
Repeat transformation for a rectangle interior to the output requested region. If the latter results in a more extreme y extent, then extend extents in source layer projection to southern/northing bounds and entire x extent. This fix resolves issue #4864.
Commit: 51ea1eeeac2239f0793ef6653ba48445b0a797b8
https://github.com/mapserver/mapserver/commit/51ea1eeeac2239f0793ef6653ba48445b0a797b8
Author: Jeff McKenna <jeffmckenna at gmail.com>
Date: 2017-11-13 (Mon, 13 Nov 2017)
Changed paths:
M mapresample.c
Log Message:
Merge pull request #5360 from dshorthouse/patch-1
Compare: https://github.com/mapserver/mapserver/compare/e7362a11131d...51ea1eeeac22
More information about the mapserver-commits
