[mapserver-commits] [mapserver/mapserver] 7beddf: Remove FLTGetMapserverExpression() and subroutines...
GitHub
noreply at github.com
Fri Sep 7 06:01:33 PDT 2018
Branch: refs/heads/master
Home: https://github.com/mapserver/mapserver
Commit: 7beddffd43fcf3be5fccd97fd778606d141a76d0
https://github.com/mapserver/mapserver/commit/7beddffd43fcf3be5fccd97fd778606d141a76d0
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2018-09-07 (Fri, 07 Sep 2018)
Changed paths:
M mapogcfilter.c
M mapogcfilter.h
Log Message:
Remove FLTGetMapserverExpression() and subroutines that are not used in code base. FLTGetCommonExpression() does the same
Commit: 655a873cbf7c88ede6edbc6231ee22e1f6ecc33d
https://github.com/mapserver/mapserver/commit/655a873cbf7c88ede6edbc6231ee22e1f6ecc33d
Author: Even Rouault <even.rouault at mines-paris.org>
Changed paths:
M mapogcfilter.c
M mapogcfilter.h
Log Message:
Merge pull request #5659 from rouault/remove_unused_FLTGetMapserverExpression
Remove FLTGetMapserverExpression() and subroutines that are not used …
Compare: https://github.com/mapserver/mapserver/compare/d50430b959d9...655a873cbf7c
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the mapserver-commits
