[mapserver-commits] [mapserver/mapserver] c144dd: Add tests and test data to package
GitHub noreply at github.com
Sat Sep 8 07:36:36 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: c144dd03e2772c1b9de413a4f1a5fdd5d82c4f34
      https://github.com/mapserver/mapserver/commit/c144dd03e2772c1b9de413a4f1a5fdd5d82c4f34
  Author: geographika <sethg at geographika.co.uk>
  Date:   2018-09-04 (Tue, 04 Sep 2018)
  Changed paths:
    M mapscript/python/setup.py.in
  Log Message:
  Commit: 660808f42587eb9edca29e239387c912cd200841
      https://github.com/mapserver/mapserver/commit/660808f42587eb9edca29e239387c912cd200841
  Changed paths:
    M mapscript/python/CMakeLists.txt
  Log Message:
  Update build process to create a virtual environment and install and test the wheel in this
  Commit: 5ac111f4d18dfda048e9fe1d5017b0c9ccc36560
      https://github.com/mapserver/mapserver/commit/5ac111f4d18dfda048e9fe1d5017b0c9ccc36560
  Changed paths:
    M mapscript/python/requirements-dev.txt
  Log Message:
  Ensure latest versions on setuptools and wheel are installed
  Commit: 832c0a1344ca2313be036e15222739f4e3163ea7
      https://github.com/mapserver/mapserver/commit/832c0a1344ca2313be036e15222739f4e3163ea7
  Changed paths:
    M mapscript/python/tests/cases/testing.py
  Log Message:
  Use test data from within the mapscript package
  Commit: 4ec932383ae9e9638493fdeb4e08ae166676b651
      https://github.com/mapserver/mapserver/commit/4ec932383ae9e9638493fdeb4e08ae166676b651
  Changed paths:
    R mapscript/python/tests/cases/pytest.ini
  Log Message:
  pytest.ini no longer required
  Commit: ecf8db4546ba5d9f617f0bb6c59c8276229aa64a
      https://github.com/mapserver/mapserver/commit/ecf8db4546ba5d9f617f0bb6c59c8276229aa64a
  Changed paths:
    A mapscript/python/tests/cases/class_test.py
    R mapscript/python/tests/cases/classtest.py
  Log Message:
  Rename test file to be picked up by pytest
  Commit: 5dcc5d1c2f9a1ffa48be69c73b5335084e02c292
      https://github.com/mapserver/mapserver/commit/5dcc5d1c2f9a1ffa48be69c73b5335084e02c292
  Changed paths:
    A mapscript/python/tests/cases/clone_test.py
    R mapscript/python/tests/cases/clonetest.py
    A mapscript/python/tests/cases/colort_est.py
    R mapscript/python/tests/cases/colortest.py
    A mapscript/python/tests/cases/font_test.py
    R mapscript/python/tests/cases/fonttest.py
    A mapscript/python/tests/cases/hash_test.py
    R mapscript/python/tests/cases/hashtest.py
    A mapscript/python/tests/cases/image_test.py
    R mapscript/python/tests/cases/imagetest.py
    A mapscript/python/tests/cases/label_test.py
    R mapscript/python/tests/cases/labeltest.py
    A mapscript/python/tests/cases/layer_test.py
    R mapscript/python/tests/cases/layertest.py
    A mapscript/python/tests/cases/line_test.py
    R mapscript/python/tests/cases/linetest.py
    A mapscript/python/tests/cases/map_test.py
    R mapscript/python/tests/cases/maptest.py
    A mapscript/python/tests/cases/outputformat_test.py
    R mapscript/python/tests/cases/outputformattest.py
    A mapscript/python/tests/cases/ows_test.py
    R mapscript/python/tests/cases/owstest.py
    A mapscript/python/tests/cases/point_test.py
    R mapscript/python/tests/cases/pointtest.py
    A mapscript/python/tests/cases/rect_test.py
    R mapscript/python/tests/cases/recttest.py
    A mapscript/python/tests/cases/resultcache_test.py
