[mapserver-commits] [mapserver/mapserver] bbfa86: Repeat transformation if extent is extreme
GitHub noreply at github.com
Fri Nov 17 04:12:09 PST 2017
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: bbfa86661216c370fa5e4860ca4d4a9efcbc3a7e
      https://github.com/mapserver/mapserver/commit/bbfa86661216c370fa5e4860ca4d4a9efcbc3a7e
  Author: David Shorthouse <davidpshorthouse at gmail.com>
  Date:   2016-12-13 (Tue, 13 Dec 2016)
  Changed paths:
    M mapresample.c
  Log Message:
Repeat transformation for a rectangle interior to the output requested region. If the latter results in a more extreme y extent, then extend extents in source layer projection to southern/northing bounds and entire x extent. This fix resolves issue #4864.
  Commit: f96f9d7884f713d56b7c78501edb97ec376edd91
      https://github.com/mapserver/mapserver/commit/f96f9d7884f713d56b7c78501edb97ec376edd91
  Author: Seth G <geographika at gmail.com>
  Date:   2017-09-26 (Tue, 26 Sep 2017)
  Changed paths:
    M msautotest/gdal/heat.map
  Log Message:
  MINSCALE and MAXSCALE are both deprecated
  Commit: 7887b8d6ff51b7b918b747be57e696955a560083
      https://github.com/mapserver/mapserver/commit/7887b8d6ff51b7b918b747be57e696955a560083
  Date:   2017-10-01 (Sun, 01 Oct 2017)
  Changed paths:
    M msautotest/misc/scaletoken.map
  Log Message:
  DEBUG 10 is an invalid value
  Commit: d78096d069e757b6889b3e51f8b48fac00c2cc61
      https://github.com/mapserver/mapserver/commit/d78096d069e757b6889b3e51f8b48fac00c2cc61
  Changed paths:
  Log Message:
  Update scaletoken.map
  Commit: 572bd765e7a0f55b8826a9bdbd2b661e07ff44b9
      https://github.com/mapserver/mapserver/commit/572bd765e7a0f55b8826a9bdbd2b661e07ff44b9
  Author: Martin.Icking <martin.icking at bentley.com>
  Date:   2017-11-10 (Fri, 10 Nov 2017)
  Changed paths:
    M mapfile.c
  Log Message:
  Added the option to set a default value for variable substitution in the map's WEB section. To do that there is a new method applyHashTableDefaultSubstitutions that is being called in msApplyDefaultSubstitutions with the map's WEB section as the hash table to work on
  Commit: d1907912880b124c97472066ef20e0c61bf3c213
      https://github.com/mapserver/mapserver/commit/d1907912880b124c97472066ef20e0c61bf3c213
  Changed paths:
    M maplayer.c
    M maporaclespatial.c
  Log Message:
  commented out vtable entries for msOracleSpatialEscapePropertyName.
By that we don't need the additional logic described below anymore
Revert "Enclose the sortby property in double quotes by putting the result of  msLayerEscapePropertyName into double quotes"
This reverts commit d5f89a3353854b0f6a8eda0758d99e74372fdf9f.
  Commit: fd04328a89e75ac963f15867d9d90a50d47513c1
      https://github.com/mapserver/mapserver/commit/fd04328a89e75ac963f15867d9d90a50d47513c1
  Author: Jeff McKenna <jeffmckenna at gmail.com>
  Date:   2017-11-13 (Mon, 13 Nov 2017)
  Changed paths:
    M maplayer.c
  Log Message:
  Merge pull request #5517 from BentleySystems/fix-remove-msOracleSpatialEscapePropertyName
Proper escaping of Oracle sortby parameters - Enhancement for pull request #5454
  Commit: 41100a91af55f2a11e516ee8d8dc49b8a194ade5
      https://github.com/mapserver/mapserver/commit/41100a91af55f2a11e516ee8d8dc49b8a194ade5
  Changed paths:
    M mapfile.c
  Log Message:
  Merge pull request #5516 from BentleySystems/fix-allow-web-substitution-defaults
enable default value for variable substitution in map's WEB section
  Commit: d3299fc311dfc5eda8ee6d1eb45587dd28e6cb3a
      https://github.com/mapserver/mapserver/commit/d3299fc311dfc5eda8ee6d1eb45587dd28e6cb3a
  Changed paths:
  Log Message:
  Merge pull request #5488 from geographika/patch-4
  Commit: e7362a11131dd0fe6132e59efb93f79a1e08d379
      https://github.com/mapserver/mapserver/commit/e7362a11131dd0fe6132e59efb93f79a1e08d379
  Changed paths:
  Log Message:
  Merge pull request #5482 from geographika/patch-3
  Commit: 51ea1eeeac2239f0793ef6653ba48445b0a797b8
      https://github.com/mapserver/mapserver/commit/51ea1eeeac2239f0793ef6653ba48445b0a797b8
  Changed paths:
    M mapresample.c
  Log Message:
  Merge pull request #5360 from dshorthouse/patch-1
  Commit: 4c5fa185ad9940d6339bf1e849143a6e553f7aa9
      https://github.com/mapserver/mapserver/commit/4c5fa185ad9940d6339bf1e849143a6e553f7aa9
  Date:   2017-11-15 (Wed, 15 Nov 2017)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  update for 7.0.7 release
  Commit: 116c7d235220e3e4cfea0d19c958e21739b309b9
      https://github.com/mapserver/mapserver/commit/116c7d235220e3e4cfea0d19c958e21739b309b9
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2017-11-17 (Fri, 17 Nov 2017)
  Changed paths:
    M mapdraw.c
    M mapraster.c
    M mapserver.h
    M mapuvraster.c
    M msautotest/wxs/expected/wms_uvraster_lonwrap180_accross_hemisphere.png
    M msautotest/wxs/expected/wms_uvraster_lonwrap180_east_hemisphere.png
    M msautotest/wxs/expected/wms_uvraster_lonwrap180_west_hemisphere.png
    M msautotest/wxs/expected/wms_uvraster_lonwrap180_whole_world.png
  Log Message:
  UVRaster: better result quality for rasters whose longitude span from 0 to 360 deg (complementary fix for #5502)
  Commit: 42f2aa44259f08d0daa10e56216c1ccb6daafd9f
      https://github.com/mapserver/mapserver/commit/42f2aa44259f08d0daa10e56216c1ccb6daafd9f
  Changed paths:
    M mapdraw.c
    M mapfile.c
    M maplayer.c
    M mapraster.c
    M mapresample.c
    M mapserver.h
    M mapuvraster.c
  Log Message:
  Merge branch 'branch-7-0'
Compare: https://github.com/mapserver/mapserver/compare/fd2bd750ab59...42f2aa44259f