    R mapscript/python/tests/cases/resultcachetest.py
    A mapscript/python/tests/cases/shape_test.py
    A mapscript/python/tests/cases/shapefile_test.py
    R mapscript/python/tests/cases/shapefiletest.py
    R mapscript/python/tests/cases/shapetest.py
    A mapscript/python/tests/cases/style_test.py
    R mapscript/python/tests/cases/styletest.py
    A mapscript/python/tests/cases/symbol_test.py
    A mapscript/python/tests/cases/symbolset_test.py
    R mapscript/python/tests/cases/symbolsettest.py
    R mapscript/python/tests/cases/symboltest.py
    A mapscript/python/tests/cases/zoom_test.py
    R mapscript/python/tests/cases/zoomtest.py
  Log Message:
  Rename all test files to be picked up by pytest
  Commit: 8bef6c918c7ad552e201f8ee3f043f594994ce87
      https://github.com/mapserver/mapserver/commit/8bef6c918c7ad552e201f8ee3f043f594994ce87
  Changed paths:
    M appveyor.yml
  Log Message:
  Add wheel building to Appveyor
  Commit: 473921127ea8d298c96e5e1b24152945f992df0a
      https://github.com/mapserver/mapserver/commit/473921127ea8d298c96e5e1b24152945f992df0a
  Changed paths:
  Log Message:
  Check for Release subfolder for MSVC
  Commit: 3f201973ac19655e498eb5c7094e2e6d61097af3
      https://github.com/mapserver/mapserver/commit/3f201973ac19655e498eb5c7094e2e6d61097af3
  Changed paths:
  Log Message:
  Remove incorrect variable
  Commit: beab44d818f32272285bac9d1c6ad2f6145c66ee
      https://github.com/mapserver/mapserver/commit/beab44d818f32272285bac9d1c6ad2f6145c66ee
  Changed paths:
  Log Message:
  Use CMAKE_BUILD_TYPE for MSCV subfolder
  Commit: d9d916a23aafeb1ac3ff2944eeb62853df7b5605
      https://github.com/mapserver/mapserver/commit/d9d916a23aafeb1ac3ff2944eeb62853df7b5605
  Changed paths:
  Log Message:
  Use correct virtualenv location
  Commit: 52c41dfb6370cc85ff5375e8f5dbf31a8d465b6b
      https://github.com/mapserver/mapserver/commit/52c41dfb6370cc85ff5375e8f5dbf31a8d465b6b
  Changed paths:
    M mapscript/python/README.rst
  Log Message:
  Update README.rst with notes about testing and new build process
  Commit: 371d46530d874a92f2eccae68db1f27a82708920
      https://github.com/mapserver/mapserver/commit/371d46530d874a92f2eccae68db1f27a82708920
  Author: Seth G <geographika at gmail.com>
  Date:   2018-09-08 (Sat, 08 Sep 2018)
  Changed paths:
    M .travis.yml
    M COMMITERS
    M mapmvt.c
    M mapogcfilter.c
    M mapogcfilter.h
    M mapogcfiltercommon.c
    M mapogcsld.c
    M mappostgis.c
    M mapwcs.c
    M mapwcs20.c
    M mapwms.c
    M mapxbase.c
    A msautotest/renderers/expected/labels-wrap.png
    A msautotest/renderers/labels-wrap.map
    A msautotest/wxs/data/test_islike_escaping.csv
    A msautotest/wxs/data/test_islike_escaping.dbf
    A msautotest/wxs/data/test_islike_escaping.shp
    A msautotest/wxs/data/test_islike_escaping.shx
    A msautotest/wxs/expected/wfs_filter_islike_escaping.xml
    M msautotest/wxs/wfs_filter.map
    M textlayout.c
  Log Message:
  Merge branch 'master' into python-test-fixes
  Commit: 265c7e0b31168551d4d289a679ceda56f4a2a81a
      https://github.com/mapserver/mapserver/commit/265c7e0b31168551d4d289a679ceda56f4a2a81a
  Changed paths:
    M appveyor.yml
  Log Message:
  Merge pull request #5657 from geographika/python-test-fixes
Add test suite to Python Wheel Builds
Compare: https://github.com/mapserver/mapserver/compare/efb012a66584...265c7e0b3116
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
